blind percentage position
megamarco83
Post by megamarco83 »
hi, i have an nodemcu where i flash espeasy and i connect 2 relays for my blind: 1relay to UP, and 1relay to DOWN
i have also connect 2 wall switch: 1 switch UP 1switch DOWN
in EspEasy rules i create a rule to identify short press or longpress (pression >= 4seconds of wall swith)
if i use shorpres the corrisponding relay is active for 1sec. if i use longpress the corresponding relay is acrived for 46sec. (46sec. = time to all open or all close the blind)
domoticz is ablo to recognize the moviment UP or DOWN if i use wall switch thanks to command inside domoticz blind switch:
http://192.168.0.154/control?cmd=event, ... N_domoticz
http://192.168.0.154/control?cmd=event, ... P_domoticz
now i want to recognize the position of the blind i have in mind to monitoring the seconds, starting from the activation of the switch. for example the idea is:
starting from all close -> i longress UP on wall swith (relay start to UP with a time of 46sec) -> after 15sec i want to stop my blind i press DOWN shortpress on the wall switch and the blind stop in that position that i choose -> script in domoticz should have counting this 15sec passed and give to domoticz that result: (15sec / 46sec ) * 100= 36% and show on the blind with percentage open 36%
if i use a shortpress wall switch -> i will activate the relay for 1sec -> send to domoticz the value 1sec -> domoticz calcolate (1sec / 46 sec) * 100 = 2% open
if i use again a shorpress from wall swith -> domoticz activate the relay for 1sec -> domoticz calcolate (1sec / 46 sec) * 100 = 2% open + 2% of previous position = 4%open
how i can implement that?
Re: blind percentage position
megamarco83 wrote: Tuesday 02 October 2018 11:07 ...I want to recognize the position of the blind i have in mind to monitoring the seconds, starting from the activation of the switch. for example the idea is:
I played a little bit with the idea.
This script uses the lastupdate.secondsAgo and state attribute of the blind to estimate the position. Script is not
complete nor failsafe but might help you in design and develop process.
local blindCheckVar = "checkBlindState"                -- type string; need to be created manually
local blindIDX      = 296                              -- idx of your blind
    on      =   {   devices   =   { blindIDX },
                    variables =   { blindCheckVar }},
    logging =   {   level     =   domoticz.LOG_DEBUG,
                    marker    =   "Blinds position"    },
    data    =   {   action    = { initial = "Open" },                  -- device.state
                    active    = { initial = 0 },                       -- information only
                    position  = { initial = 0  }},                     -- 0 = open / 100 = closed
    execute = function(dz, item )
        local maxActionTime = 46
        local blind         = dz.devices(blindIDX)
        local idleTime      = blind.lastUpdate.secondsAgo
        local function updatePersistent(action,active,position)
            dz.data.position = dz.utils.round(math.max(math.min(position,100),0)) or dz.data.position
            dz.data.active   = active or dz.data.active
            dz.data.action   = action or dz.data.action
        -- This block will be triggered by the var change and will set
        -- the position to completely Open or completely Closed when no stop Command is received
        if item.isVariable then
            if idleTime > maxActionTime then
                if dz.data.action == "Open" then
                    updatePersistent("Stopped",idleTime,0)
                elseif dz.data.action == "Closed" then
                    updatePersistent("Stopped",idleTime,100)
            return
        -- This block will do the actual calculation
        local position = dz.data.position
        if    blind.state == "Stopped"  or
            ( blind.state == "Open"     and dz.data.action == "Closed" ) or
            ( blind.state == "Closed"   and dz.data.action == "Open"   ) then
            local factor = 1
                factor = -1
            position = dz.data.position + factor * (( idleTime )  * ( 100/maxActionTime ))
        updatePersistent(blind.state,idleTime,position)
        -- Next if block will schedule an update of a uservariable that will force
        -- a trigger of this script even when no stop command is given
        if blind.state == "Open" or blind.state == "Closed" then
            local timeRemains = dz.data.position/100 * maxActionTime
            if blind.state == "Closed" then
                timeRemains = maxActionTime - timeRemains
            dz.variables(blindCheckVar).set(blind.state).afterSec(timeRemains + 3)
megamarco83
waaren wrote: Tuesday 02 October 2018 14:53
wow thanks so much!!!!
