Need help with sunscreen script  [Solved]
drwurn
Post by drwurn »
Since I can't make such a script with blockly cause of the multiple 'if' I need some help with dzvents. Did some reading on wiki and the forum but guess I'm not much of a script writer.
The weather conditions are from darksky
What I want to create is the following:
If
'zonnescherm' is closed
Time is between 11.30 and sunset
Date is between 1 april and 30 september
'Windsnelheid Assen' <8
'UV Index Assen' >1
'Regen voorspelling Assen' <1
Then
Set 'Zonnescherm' On
If 'Zonnescherm' is On and one of the conditions changing, 'Zonnescherm' should close. (Off)
Not sure if I'm missing something.
Who can help me with creating this?
Re: Need help with sunscreen script
drwurn wrote: Tuesday 09 October 2018 12:42 Since I can't make such a script with blockly cause of the multiple 'if' I need some help with dzvents. Did some reading on wiki and the forum but guess I'm not much of a script writer.
If
'UV Index Assen' >1
Then
Could be something like this
-- sunProtection.lua
        on =        { timer   =   {"every 10 minutes between 11:30 and 10 minute after sunset on 1/4-30/9"}},
        logging =   {   level   =   domoticz.LOG_DEBUG,
                        marker  =   "Sunscreen" },
    execute = function(dz)
        local sunscreen       = dz.devices(###)                      -- replace ### by your sunscreen device IDX
        local windSpeed       = dz.devices(###).speed                 -- replace ### by your virtual wind device IDX
        local UV              = dz.devices(###).uv                    -- replace ### by your virtual UV device IDX
        local rainPrediction  = tonumber(dz.devices(###).state)       -- replace ### by your virtual rainprediction device IDX
        local OnConditionsMet =  sunscreen.state == "Open" and   -- Maybe you need to reverse this to ~= or to "Closed"
                                 windSpeed < 8 and
                                 UV > 1 and
                                 rainPrediction < 1 and
                                 dz.time.matchesRule("between 11:30 and sunset")
        if OnConditionsMet then
            sunscreen.switchOff()
            sunscreen.switchOn().checkFirst()
drwurn
Post by drwurn »
waaren wrote: Tuesday 09 October 2018 21:10
If
'UV Index Assen' >1
Then
                                 windSpeed < 8 and
                                 UV > 1 and
That looks good.
I've spend the intire evening on this script.
       timer = { 'on 1/4-30/9 between 11:30 and sunset' },
   execute = function (domoticz, item)
      if item.isTimer and
      domoticz.devices('Test lamp').state == "On" and
      domoticz.devices('UV Index Assen').uv >0 then
         domoticz.devices('Dummy Zonnescherm').switchOn()
         domoticz.devices('Dummy Zonnescherm').switchOff()
Still not finished and needs testing.
Also need to work out how to get a message when the sunscreen is set to off, and which variable causes it.
drwurn wrote: Tuesday 09 October 2018 23:48 Also need to work out how to get a message when the sunscreen is set to off, and which variable causes it.
Does this help ?
                                 windSpeed < 8 and
                                 UV > 1 and
            if sunscreen.state == "Closed " then
                if windSpeed    >= 8 then dz.notify(sunscreen.name .. " closed because of windspeed " .. windSpeed)
                elseif UV           <= 1 then dz.notify(sunscreen.name .. " closed because of UV " .. UV)
                elseif rainPrediction    >= 1 then dz.notify(sunscreen.name .. " closed because of rainPrediction " .. rainPrediction)
                else dz.notify(sunscreen.name .. " closed because of timerule " )
drwurn
Post by drwurn »
I've made a dummy switch for the sunscreen for testing.
The dummy switch turned on this morning but didn't turn off after sunset or because of the UV rule
drwurn wrote: Wednesday 10 October 2018 19:03 I've made a dummy switch for the sunscreen for testing.
Can you check what the On / Off equivalent of "Open" is for your sunscreen and report back ?
What would also help is to add some log statements.
Thx
drwurn
Post by drwurn »
waaren wrote: Wednesday 10 October 2018 22:04
Thx
Open = On and Close = Off.
The sunscreen isn't responding at all with the script, without the script the screen works as normal. Double checked the IDX's and they're right.
The log:
2018-10-10 22:18:00.410 Status: dzVents: Info: Sunscreen: ------ Start internal script: Zonnescherm:, trigger: every 1 minutes between 11:30 and 1 minute after 23:59 on 1/4-30/12
2018-10-10 22:18:00.446 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Dummy Zonnescherm Forum: Switch device adapter
2018-10-10 22:18:00.447 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Windsnelheid Assen: Wind device adapter
2018-10-10 22:18:00.449 Status: dzVents: Debug: Sunscreen: Processing device-adapter for UV Index Assen: UV device adapter
2018-10-10 22:18:00.450 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Regen voorspelling Assen: Rain device
2018-10-10 22:18:00.450 Status: dzVents: Info: Sunscreen: ------ Finished Zonnescherm
drwurn wrote: Wednesday 10 October 2018 22:26
Thx
At line 23 there is an extra space after the word Closed that does not belong there. Can you correct that and try again ?
drwurn
Post by drwurn »
waaren wrote: Wednesday 10 October 2018 22:38
Thx
Removed it but still don't work
Re: Need help with sunscreen script  [Solved]
drwurn wrote: Wednesday 10 October 2018 22:26 ... Removed it but still don't work
I Sent you a PM
dendoba
Post by dendoba »
And? Did you manage to get it working?😊
remko2000
Post by remko2000 »
good question: did you succeed???
