Is it possible to send message when domoticz started?
Mixanoid
Post by Mixanoid »
Sometimes we have problems on power line. I cannot see when the line is down (domoticz does not work without electricity) but can I receive the message when domoticz turns on?
Egregius
Domoticz version: v2024.7
Re: Is it possible to send message when domoticz started?
Post by Egregius »
You could use a cron job for that, or alter the init.d script.
Mixanoid wrote: Tuesday 09 October 2018 17:23 Sometimes we have problems on power line. I cannot see when the line is down (domoticz does not work without electricity) but can I receive the message when domoticz turns on?
I use this dzVents script to notify when domoticz has been started.
    active when function returns true ( domoticz started less then 180 seconds ago )
    The defined tasks will only execute once after domoticz started.
    Please note that in theory this is not a failsafe way of handling this.
    If domoticz crashes / is stopped after the first excution of this script and before 120 seconds after
    it started, the Executed value is not set back to 0 and the script needs to be reloaded to reset the persistent data.
    If domoticz starts extremely slow, in theory it could be that this script will not be evaluated before the 180 seconds
    after startup has passed. On my test system (PI-3), first execution is well within that window. (somewhere between 13 and 60 seconds)
    active = function(domoticz)
              return domoticz.startTime.secondsAgo < 180
            end,
    on         = {      timer     = { 'every minute'  } },
    data     = {     Executed     = { initial = 0 } },
    execute = function(dz)
        if dz.data.Executed == 0 then
            dz.notify("Domoticz has just been started")
            print ("Älready executed; " .. tostring(dz.data.Executed) .. " seconds after domoticz started.")
            if dz.startTime.secondsAgo > 119 then
                dz.data.Executed = 0
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
I use Monit for it with pushover, but I also like very much @waaren solution.
11101101 - www.machinon.com
Domoticz version: 2024.7
waaren wrote: Tuesday 09 October 2018 18:47
            end,
            dz.data.Executed = dz.startTime.secondsAgo
            print ("Allready executed; " .. tostring(dz.data.Executed) .. " seconds after domoticz started.")
I use this script but got up to 3 notifications after a restart of Domoticz. 1 is enough :-)
So I added the line
after dz.notify("Domoticz has just been started") and now I get only 1 notification.
waltervl wrote: Wednesday 27 January 2021 0:33 I use this dzVents script to notify when domoticz has been started....
This script was posted a long time ago. dzVents evolved since then ...
You can now do
-- system triggers available in dzVents >= 3.0.0 (domoticz V4 build 11687)
return
    on =
        system =
            'start',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'startup tasks'
