IFTTT, Ring & domoticz
assenzuid
Post by assenzuid »
I want to add my Ring Doorbell into Domoticz through IFTTT. Not sure how to fix that?
I have enabled IFTTT in Domoticz, I must do something with Blocky.
Must I create an dummy device in Domoticz?
Skippiemanz
Domoticz version: 4.10233
Re: IFTTT, Ring & domoticz
Post by Skippiemanz »
What ive done is created a virtual switch called doorbell and made it a push on button with a switch of delay of 1 sec. Then in the iftt i made an app witch call a webhook when the doorbell is pressed. This switches the Domoticz switch. Usualy this is done within 10 seconds.
assenzuid
Post by assenzuid »
Do you have an example how to make exactly the webhook :?
felix63
Domoticz version: 2020.1
Post by felix63 »
In IFTTT create an applet with IF Ring 'New Ring Detected' and THEN Webhook 'Make a Web Request' with as URL:
https://userxxx:[email protected]/json.htm?type=command&param=switchlight&idx=99&switchcmd=On
If you update the URL for your own and change the idx to your virtual devices then that should do the trick.
assenzuid
Post by assenzuid »
Thanks, I wil try it :D
Users browsing this forum: Daro1003 and 1 guest
