Variable for Blockly
Jubbes
Hello, is it possible to make a Variable that i can use in Blockly?
The variable should say 15 min. before sunset.
In Blockly then:
if time = new variable `sunset-10min` then .......
Jubbes
In Blockly then:
Jubbes
- waaren
Re: Variable for Blockly
You can set the value of a User variables created in Domoticz with dzVents at the time you want (in this case 15 minutes before sunset) or when a certain event occurred. And this can trigger a Blockly like the attached when saved as to be started on UserVariable events
Jubbes
can you show me this script with user value in dzVents???? 15min before sunset. Thank you
- waaren
Below how to set (and reset) the value of the domoticz user Variable named "Alarm" of type string.Jubbes wrote: Wednesday 24 October 2018 20:32 can you show me this script with user value in dzVents???? 15min before sunset. Thank you
-- setvar
on = { timer = { "15 minutes before sunset" }},
logging = { level = domoticz.LOG_DEBUG, -- INFO, DEBUG or ERROR
marker = "setvar" },
execute = function(dz, item)
domoticz.variables("Alarm").set("On") -- set to On
domoticz.variables("Alarm").set("Off").afterSec(60) -- set to Off after 60 seconds
Jubbes
and now what i do in blockly is:
if alarm = on do. set scene......... = on
korrect?
korrect?
- waaren
That is a possibility but why should you do that ? Anything that can be done with Blockly, can be done with dzVents and a whole lot more..Jubbes wrote: Wednesday 24 October 2018 21:24 and now what i do in blockly is:
korrect?
Look at the video Danny (creator of dzVents) posted and the wiki to get an idea of the possibilities when learning this framework for using Lua with domoticz.
Jubbes
i know, but i am a absolute beginner in domoticz, blockly and dzVents.
Thank you very very much for your help !!!!!
The value Alarm can have every name?
- waaren
Yes it can have any name as long as you change it in domoticz, dzVents and Blockly to keep it aligned . Also have a look at my (edited) previous post. Now with links to the wiki and youtube video on dzVents.Jubbes wrote: Wednesday 24 October 2018 21:43 i know, but i am a absolute beginner in domoticz, blockly and dzVents.
Jubbes
The script doesnt run. What must i do in more options / user variables?
- waaren
My mistake, sorry. Should be:Jubbes wrote: Thursday 25 October 2018 21:09 The script doesnt run. What must i do in more options / user variables?
-- setvar
}Debian buster, bullseye on RPI-4, Intel NUC.