i try to adapt your code and i create this:
i create a user var as string named: "checkBlindState"
this is my blind with percentage switch, that as id=31
and this is what is inside:
blind command.jpg (31.09 KiB) Viewed 3498 times
this is your code:
local blindIDX      = 31                             -- idx of your blind
        local maxActionTime = 10  -- seconds to completly the action (10 for test)
            return
            local factor = 1
                factor = -1
i used just to test 10seconds to simulate a completly moviment of blind
so also in ESPeasy on nodemcu i changed:
shor press down wall switch = 2sec DOWN
short press UP wall switch = 2 sec UP
long press DOWN wall switch = 10 sec down
long press UP wall switch = 10 sec UP
if i press domoticz UP = 10 sec UP relay is activation
if i press domoticz DOWN = 10sec DOWN relay down activation
so all is ok, now related to the percentage:
i started to all close (domoticz 0%) then i short press wall switch UP -> 2sec activation relay UP -> i see in domoticz 40% open (why?!?!?) (the string checkBlindState is closed)
then i short press again wall switch UP-> 2sec activation relay UP -> i see again in domoticz 40% open (same as previous) (the user string checkBlindState is closed)
then i long press again wall switch UP -> 10sec activation relay UP -> i see in domoticz 100% open (the user string checkBlindState now is open)
when i short press wall switch DOWN -> 2sec activation relay DOWN -> i see again in domoticz 0% (all close) (the user string checkBlindState is closed)
when i long press wall switch DOWN -> 10sec activation relay DON -> i see in domoticz 0% (all close) (the user string checkBlindState is closed again)
i do not understand....
if it's needed this is my ESP rules:
on B_UP#Shortpress do
 if [relayp#R_UP]>0
  output,relayp,0,0
  output,relayp,1,0
  output,relayp,0,1
SendToHTTP 192.168.0.105,8085,/json.htm?type=command&param=switchlight&idx=31&switchcmd=Set%20Level&level=40
  timerset,1,2
 endif
endon
on B_UP#Longpress do
event,event_UP_domoticz
endon
on event_UP_domoticz do
 if [relayp#R_UP]>0
  output,relayp,0,0
  output,relayp,1,0
  output,relayp,0,1
  timerset,1,10   // 10 sec as test to simulate completly UP
SendToHTTP 192.168.0.105,8085,/json.htm?type=command&param=udevice&idx=31&nvalue=1&svalue=40
 endif
endon
on B_DOWN#Shortpress do
 if [relayp#R_DOWN]>0
  output,relayp,1,0
  output,relayp,0,0
  output,relayp,1,1
SendToHTTP 192.168.0.105,8085,/json.htm?type=command&param=switchlight&idx=31&switchcmd=Set%20Level&level=0
 endif
endon
on B_DOWN#Longpress do
event,event_DOWN_domoticz
endon
on event_DOWN_domoticz do
  output,relayp,1,0
  output,relayp,0,0
  output,relayp,1,1
  timerset,2,10   // 10 sec as test to simulate completly DOWN
SendToHTTP 192.168.0.105,8085,/json.htm?type=command&param=udevice&idx=31&nvalue=0&svalue=0
 endif
endon
on Rules#Timer=1 do
 output,relayp,0,0
endon
on Rules#Timer=2 do
 output,relayp,1,0
endon
where i have:
gpio15= relay UP
gpio12= relay DOWN
gpio1 = wall switch UP
gpio3 = wall switch DOWN
megamarco83 wrote: Tuesday 02 October 2018 23:15
waaren wrote: Tuesday 02 October 2018 14:53 I played a little bit with the idea.
short press down wall switch = 2sec DOWN
I do not understand....
The script is created for a Blind that return "Open", "Closed" or "Stopped" as state.
The %-age "Open" is calculated when a "Stop" command is received or when the time until max. Open or Close has passed (controlled by the afterSeconds command mode)
The script is now just to give an idea. It does not update anything else than the uservariable and dzVents persistent data.
I am a bit busy the next couple of weeks but after that I am happy to look at it again. Probably better to discuss via PM and come back here if /when we have something working. OK ?
emme
Domoticz version: latest
Post by emme »
be aware that time for rolling up could be NOT the same for rolling down... due to forces, gravity and performances of the actuator. ;)
you'd better evaluate to split timers into 2 different values
"We always done this way"
emme wrote: Wednesday 03 October 2018 8:08 be aware that time for rolling up could be NOT the same for rolling down... due to forces, gravity and performances of the actuator. ;)
Thx. Will keep that in mind
megamarco83
yes, true. i misured both time UP and DOWN and i have a difference that is only 2 sec, but you are true, if we want to generalize for other person (and i think that is very usefull for many person) is better to follow your suggestion and using 2 timers
thanks!
