My name is Steef, and I am exploring the (endless) possibilities of the Domoticz workaround.
I have Domoticz running on a Raspberry Pi 3b, running on Raspbian.
Because I would really like to receive detailed weather information, I am trying to follow a nice how-to I found on the internet: https://ehoco.nl/domoticz-weerstation/ (The how-to is in Dutch).
I followed the how-to, but somehow, I receive an error on the following line:
commandArray[#commandArray+1] = {['UpdateDevice'] = otherdevices_idx[device]..'|'..tostring(nvalue)..'|'..tostring(svalues)}
The complete script is mentioned below. I am trying to understand the .lua language, but it is new to me, and can not find the error.
Is there anyone who can help me with this problem? many thanks!
--[[ WEERSTATIONS:
Amsterdam = 36 Groningen = 13 Oost-Groninigen = 31 Vlissingen = 44
Arnhem = 2 Hoek van Holland = 17 Oost-Overijssel = 12 Voorschoten = 46
Berkhout = 3 Hoogeveen = 18 Rotterdam = 33 Wadden = 19
Den Helder = 6 Leeuwarden = 26 Utrecht = 5 Weert = 8
Eindhoven = 7 Lelystad = 27 Terneuzen = 47 West-Friesland = 38
Gilze Rijen = 10 Maastricht = 29 Twente = 41 West-Utrecht = 28
Goes = 11 Noord-Groninigen = 24 Uden = 45 Woensdrecht = 50
Gorinchem = 16 Noordoostpolder = 30 Venlo = 1 Zwolle = 15
---------- SETTINGS ------------
local domo_ip = "lokaal IP plus poort" -- IP adres van Domoticz, inclusief poort
local weerstation = 15 -- Kies je weerstation naar keuze
local api_key = "API key" -- Darksky secret key
local debug = 0 -- 0 = no debug, 1 = debug
local language = "nl" -- ar: Arabic, az: Azerbaijani, be: Belarusian, bg: Bulgarian, bs: Bosnian, ca: Catalan, cs: Czech, da: Danish,
-- de: German, el: Greek, en: English, es: Spanish, et: Estonian, fi: Finnish, fr: French, he: Hebrew, hr: Croatian,
-- hu: Hungarian, id: Indonesian, is: Icelandic, it: Italian, ja: Japanese, ka: Georgian, ko: Korean, kw: Cornish,
-- lv: Latvian, nb: Norwegian Bokmål, nl: Dutch, no: Norwegian Bokmål (alias for nb), pl: Polish, pt: Portuguese,
-- ro: Romanian, ru: Russian, sk: Slovak, sl: Slovenian, sr: Serbian, sv: Swedish, tet: Tetum, tr: Turkish,
-- uk: Ukrainian, x-pig-latin: Igpay Atinlay, zh: simplified Chinese, zh-tw: traditional Chinese
local dev_TempGround = "GrondTemperatuur" -- Temperature sensor
local dev_TextTomorrow = "Verwachting morgen" -- Text sensor
local dev_LongText = "Uitgebreide verwachting" -- Text sensor
local dev_DewPoint = "Dauwpunt" -- Temperature sensor
local dev_CloudCover = "Bewolkingsgraad" -- Percentage sensor
local dev_UV = "UV" -- UV sensor
local dev_Ozone = "Ozone" -- Custom sensor with axis "DU"
--Functie devices updaten
if commandArray == nil then commandArray = {} end
function UpdateDev(device,nvalue,svalues)
-- Functie afronding
function round(num, dec)
if num == 0 then
return 0
local mult = 10^(dec or 0)
return math.floor(num * mult + 0.5) / mult
----- ######## Buienradar API Data call ######## -----
time = os.date("*t")
if ((time.min+2)%5)==0 then -- Script loopt iedere 5 minuten (bv. 11.03, 11.08, 11.13, 11.18, etc.
