Is it possible to send message when domoticz started?
Mixanoid
Sometimes we have problems on power line. I cannot see when the line is down (domoticz does not work without electricity) but can I receive the message when domoticz turns on?
- Egregius
- Domoticz version: v2024.7
Re: Is it possible to send message when domoticz started?
You could use a cron job for that, or alter the init.d script.
- waaren
I use this dzVents script to notify when domoticz has been started.Mixanoid wrote: Tuesday 09 October 2018 17:23 Sometimes we have problems on power line. I cannot see when the line is down (domoticz does not work without electricity) but can I receive the message when domoticz turns on?
active when function returns true ( domoticz started less then 180 seconds ago )
The defined tasks will only execute once after domoticz started.
Please note that in theory this is not a failsafe way of handling this.
If domoticz crashes / is stopped after the first excution of this script and before 120 seconds after
it started, the Executed value is not set back to 0 and the script needs to be reloaded to reset the persistent data.
If domoticz starts extremely slow, in theory it could be that this script will not be evaluated before the 180 seconds
after startup has passed. On my test system (PI-3), first execution is well within that window. (somewhere between 13 and 60 seconds)
active = function(domoticz)
return domoticz.startTime.secondsAgo < 180
end,
on = { timer = { 'every minute' } },
data = { Executed = { initial = 0 } },
execute = function(dz)
if dz.data.Executed == 0 then
dz.notify("Domoticz has just been started")
print ("Älready executed; " .. tostring(dz.data.Executed) .. " seconds after domoticz started.")
if dz.startTime.secondsAgo > 119 then
dz.data.Executed = 0
}Debian buster, bullseye on RPI-4, Intel NUC.
- EdddieN
- Domoticz version: 4.9700
I use Monit for it with pushover, but I also like very much @waaren solution.
11101101 - www.machinon.com
- Domoticz version: 2026.3
I use this script but got up to 3 notifications after a restart of Domoticz. 1 is enoughwaaren wrote: Tuesday 09 October 2018 18:47
--[[ active when function returns true ( domoticz started less then 180 seconds ago ) The defined tasks will only execute once after domoticz started. Please note that in theory this is not a failsafe way of handling this. If domoticz crashes / is stopped after the first excution of this script and before 120 seconds after it started, the Executed value is not set back to 0 and the script needs to be reloaded to reset the persistent data. If domoticz starts extremely slow, in theory it could be that this script will not be evaluated before the 180 seconds after startup has passed. On my test system (PI-3), first execution is well within that window. (somewhere between 13 and 60 seconds) ]]-- return { active = function(domoticz) return domoticz.startTime.secondsAgo < 180 end, on = { timer = { 'every minute' } }, data = { Executed = { initial = 0 } }, execute = function(dz) if dz.data.Executed == 0 then dz.notify("Domoticz has just been started") dz.data.Executed = dz.startTime.secondsAgo else print ("Allready executed; " .. tostring(dz.data.Executed) .. " seconds after domoticz started.") if dz.startTime.secondsAgo > 119 then dz.data.Executed = 0 end end end }
So I added the line
dz.data.Executed = dz.startTime.secondsAgoDomoticz running on Udoo X86 (on Ubuntu)
- waaren
This script was posted a long time ago. dzVents evolved since then ...waltervl wrote: Wednesday 27 January 2021 0:33 I use this dzVents script to notify when domoticz has been started....
You can now do
-- system triggers available in dzVents >= 3.0.0 (domoticz V4 build 11687)
return
on =
system =
'start',
logging =
level = domoticz.LOG_DEBUG,
marker = 'startup tasks'
