Difference between RFXtrx433E and ICS-2000
gschmidt
What is the difference between the RFXtrx433E and ICS-2000 hardware?
I am just starting with domoticz. Have some mi-lights working in domoticz.
but I also have a few KAKU devices (3x lights, rolling shutter, sunscreen and ventilation system ) in my house which I want to control (with voice).
Greetzzz,
Gerben
Greetzzz,
Gerben
b_weijenberg
- Target OS: -
Re: Difference between RFXtrx433E and ICS-2000
See chapter 2.2.2 in the RFXtrx User Guide for the list of supported devices by the RFXtrx433E and RFXtrx433XL.
It supports KAKU, Somfy RTS, Dooya and many others.
RFX-433, RFX-433EMC, RFX-868
gschmidt
I was aware...but where do you need ics-2000 for then?
Domoticz + RFXtrx is far more then an ICS2000, which is only/mainly used for Kaku devices.
But you can use both to control and recieve devices.
gschmidt
Aha thanx! But ics-2000 is found as a device in google assitant and Rfxtrx is not...
You can use Controlicz together with Domoticz and RFXtrx and have a lot more devices available in Google Home.
I command all my switches, rollershutters and read temperatures etc with this setup.
gschmidt
Aha, Is controlicz a paid service?
- felix63
- Domoticz version: 2020.1
Yes. Controlicz is a paid service. 20 GBP per year or 2 GBP per month. For which someone is running a server, creating and maintaining software and providing adequate end-user support.
gschmidt
True!
It appears that ics-2000 is capable of connecting tradfri IKEA lamps, is this also possible with the rfxtrx433e device?...I ask this because I want to avoid buying multiple hardware.
b_weijenberg
- Target OS: -
Please search and read the forum before asking questions.
The RFXtrx433XL operates at 433MHz.
tradfri IKEA is using Zigbee at 2.4GHz and is supported by Domoticz.
viewtopic.php?f=65&t=17312&p=199977&hil ... EA#p199978
Check also if the ICS2000 supports all possibilities of the RFXtrx433XL and Domoticz.