megamarco83
waaren wrote: Wednesday 03 October 2018 0:28
ok, no problem for me, that's fantastic
i PM you with my contact, then if we succeed i will write here, i think that could be very usefull for many users!
keep in touch, in the meanwhile i'll try to do some tests (i'm a beginner, so very very small steps contribution from my side )
thanks for your kindness as usual
DewGew
Domoticz version: V4.10618
Post by DewGew »
Any progress with this script? I need this..:)
DewGew wrote: Thursday 13 December 2018 11:38 Any progress with this script? I need this..:)
The script is ready and in use but probably not generic enough to share with a wide audience. I attach it here but I cannot give much support on it.
I will try to answer questions to clarify but will not make modifications. So use it at it is and make the necessary adjustments for your specific situation yourself.
@megamarco83 can share the detailed rules and settings necessary in the nodemcu but in short you will have to setup MQTT as communication and listen to incoming MQTT messages and set the attached relais accordingly.
Have Fun !
--[[     this scripts handles two way commmunication between domoticz and nodemcu / relais
     *** nodemcu to domoticz: nodemcu update the (type string) uservariable blindControl with an MQTT command json string like
        Publish domoticz/in,{"command":"setuservariable","idx":55,"value":"blind_1;Up;42"}     -- testJSON up
        Publish domoticz/in,{"command":"setuservariable","idx":55,"value":"blind_1;Down;2"}    -- testJSON down
         dzVents will pickup the variable and set the virtual blind accordingly
     *** domoticz to relais :  dzVents is triggered by a change (open / close / On / Off and setting a percentage with the slider )in any device with a name
                               that starts with "blind_", it will calculate the number of equivalent seconds and the direction and send that together
                               with the name of the device back to nodemcu with an MQTT command
                               the constructed OS command to send the MQTT message looks like:
        mosquitto_pub -t LM46_213/blind_1_Down -m 1
        The OS Command to send the off signal is scheduled for after n seconds using a delayed URL
         the description field of the virtual blind contain the necessary information to identify the nodemcu and the settings there.
         Layout: {"nodemcu":"LM46_213","maxUpTime":"42","maxDownTime":"36"}
        some history (last action per device and last nodemcu action will be maintained in
        dzVenst persistent data. Lay-out in  domoticzdir/scripts/dzVents/data/__data_scriptname.lua
        also in persistent data is per blind a line setting the until blocktime (in seconds from epoch)
        MQTT messages can be monitored on the CLI with mosquitto_sub -F "%U - %t - %p" -v -h <broker IP or broker DNS name> -p 1883 -t '#'
    -- active = false,
    on      =   {   devices         =   { "blind_*"  },
                    variables       =   { "blindControl" },
                    httpResponses   =   { "nodemcu_*"              }},     -- wildcard
                    marker          =   "MQTT Blindposition"    },
    data    =   {   blinds          = { initial = {}  },
                    commands        = { history = true, maxItems = 10 },
    execute = function(dz, item, info )
        _G.logMarker             = info.scriptName                  -- sets the logmarker for dz.log
        local allBlinds          = {"blind_1","blind_2","blind_3"}  -- blind names in domoticz
        local maxBlindDownTime   = 36                               -- default time in seconds for blind to go from fully open to fully closed (can be overruled in description)
        local maxBlindUpTime     = 42                               -- default time in seconds for blind to  go from fully closed to fully open (can be overruled in description)
        local control            = {}
        local entryTime          = os.date(os.time())
        local function logWrite(str,level)
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local function dumpPersist()
            for k,v in pairs(dz.data.blinds[item.name]) do
                logWrite(k .. "  ===>>> " ..tostring(v) )
            logWrite(item.name .. "; state: " .. item.state)
       -- if item.isDevice then
         --   logWrite("\n\n" .. item.name .. "; state: " .. item.state .. "\n" .. item.name .. "; level: " .. item.level .. "\n")
           -- return
        -- end
        local function blockBlind(blind,blockSeconds,blocker)
            dz.data.blinds[blind] = dz.data.blinds[blind] or {}
            dz.data.blinds[blind].blockedUntil = math.ceil(os.date(os.time() + blockSeconds+1))     -- blocked until
            dz.data.blinds[blind].blockedBy    = blocker
