Problems converting LUA to DZVENTZ
pvklink
Domoticz version: latest b
Post by pvklink »
Hi i have several LUA scripts to manage my denon receiver with http commands.
The receiver is always in sleeping mode, i manually manage it state by a uservariable.
I recently started to convert to DZVENTZ and getting rid of LUA...
I have a two scripts:
1. denon_volume (dimmer) for on/off and volume changing
2. denon_source for selecting the source. WITH LUA i had no problems but with dzventz i still have some problems.
When denon is in sleeping state, and selecting a source (like radio), my denon_source turns the receiver on, selects the source, so far so good!
But the domoticz device denon_volume is still off. I dont understand this because i do call to dz.devices['denon_volume'].switchOn(). With LUA scripts this part was working....
When i can activate the dimmer switch from denon_source i can get rid of the uservariables and read the state of this dimmer for on/off
denon_source
	on = {devices = {'denon_source'}},
    logging = { level   = domoticz.LOG_DEBUG ,marker  = actOnIdleDevices },
	execute = function(dz, device)
	--domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
    local scriptnaam        = 'testsource'
    local receiver_source   = dz.devices('denon_source')
    local receiver_volume   = dz.devices('denon_volume')
    local ip                = dz.variables('ipdenon').value
    local denonstatus       = dz.variables('denonstatus')
    if receiver_source.state == 'FM RADIO' then                -- selector 10
        SourceToSet = 'TUNER';
    elseif receiver_source.state == 'TV ZIGGO' then     -- selector 10
        SourceToSet = 'SAT/CBL';
    elseif receiver_source.state == 'SONOS' then         -- selector 30
        SourceToSet = 'CD';
    elseif receiver_source.state == 'KODI MCE' then         -- selector 40
        SourceToSet = 'MPLAY';
    elseif receiver_source.state == 'PC KABEL' then         -- selector 50
        SourceToSet = 'GAME';
    elseif receiver_source.state == 'CHROMECAST' then        -- selector 60
        SourceToSet = 'BD';
        SourceToSet = 'Unknown';
    if ( SourceToSet == 'Unknown' ) then
        -- do nothing
    else        -- Denon wordt op Source gezet nog aanpassen check denon aan ?
        if denonstatus== 'Off' then                                                 -- als denon uitstaat
            dz.devices['denon_volume'].switchOn()  --my denon goes on, but not the denon_volume switch
        os.execute ("curl http://" .. (ip) .. "/MainZone/index.put.asp?cmd0=PutZone_InputFunction%2F" .. (SourceToSet) );   -- Denon wordt op source gezet
        --denonstatus.set('On')
    dz.log("Script: " .. scriptnaam .. " Device:" .. receiver_source.state .. " set source input = " .. (SourceToSet) .. ". => " .. receiver_source.state)
denon_volume
   active = true,
		devices = {
			'denon_volume'
execute = function(domoticz, RECEIVER_VOLUME)
    local scriptnaam = 'dztest_volume'
    local TVSTATUS = domoticz.devices('tv-woonkamer')                                                       -- switch met tv status       TVSTATUS=os.execute('ping -c 1 192.168.20.24') duurt te lang, dus ping-service gebruikt
    local RECEIVER_SOURCE = domoticz.devices('denon_source')                                                -- switch met DENON devices
    local RECEIVER_MIXER = domoticz.devices('denon_mixer')                                                  -- switch met DENON mixer
    local RADIO_SENDER = 'denon_radio'        -- switch met DENON radio zender
    local IP = domoticz.variables('ipdenon').value                                                          -- ip adress denon receiver,
    local IPTV = domoticz.variables('iptv').value                                                           -- ip adress tv
    local DENONSTATUS = domoticz.variables('denonstatus')                                                   -- USER variabele in domoticz waar DENON status wordt bijgehouden
    local MAXLEVEL = 50        -- MAximaal volume DENON
    local DEFLEVEL = 20        -- Default volume DENON
    local XOLDVOLUME = domoticz.variables('denonvolume')                                                    -- opgeslagen volume
    local OLDVOLUME =XOLDVOLUME.value        -- ip adress denon receiver, niet nodig ping service van domoticz wordt gebruikt
    local RVOLUME = RECEIVER_VOLUME.level        -- Apply offset from absolute to relative
    local VOLUME = RVOLUME
    local VOLCOR = 80
    domoticz.log('PRG: 1 ' ..scriptnaam ..' tv:' .. IPTV .. ' Status:' .. TVSTATUS.state)                     -- voor debugging
    if (RECEIVER_VOLUME.state == 'On') then        -- denon wordt AAN gezet
        os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FON" );            -- zet denon aan
        DENONSTATUS.set('On')        -- zet uservariabele aan
        domoticz.log('PRG: 2 ' ..scriptnaam ..': denon is aangezet')                                              -- debugging
	    if (TVSTATUS.state == 'On') then        --TV staat AAN
            --RECEIVER_SOURCE.switchSelector(20)        -- zet versterker op tv             .afterSec(2)
            --RECEIVER_MIXER.switchSelector(10)        -- set versterker op stereo
            domoticz.log('PRG: 3 ' ..scriptnaam ..': denon op tv gezet')                                              -- debugging
        elseif (TVSTATUS.state == 'Off') then        --TV staat UIT
            --RECEIVER_SOURCE.switchSelector(10)        -- zet versterker op RADIO         .afterSec(2)
            --RADIO_SENDER.switchSelector(10)        -- set radio zender sky
            --RECEIVER_MIXER.switchSelector(20)        -- set versterker op mch stereo
            domoticz.log('PRG: 4 ' ..scriptnaam ..': denon op radio gezet')                                           -- debugging
        else        --TV heeft geen status
            domoticz.log('PRG: 5 ' ..scriptnaam ..': Geen tv status bekend')                                      -- debugging
        if (RVOLUME == OLDVOLUME) then
            VOLUME=DEFLEVEL
        elseif tonumber(RVOLUME) == 0 then                                             -- als slidergeluid = opgeslagen geluid
            VOLUME=DEFLEVEL
        if tonumber(VOLUME) > MAXLEVEL then        -- Peter toegevoegd volume maxlevel
            VOLUME = MAXLEVEL
        os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/" .. (VOLUME-VOLCOR)); --set volume
        XOLDVOLUME.set(VOLUME)        -- zet uservariabele aan        --RECEIVER_VOLUME.switchSelector(VOLUME)
        domoticz.log('PRG: 6 ' ..scriptnaam .. ' VOLUME aangepast: Slidervolume:' .. tostring(RVOLUME) .. ' Oldvolume:' .. tostring(OLDVOLUME) .. ' NieuwVolume:' .. tostring(VOLUME))           -- debugging
    elseif  (RECEIVER_VOLUME.state == 'Off') then                                                           -- denon wordt UIT gezet
        os.execute ("curl http://" .. (IP) .. "/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FOFF" );           -- zet denon uit
        DENONSTATUS.set('Off')        -- zet uservariabele aan
        domoticz.log('PRG:7  ' ..scriptnaam ..': denon is uitgezet')                                              -- debugging
Jablotron connection, Ikea
Re: Problems converting LUA to DZVENTZ
pvklink wrote: Tuesday 11 December 2018 20:22 I dont understand this because i do call to dz.devices['denon_volume'].switchOn()
try changing
to
pvklink
Post by pvklink »
I have rewritten all my denon scripts, All dzventz now instead of LUA. I also eliminated uservariables etc. Problems are gone now...
