The receiver is always in sleeping mode, i manually manage it state by a uservariable.
I recently started to convert to DZVENTZ and getting rid of LUA...
I have a two scripts:
1. denon_volume (dimmer) for on/off and volume changing
2. denon_source for selecting the source. WITH LUA i had no problems but with dzventz i still have some problems.
When denon is in sleeping state, and selecting a source (like radio), my denon_source turns the receiver on, selects the source, so far so good!
But the domoticz device denon_volume is still off. I dont understand this because i do call to dz.devices['denon_volume'].switchOn(). With LUA scripts this part was working....
When i can activate the dimmer switch from denon_source i can get rid of the uservariables and read the state of this dimmer for on/off
denon_source
on = {devices = {'denon_source'}},
logging = { level = domoticz.LOG_DEBUG ,marker = actOnIdleDevices },
execute = function(dz, device)
--domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
local scriptnaam = 'testsource'
local receiver_source = dz.devices('denon_source')
local receiver_volume = dz.devices('denon_volume')
local ip = dz.variables('ipdenon').value
local denonstatus = dz.variables('denonstatus')
if receiver_source.state == 'FM RADIO' then -- selector 10
SourceToSet = 'TUNER';
elseif receiver_source.state == 'TV ZIGGO' then -- selector 10
SourceToSet = 'SAT/CBL';
elseif receiver_source.state == 'SONOS' then -- selector 30
SourceToSet = 'CD';
elseif receiver_source.state == 'KODI MCE' then -- selector 40
SourceToSet = 'MPLAY';
elseif receiver_source.state == 'PC KABEL' then -- selector 50
SourceToSet = 'GAME';
elseif receiver_source.state == 'CHROMECAST' then -- selector 60
SourceToSet = 'BD';
SourceToSet = 'Unknown';
if ( SourceToSet == 'Unknown' ) then
-- do nothing
else -- Denon wordt op Source gezet nog aanpassen check denon aan ?
if denonstatus== 'Off' then -- als denon uitstaat
dz.devices['denon_volume'].switchOn() --my denon goes on, but not the denon_volume switch
os.execute ("curl http://" .. (ip) .. "/MainZone/index.put.asp?cmd0=PutZone_InputFunction%2F" .. (SourceToSet) ); -- Denon wordt op source gezet
--denonstatus.set('On')
dz.log("Script: " .. scriptnaam .. " Device:" .. receiver_source.state .. " set source input = " .. (SourceToSet) .. ". => " .. receiver_source.state)
active = true,
devices = {
'denon_volume'
execute = function(domoticz, RECEIVER_VOLUME)
local scriptnaam = 'dztest_volume'
local TVSTATUS = domoticz.devices('tv-woonkamer') -- switch met tv status TVSTATUS=os.execute('ping -c 1 192.168.20.24') duurt te lang, dus ping-service gebruikt
local RECEIVER_SOURCE = domoticz.devices('denon_source') -- switch met DENON devices
local RECEIVER_MIXER = domoticz.devices('denon_mixer') -- switch met DENON mixer
local RADIO_SENDER = 'denon_radio' -- switch met DENON radio zender
local IP = domoticz.variables('ipdenon').value -- ip adress denon receiver,
local IPTV = domoticz.variables('iptv').value -- ip adress tv
local DENONSTATUS = domoticz.variables('denonstatus') -- USER variabele in domoticz waar DENON status wordt bijgehouden
local MAXLEVEL = 50 -- MAximaal volume DENON
local DEFLEVEL = 20 -- Default volume DENON
local XOLDVOLUME = domoticz.variables('denonvolume') -- opgeslagen volume
local OLDVOLUME =XOLDVOLUME.value -- ip adress denon receiver, niet nodig ping service van domoticz wordt gebruikt
local RVOLUME = RECEIVER_VOLUME.level -- Apply offset from absolute to relative
local VOLUME = RVOLUME
local VOLCOR = 80
domoticz.log('PRG: 1 ' ..scriptnaam ..' tv:' .. IPTV .. ' Status:' .. TVSTATUS.state) -- voor debugging
if (RECEIVER_VOLUME.state == 'On') then -- denon wordt AAN gezet
os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FON" ); -- zet denon aan
DENONSTATUS.set('On') -- zet uservariabele aan
domoticz.log('PRG: 2 ' ..scriptnaam ..': denon is aangezet') -- debugging
if (TVSTATUS.state == 'On') then --TV staat AAN
--RECEIVER_SOURCE.switchSelector(20) -- zet versterker op tv .afterSec(2)
--RECEIVER_MIXER.switchSelector(10) -- set versterker op stereo
domoticz.log('PRG: 3 ' ..scriptnaam ..': denon op tv gezet') -- debugging
elseif (TVSTATUS.state == 'Off') then --TV staat UIT
--RECEIVER_SOURCE.switchSelector(10) -- zet versterker op RADIO .afterSec(2)
--RADIO_SENDER.switchSelector(10) -- set radio zender sky
--RECEIVER_MIXER.switchSelector(20) -- set versterker op mch stereo
domoticz.log('PRG: 4 ' ..scriptnaam ..': denon op radio gezet') -- debugging
else --TV heeft geen status
domoticz.log('PRG: 5 ' ..scriptnaam ..': Geen tv status bekend') -- debugging
if (RVOLUME == OLDVOLUME) then
VOLUME=DEFLEVEL
elseif tonumber(RVOLUME) == 0 then -- als slidergeluid = opgeslagen geluid
VOLUME=DEFLEVEL
if tonumber(VOLUME) > MAXLEVEL then -- Peter toegevoegd volume maxlevel
VOLUME = MAXLEVEL
os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/" .. (VOLUME-VOLCOR)); --set volume
XOLDVOLUME.set(VOLUME) -- zet uservariabele aan --RECEIVER_VOLUME.switchSelector(VOLUME)
domoticz.log('PRG: 6 ' ..scriptnaam .. ' VOLUME aangepast: Slidervolume:' .. tostring(RVOLUME) .. ' Oldvolume:' .. tostring(OLDVOLUME) .. ' NieuwVolume:' .. tostring(VOLUME)) -- debugging
elseif (RECEIVER_VOLUME.state == 'Off') then -- denon wordt UIT gezet
os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FOFF" ); -- zet denon uit
DENONSTATUS.set('Off') -- zet uservariabele aan
domoticz.log('PRG:7 ' ..scriptnaam ..': denon is uitgezet') -- debugging