            dz.data.blinds[blind].blockedFrom  = os.date(os.time())
            dz.data.blinds[blind].levelFrom    = dz.devices(blind).lastLevel
            logWrite(blind .. " is blocked until " .. os.date("%X",os.time() + blockSeconds))
        local function isBlocked(blind)
            if dz.data.blinds[blind] == nil then dz.data.blinds[blind] = {} end
            dz.log("isBlocked = ".. tostring((tonumber(dz.data.blinds[blind].blockedUntil or 0)) >  tonumber(os.date(os.time()))),dz.LOG_DEBUG)
            return (tonumber(dz.data.blinds[blind].blockedUntil or 0) >  tonumber(os.date(os.time())))
        local function delta2Seconds(delta)
            local maxUpTime = control.maxUpTime or maxBlindUpTime
            local maxDownTime = control.maxDownTime or maxBlindDownTime
            if    delta > 0 then return "Up", math.abs(math.ceil(math.min((delta * maxUpTime / 100 ),maxUpTime)))  end
            return "Down" , math.abs(math.ceil(math.min((delta * maxDownTime / 100 ),maxDownTime)))
        local function keepTrack(origin,targetLevel)
            local tail, info
            if item.level  ~=  nil then info = "; level to " .. item.level .. "%"  -- when triggered by variable, there is no level
            else if bTable.s then tail = " for " .. bTable.s   .. " seconds"              -- variable contain s (seconds)
                 else tail = "; level " .. bTable.p end                            -- variable contain p (position)
                 info = ", moving " .. bTable.d .. tail
            dz.data.blinds[origin].levelTo = targetLevel
            dz.data.blinds[origin].info    = dz.data.blinds[origin].info or {}
            dz.data.blinds[origin].info[dz.data.blinds[origin].direction] = dz.time.rawDate .. " " .. dz.time.rawTime .. info
        local function newLevel(direction, duration, oldLevel, screenInversion)
            logWrite("1 ---------")
            logWrite(tostring(inverted))
            local factor   = 100 *  screenInversion
            local maxTime  = control.maxUpTime or maxBlindUpTime
            if direction  ~= "Down" and not inverted then
                factor = -1 * factor
                maxTime = control.maxUpTime or maxBlindDownTime     -- time in seconds for blind to go from fully closed to fully open
            elseif direction ~= "Up" and inverted then
                 maxTime = control.maxDownTime or maxBlindDownTime     -- time in seconds for blind to go from fully closed to fully open
            return dz.utils.round(math.min(math.max(oldLevel + ( factor * duration / maxTime ),0),100))
        local function delayedURL(callback,seconds)
            callback = "nodemcu_" ..  callback
            local url = dz.settings['Domoticz url'] .. "/json.htm?type=command&param=addlogmessage&message=" ..
                        callback ..  "%20Scheduled%20for%20after%20" .. seconds .. "%20seconds."
            dz.openURL  ({ url      = url , method   = "GET", callback = callback,}).afterSec(seconds)
        local function makeTableFromVar(str)
            local bTable = {}
            bTable.n = item.value:match("[a-zA-Z0-9_]+")       -- blind name
            bTable.d = item.value:match(";[A-Z][a-z]+"):sub(2)      -- direction
            local seconds = item.value:gsub(bTable.n .. ";" .. bTable.d .. ";","")
            bTable.s = tonumber( seconds )
            logWrite("Seconds: " .. bTable.s)
            return bTable
        local function osExecute(cmd)
            logWrite("command for osEexecute: ".. cmd)
            local fileHandle     = assert(io.popen(cmd, 'r'))
            local commandOutput  = assert(fileHandle:read('*a'))
            local returnTable    = {fileHandle:close()}
            logWrite("commandOutput: " .. commandOutput)
            logWrite("returncode   : " .. returnTable[3])
           return commandOutput,returnTable[3]            -- rc[3] contains returnCode
        local function sendMQTT(nodemcu,blind,direction,seconds)
            local seconds   = tonumber(seconds) or 0
            local baseMQTT  = "mosquitto_pub -t " .. nodemcu .. "/" .. blind .. "_" .. direction .. " -m "
            if seconds == 0 then
                osExecute(baseMQTT .. "0" )
            elseif seconds >= 1 then
                osExecute(baseMQTT .. "1")
                delayedURL(blind,seconds)
                osExecute("sleep 0.5")
                osExecute(baseMQTT .. "0")
            dz.data.blinds[blind].nodemcu   = nodemcu
            dz.data.blinds[blind].direction = direction
        local function initPersistentBlind(blind)
        local function Response2Parms(str)
            str = str:gsub("nodemcu_","")
            return dz.data.blinds[str].nodemcu, str, dz.data.blinds[str].direction
        local function setLevelAfterInterrupt(blind)
            -- When a blind action is interrupted, the new level should take this into acount
