Variable for Blockly
Jubbes
Post by Jubbes »
Hello, is it possible to make a Variable that i can use in Blockly?
The variable should say 15 min. before sunset.
In Blockly then:
if time = new variable `sunset-10min` then .......
Jubbes
Re: Variable for Blockly
You can set the value of a User variables created in Domoticz with dzVents at the time you want (in this case 15 minutes before sunset) or when a certain event occurred. And this can trigger a Blockly like the attached when saved as to be started on UserVariable events
Jubbes
Post by Jubbes »
can you show me this script with user value in dzVents???? 15min before sunset. Thank you
Jubbes wrote: Wednesday 24 October 2018 20:32 can you show me this script with user value in dzVents???? 15min before sunset. Thank you
Below how to set (and reset) the value of the domoticz user Variable named "Alarm" of type string.
--  setvar
        on = {  timer =         { "15 minutes before sunset" }},
        logging =   {   level   = domoticz.LOG_DEBUG,                        -- INFO, DEBUG or ERROR
                        marker = "setvar" },
    execute = function(dz, item)
        domoticz.variables("Alarm").set("On")                                 -- set to On
        domoticz.variables("Alarm").set("Off").afterSec(60)                   -- set to Off after 60 seconds
Jubbes
Post by Jubbes »
and now what i do in blockly is:
if alarm = on do. set scene......... = on
korrect?
Jubbes wrote: Wednesday 24 October 2018 21:24 and now what i do in blockly is:
korrect?
That is a possibility but why should you do that ? Anything that can be done with Blockly, can be done with dzVents and a whole lot more..
Look at the video Danny (creator of dzVents) posted and the wiki to get an idea of the possibilities when learning this framework for using Lua with domoticz.
Jubbes
Post by Jubbes »
i know, but i am a absolute beginner in domoticz, blockly and dzVents.
Thank you very very much for your help !!!!!
The value Alarm can have every name?
Jubbes wrote: Wednesday 24 October 2018 21:43 i know, but i am a absolute beginner in domoticz, blockly and dzVents.
Yes it can have any name as long as you change it in domoticz, dzVents and Blockly to keep it aligned . Also have a look at my (edited) previous post. Now with links to the wiki and youtube video on dzVents.
Jubbes
Post by Jubbes »
The script doesnt run. What must i do in more options / user variables?
Jubbes wrote: Thursday 25 October 2018 21:09 The script doesnt run. What must i do in more options / user variables?
My mistake, sorry. Should be:
--  setvar
