Do nodes act as repeaters by themselves or need to be configured for this?
przemhb
Post by przemhb »
I am wondering do I have to manually configure Z-Wave nodes, for example mains powered ones, to act as repeaters for battery powered? If so, then how? By proper grouping them?
Or maybe each Z-Wave node acts as repeater out of box, without any extra configuration?
emme
Domoticz version: latest
Re: Do nodes act as repeaters by themselves or need to be configured for this?
Post by emme »
zwave mesh and routing is normally helded automatically by the controller (the zWave stick itself, not the server)
there are few options you can try to forse routings.... one is healing the network that forse the controller to ping each node and find a better way to communicate with it
another way (for a specific route) is going to the OpenZWaveControl Panel and select operation TEST AND HEAL and select the 2 nodes and HEAL RETURN ROUTES
both of them would take time to complete
"We always done this way"
jvdz
Domoticz version: 4.107
Post by jvdz »
They will automatically act as router when the device supports that an ddo not need to be configured.
Jos
przemhb
Post by przemhb »
Thank you for your explanations :)
kimhav
Domoticz version: 2023.2
Post by kimhav »
You can also verify if this works as it should by checking Setup/Hardware and click on Setup for the Zwave controller and under Node Management/Groups & Network which would provide you a map of the mesh network:
przemhb
Post by przemhb »
In my case it looks like this. Node ID 28 is a newly added light switch. Nodes 18 and 26 are door locks. Node 18 was last time seen on 30.09. Before that time it worked and I got configured notification. Unfortunately it stopped for a reason unknown to me.
Nodes 20-25 are previous instances of the current node 26. I've factory reset and re-included it.
przemhb
Post by przemhb »
kimhav
Post by kimhav »
Have you enabled polling for the zwave devices else you'll have some devices going red for sleeping after not receiving an update for a while. I've set my poll interval (under controller settings) to 60 sec.
przemhb
Post by przemhb »
For nodes 15 and 16 only. I've read it is advised to avoid polling when only it is possible.
jvdz
Post by jvdz »
Correct, polling is only needed when the devices shows an issue updating itself.
Jos
kimhav
Post by kimhav »
Agree the polling should be used wise due to the limited bandwidth that the zwave mesh network have and some general guidelines can also be applied:
  • Devices that update their state automatically such as a motion sensor being triggered or a switch turning on do not need to be polled.
  • Devices such as temperature sensors (including those embedded within a motion sensor) may require polling if no option exists to send a report of the sensors state regularly.
  • The Fibaro and Aeotec Multi Sensors all have options to send a report at regular intervals of their temperature, humidity, lux, etc. states. However, by default this option is turned off.
  • Any device that does not have an option to send a regular report a a specific interval will need to be polled.
  • Devices that sleep will ignore polling requests.
przemhb
Post by przemhb »
Thank you kimhav for you reply.
How can I delete previous occurrences of a node, which later was included with a new ID? In the screenshot above nodes 20-25 are such an old occurrences of the node 26. The node was factory reset and re-included. Unfortunately each time it the node stayed with old ID in OZW control panel.
I've tried to use the OZW control panel Controller->Remove Device. I've selected a node to be removed and clicked Go button. It changed it's label to Cancel suggesting something is going on, but there was no effect. I've left it overnight. Nothing changed.
The same applies for Remove Failed Node.
Maybe I shouldn't worry about those nodes? I'd be thankful for help on the matter, as this is unclear to me and I cannot find any explanation nowhere.
