Need help with sunscreen script [Solved]
drwurn
Since I can't make such a script with blockly cause of the multiple 'if' I need some help with dzvents. Did some reading on wiki and the forum but guess I'm not much of a script writer.
The weather conditions are from darksky
What I want to create is the following:
If
'zonnescherm' is closed
Time is between 11.30 and sunset
Date is between 1 april and 30 september
'Windsnelheid Assen' <8
'UV Index Assen' >1
'Regen voorspelling Assen' <1
Then
Set 'Zonnescherm' On
If 'Zonnescherm' is On and one of the conditions changing, 'Zonnescherm' should close. (Off)
Not sure if I'm missing something.
Who can help me with creating this?
If
'UV Index Assen' >1
Then
- waaren
Re: Need help with sunscreen script
Could be something like this
-- sunProtection.lua
on = { timer = {"every 10 minutes between 11:30 and 10 minute after sunset on 1/4-30/9"}},
logging = { level = domoticz.LOG_DEBUG,
marker = "Sunscreen" },
execute = function(dz)
local sunscreen = dz.devices(###) -- replace ### by your sunscreen device IDX
local windSpeed = dz.devices(###).speed -- replace ### by your virtual wind device IDX
local UV = dz.devices(###).uv -- replace ### by your virtual UV device IDX
local rainPrediction = tonumber(dz.devices(###).state) -- replace ### by your virtual rainprediction device IDX
local OnConditionsMet = sunscreen.state == "Open" and -- Maybe you need to reverse this to ~= or to "Closed"
windSpeed < 8 and
UV > 1 and
rainPrediction < 1 and
dz.time.matchesRule("between 11:30 and sunset")
if OnConditionsMet then
sunscreen.switchOff()
sunscreen.switchOn().checkFirst()
}Debian buster, bullseye on RPI-4, Intel NUC.
drwurn
That looks good.waaren wrote: Tuesday 09 October 2018 21:10Could be something like this
-- sunProtection.lua return { on = { timer = {"every 10 minutes between 11:30 and 10 minute after sunset on 1/4-30/9"}}, logging = { level = domoticz.LOG_DEBUG, marker = "Sunscreen" }, execute = function(dz) local sunscreen = dz.devices(###) -- replace ### by your sunscreen device IDX local windSpeed = dz.devices(###).speed -- replace ### by your virtual wind device IDX local UV = dz.devices(###).uv -- replace ### by your virtual UV device IDX local rainPrediction = tonumber(dz.devices(###).state) -- replace ### by your virtual rainprediction device IDX local OnConditionsMet = sunscreen.state == "Open" and -- Maybe you need to reverse this to ~= or to "Closed" windSpeed < 8 and UV > 1 and rainPrediction < 1 and dz.time.matchesRule("between 11:30 and sunset") if OnConditionsMet then sunscreen.switchOff() else sunscreen.switchOn().checkFirst() end end }
I've spend the intire evening on this script.
timer = { 'on 1/4-30/9 between 11:30 and sunset' },
execute = function (domoticz, item)
if item.isTimer and
domoticz.devices('Test lamp').state == "On" and
domoticz.devices('UV Index Assen').uv >0 then
domoticz.devices('Dummy Zonnescherm').switchOn()
domoticz.devices('Dummy Zonnescherm').switchOff()
Also need to work out how to get a message when the sunscreen is set to off, and which variable causes it.
- waaren
Does this help ?drwurn wrote: Tuesday 09 October 2018 23:48 Also need to work out how to get a message when the sunscreen is set to off, and which variable causes it.
windSpeed < 8 and
UV > 1 and
if sunscreen.state == "Closed " then
if windSpeed >= 8 then dz.notify(sunscreen.name .. " closed because of windspeed " .. windSpeed)
elseif UV <= 1 then dz.notify(sunscreen.name .. " closed because of UV " .. UV)
elseif rainPrediction >= 1 then dz.notify(sunscreen.name .. " closed because of rainPrediction " .. rainPrediction)
else dz.notify(sunscreen.name .. " closed because of timerule " )
drwurn
I've made a dummy switch for the sunscreen for testing.
The dummy switch turned on this morning but didn't turn off after sunset or because of the UV rule
- waaren
Can you check what the On / Off equivalent of "Open" is for your sunscreen and report back ?drwurn wrote: Wednesday 10 October 2018 19:03 I've made a dummy switch for the sunscreen for testing.
What would also help is to add some log statements.
Thx
drwurn
Open = On and Close = Off.waaren wrote: Wednesday 10 October 2018 22:04Can you check what the On / Off equivalent of "Open" is for your sunscreen and report back ?drwurn wrote: Wednesday 10 October 2018 19:03 I've made a dummy switch for the sunscreen for testing.
Thx
The sunscreen isn't responding at all with the script, without the script the screen works as normal. Double checked the IDX's and they're right.
The log:
2018-10-10 22:18:00.410 Status: dzVents: Info: Sunscreen: ------ Start internal script: Zonnescherm:, trigger: every 1 minutes between 11:30 and 1 minute after 23:59 on 1/4-30/12
2018-10-10 22:18:00.446 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Dummy Zonnescherm Forum: Switch device adapter
2018-10-10 22:18:00.447 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Windsnelheid Assen: Wind device adapter
2018-10-10 22:18:00.449 Status: dzVents: Debug: Sunscreen: Processing device-adapter for UV Index Assen: UV device adapter
2018-10-10 22:18:00.450 Status: dzVents: Debug: Sunscreen: Processing device-adapter for Regen voorspelling Assen: Rain device
2018-10-10 22:18:00.450 Status: dzVents: Info: Sunscreen: ------ Finished Zonnescherm
- waaren
At line 23 there is an extra space after the word Closed that does not belong there. Can you correct that and try again ?drwurn wrote: Wednesday 10 October 2018 22:26Open = On and Close = Off.waaren wrote: Wednesday 10 October 2018 22:04Can you check what the On / Off equivalent of "Open" is for your sunscreen and report back ?drwurn wrote: Wednesday 10 October 2018 19:03 I've made a dummy switch for the sunscreen for testing.
Thx
drwurn
Removed it but still don't workwaaren wrote: Wednesday 10 October 2018 22:38At line 23 there is an extra space after the word Closed that does not belong there. Can you correct that and try again ?drwurn wrote: Wednesday 10 October 2018 22:26Open = On and Close = Off.waaren wrote: Wednesday 10 October 2018 22:04
Thx
- waaren
Re: Need help with sunscreen script [Solved]
I Sent you a PM
dendoba
And? Did you manage to get it working?
remko2000
good question: did you succeed???
