I want to add my Ring Doorbell into Domoticz through IFTTT. Not sure how to fix that?
I have enabled IFTTT in Domoticz, I must do something with Blocky.
Must I create an dummy device in Domoticz?
IFTTT, Ring & domoticz
Skippiemanz
- Domoticz version: 4.10233
Re: IFTTT, Ring & domoticz
What ive done is created a virtual switch called doorbell and made it a push on button with a switch of delay of 1 sec. Then in the iftt i made an app witch call a webhook when the doorbell is pressed. This switches the Domoticz switch. Usualy this is done within 10 seconds.
assenzuid
Do you have an example how to make exactly the webhook
- felix63
- Domoticz version: 2020.1
In IFTTT create an applet with IF Ring 'New Ring Detected' and THEN Webhook 'Make a Web Request' with as URL:
If you update the URL for your own and change the idx to your virtual devices then that should do the trick.
https://userxxx:[email protected]/json.htm?type=command¶m=switchlight&idx=99&switchcmd=On-
assenzuid
Thanks, I wil try it
Users browsing this forum: willemd and 1 guest