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- For Linux
local config=assert(io.popen('curl "https://api.buienradar.nl/data/public/2.0/jsonfeed"'))
local Stringjson = config:read('*all')
config:close()
local jsonData = json:decode(Stringjson)
-- Convert the json to a LUA table
if jsonData.actual.stationmeasurements[ weerstation ] ~= nil then -- this sometimes happens around midnight
val_TempGround = jsonData.actual.stationmeasurements[ weerstation ].groundtemperature
val_WeatherTomorrow = jsonData.forecast.fivedayforecast[1].weatherdescription
val_SunChanceTomorrow = jsonData.forecast.fivedayforecast[1].sunChance
val_RainChanceTomorrow = jsonData.forecast.fivedayforecast[1].rainChance
val_RainMinimum = jsonData.forecast.fivedayforecast[1].mmRainMin
val_RainMaximum = jsonData.forecast.fivedayforecast[1].mmRainMax
val_WindDirectionTomorrow = jsonData.forecast.fivedayforecast[1].windDirection
val_WindSpeedTomorrow = jsonData.forecast.fivedayforecast[1].wind
val_TempTomorrowMinMin = jsonData.forecast.fivedayforecast[1].mintemperatureMin --minimale minimumtemperatuur
val_TempTomorrowMaxMin = jsonData.forecast.fivedayforecast[1].mintemperatureMax --maximale minimumtemperatuur
val_TempTomorrowMinMax = jsonData.forecast.fivedayforecast[1].maxtemperatureMin --minimale maximumtemperatuur
val_TempTomorrowMaxMax = jsonData.forecast.fivedayforecast[1].maxtemperatureMax --maximale maximumtemperatuur
--Min/Max. temperatuur bepalen
if val_TempTomorrowMinMin == val_TempTomorrowMaxMin then TempMinimum = val_TempTomorrowMinMin
else TempMinimum = val_TempTomorrowMinMin.." - "..val_TempTomorrowMaxMin end
if val_TempTomorrowMinMax == val_TempTomorrowMaxMax then TempMaximum = val_TempTomorrowMinMax
else TempMaximum = val_TempTomorrowMinMax.." - "..val_TempTomorrowMaxMax
--Regenhoeveeldheid bepalen
if val_RainMinimum == val_RainMaximum then RainIntensity = val_RainMinimum
else RainIntensity = val_RainMinimum.." - "..val_RainMaximum end
-- Windrichting tekst bepalen
if val_WindDirectionTomorrow == "z" or val_WindDirectionTomorrow == "Z" then WindDirectionTomorrow = " het zuiden"
elseif val_WindDirectionTomorrow == "zw" or val_WindDirectionTomorrow == "ZW" then WindDirectionTomorrow = "het zuidwesten"
elseif val_WindDirectionTomorrow == "zo" or val_WindDirectionTomorrow == "ZO" then WindDirectionTomorrow = "het zuidoosten"
elseif val_WindDirectionTomorrow == "w" or val_WindDirectionTomorrow == "W" then WindDirectionTomorrow = "het westen"
elseif val_WindDirectionTomorrow == "nw" or val_WindDirectionTomorrow == "NW" then WindDirectionTomorrow = "het noordwesten"
elseif val_WindDirectionTomorrow == "n" or val_WindDirectionTomorrow == "N" then WindDirectionTomorrow = "het noorden"
elseif val_WindDirectionTomorrow == "no" or val_WindDirectionTomorrow == "NO" then WindDirectionTomorrow = " het noordoosten"
elseif val_WindDirectionTomorrow == "o" or val_WindDirectionTomorrow == "O" then WindDirectionTomorrow = "het oosten"
else WindDirectionTomorrow = "variabele richtingen" end
--Voorspellingen
forecast=val_WeatherTomorrow.. "\n " .."\n".. "Komende nacht daalt de temperatuur naar "..TempMinimum.." °C. Morgen overdag wordt morgen maximaal "..TempMaximum.. " °C. Er is morgen "..val_SunChanceTomorrow.." % kans op zon en "..val_RainChanceTomorrow.." % kans op neerslag ("..RainIntensity.." mm). De wind komt uit "..WindDirectionTomorrow.." en zal kracht "..val_WindSpeedTomorrow.." Bft hebben." .."\n " .."\n "
if otherdevices_svalues[dev_TextTomorrow] ~= forecast then UpdateDev(dev_TextTomorrow,0,forecast) end
-- Updating domoticz devices
UpdateDev(dev_TempGround,0,val_TempGround)
if debug==1 then
print ("Temperatuur grond: "..val_TempGround.." °C")
-- ######## Darksy API call ######## --
local config=assert(io.popen('curl "http://'..domo_ip..'/json.htm?type=settings"'))
config:close()
lat = jsonData.Location.Latitude
lon = jsonData.Location.Longitude
local coord = lat..","..lon
local config=assert(io.popen('curl "https://api.darksky.net/forecast/'..api_key..'/'..coord..'?lang='..language..'&units=si&exclude=hourly,flags"'))
config:close()
if jsonData ~= nil then -- this sometimes happens around midnight
val_UV = jsonData.currently.uvIndex
val_Ozone = jsonData.currently.ozone
val_DewPoint = round(jsonData.currently.dewPoint,1)
val_CloudCover = jsonData.currently.cloudCover*100
if debug==1 then
print("Bewolkingsgraad : "..val_CloudCover.. " %")
print("UV-kracht :"..val_UV)
print("Ozone : De ozone-waarde is "..val_Ozone)
print("Dauwpunt : "..val_DewPoint.. " °C")
-- Domoticz devices updaten
UpdateDev(dev_CloudCover,0,val_CloudCover)
UpdateDev(dev_DewPoint,0,val_DewPoint)
UpdateDev(dev_UV,0,val_UV..";0")
UpdateDev(dev_Ozone,0,val_Ozone)
if debug==1 then
print ("Dauwpunt: "..val_DewPoint.." °C")
print ("Bewolkingsgraad: "..val_CloudCover.." %")
print ("UV-Index: "..val_UV)
print ("Ozone: "..val_Ozone)
-- ######## Buienradar Verwachting API call ######## --
if ((time.min+2)%30)==0 then -- Script loopt iedere 30 minuten (bv. 11.28, 11.58, 12.28, 12.58, etc.
local config=assert(io.popen('curl "https://api.buienradar.nl/data/public/1.1/jsonfeed"'))
config:close()
val_LongText = jsonData.buienradarnl.weergegevens.verwachting_vandaag.titel .."\n " .."\n ".. jsonData.buienradarnl.weergegevens.verwachting_vandaag.tekst .."\n " .."\n"
if debug==1 then
print ("Uitgebreid: "..val_LongText)
if otherdevices_svalues[dev_LongText] ~= val_LongText then UpdateDev(dev_LongText,0,val_LongText) end