            local deltaLevel = dz.data.blinds[blind].levelFrom - dz.data.blinds[blind].levelTo
            local deltaTime  = dz.data.blinds[blind].blockedUntil - dz.data.blinds[blind].blockedFrom
            local newTime    = entryTime - dz.data.blinds[blind].blockedFrom
            local newLevel   = dz.utils.round(dz.data.blinds[blind].levelFrom - newTime / deltaTime *  deltaLevel )
            dz.devices(blind).dimTo(newLevel).silent()
            dz.data.blinds[blind].blockedUntil = os.date(os.time())  -- unblock blind
            dz.data.blinds[blind].levelTo = newLevel
        local function isCut(silent)
            local closed = 99
            local opened = 1
            if item.state == "Closed" then
               item.dimTo(closed)
               return true
            elseif item.state == "Open" then
               item.dimTo(opened)
               return true
            elseif item.level == 100  then
                if inverted then
                    item.dimTo(opened)
                    item.dimTo(closed)
                return true
            elseif item.level == 0 then
                if inverted then
                    item.dimTo(closed)
                    item.dimTo(opened)
                return true
            return false
        local function handleBlind(blind)
            control = dz.utils.fromJSON(dz.devices(blind).description)
            local targetLevel
            if isBlocked(blind) then
                dz.log("Blind ".. blind .. " is active; Stopping now",dz.LOG_DEBUG)
                sendMQTT(control.nodemcu,blind,"Up",0)
                sendMQTT(control.nodemcu,blind,"Down",0)
                return
                blockBlind(blind,bTable.s,control.nodemcu)
            local factor = 1
            if inverted then factor = -1 end
            targetLevel = newLevel(bTable.d,bTable.s,dz.devices(blind).level,factor)
            dz.devices(blind).dimTo(targetLevel).silent()
            sendMQTT(control.nodemcu,blind,bTable.d,bTable.s)
            keepTrack(blind,targetLevel)
        local function dzHandleBlind(blindName)
            local blind = dz.devices(blindName)
            local control = dz.utils.fromJSON(blind.description)
            local direction
            local delta     = control.maxUpTime or maxBlindUpTime
            if not(isBlocked(blindName)) then                                       -- too Quick
                if isCut() then
                    dumpPersist()
                    return
                if  dz.data.blinds[blindName].levelTo == 1 then
                        direction, delta = delta2Seconds(blind.lastLevel - 1)
                        direction = "Up"
                elseif dz.data.blinds[blindName].levelTo == 99 then
                        direction, delta = delta2Seconds(blind.lastLevel - 99)
                        direction = "Down"
                       direction, delta = delta2Seconds(blind.lastLevel - blind.level)
                dumpPersist()
                logWrite("lastLevel: " .. blind.lastLevel)
                logWrite("level: " .. blind.level)
                logWrite("direction: " .. direction)
                logWrite("delta: " .. delta)
                sendMQTT(control.nodemcu,blindName,direction,delta)
                blockBlind(blindName,delta,"dzVents")
                dz.log("Not enough time (still blocked) ...", dz.LOG_DEBUG)
                blind.dimTo(blind.lastLevel).silent()
                return
            keepTrack(blind.name,blind.level)        -- We are here because blind was set in domoticz so blind.level is targetLevel
        --- Main code
        if item.isHTTPResponse then                                  -- Used for switching relais off only
            local nodemcu,blind,direction = Response2Parms(item.trigger)
            sendMQTT(nodemcu,blind,direction,0)
        elseif item.isVariable then                                  -- triggered by nodemcu
            bTable = makeTableFromVar(item.value)
            inverted = dz.devices(bTable.n).switchType ==  "Blinds Percentage Inverted"
            if bTable.n ~= "ALLBLINDS" then
                blinds2Handle = {bTable.n}
                blinds2Handle = allBlinds
            for i = 1,#blinds2Handle do
                handleBlind(blinds2Handle[i])
                logWrite(blinds2Handle[i])
        else                                                        -- triggered by device
            local inverted = item.switchType ==  "Blinds Percentage Inverted"
            if item.name == "blind_Master" then
                if isCut() then return end
                for i = 1,#allBlinds do
                    dz.devices(allBlinds[i]).dimTo(math.max(math.min(item.level,99),1))
                if isCut() then
                    return
                dzHandleBlind(item.name)
