Variable doesn't trigger script
Posted: Wednesday 26 September 2018 11:05
by Dirk79
Hi All,
After a few days of searching I hope you can help me. I've got the following time script that updates a uservariable 'Night' with True of False:
--Haal de huidige tijd op
timenow = os.date("*t")
minutesnow = timenow.min + timenow.hour * 60
--Vergelijk de tijd met zonsondergang - 30 minuten en zet variabele Nacht op True als ze overeenkomen
if (minutesnow == timeofday['SunsetInMinutes'] - 30) then
commandArray['Variable:Nacht']='True'
--Vergelijk de tijd met zonsopgang - 0 minuten en zet variabele Nacht op False als ze overeenkomen
if (minutesnow == timeofday['SunriseInMinutes'] - 0) then
commandArray['Variable:Nacht']='False'
This works fine. The following uservariable script should be triggered when 'Night' is updated. The problem is that it isn't triggered:
if (uservariables['Thuis'] == 'True' and uservariables['Nacht'] == 'True') then
commandArray['Lampen bij bank']='On'
commandArray['Lamp bij tv']='On'
commandArray['Vensterbank']='On'
if uservariables['Thuis'] == 'False' then
commandArray['Lampen bij bank']='Off'
commandArray['Lamp bij tv']='Off'
commandArray['Vensterbank']='Off'
if uservariables['Nacht'] == 'False' then
The other variable 'Home' is updated via API/JSON. When 'Night' is True all is fine and lights switch on.
Do you have ideas what might be the problem?
Re: Variable doesn't trigger script
Posted: Wednesday 26 September 2018 11:52
by jvdz
There use to be a remark in the Wiki about this, so don't know whether it has changed, but it use to be the case that UserVariable events would ONLY trigger when the uservariable was updated by a JSON call and not by a Commandarray[] action.
The remark isn't there anymore so maybe it was updated in a recent version?
My scripts still use a http request to update the variable with a JSON call to trigger the event system.
Jos
Posted: Thursday 27 September 2018 8:55
by Dirk79
Thank you! Most likely that only JSON will trigger uservariable scripts then.
How did you write your http request in the script?
I've tried different 'versions' of the following line:
commandArray['OpenURL']="http://127.0.0.1:8080/json.htm?param=updateuservariable&type=command&vname=Nacht&vtype=2&vvalue=False"
But keep getting errors:
2018-09-26 16:05:56.788 Error: Error opening url: http://127.0.0.1:8080/json.htm?param=updateuservariable&type=command&vname=Nacht&vtype=2&vvalue=False
Posted: Thursday 27 September 2018 9:07
by emme
look into the settings if 127.0.0.1 is in the IP whitelist
try also to open it into your browser (replacing 127.0.0.1 with the dz box ip) and post the error
Posted: Thursday 27 September 2018 9:46
by jvdz
Try this variant without the http:// prefix:
commandArray['OpenURL'] = "127.0.0.1:8080/json.htm?type=command&param=updateuservariable&vname=Nacht&vtype=2&vvalue=False"
Jos
Posted: Thursday 27 September 2018 10:51
by waaren
jvdz wrote: Wednesday 26 September 2018 11:52 There use to be a remark in the Wiki about this, so don't know whether it has changed, but it use to be the case that UserVariable events would ONLY trigger when the uservariable was updated by a JSON call and not by a Commandarray[] action.
Jos
I just tested this with a Lua and with a dzVents script. The Lua script (using commandArray) does not trigger an event. The dzVents script does.
Posted: Thursday 27 September 2018 11:13
by jvdz
waaren wrote: Thursday 27 September 2018 10:51 I just tested this with a Lua and with a dzVents script. The Lua script (using commandArray) does not trigger an event. The dzVents script does.
That is pretty strange that we aren't worried about an indefinite trigger loop in dzVents and still are with LUA.
I've already mentioned this before that I never understood why this "safeguard" was build in for uservariables. It is just a nuisance having to resort to a JSON call to update a uservariable and want to trigger subsequent events.
I vote for changing this behavior. :)
Jos
Posted: Thursday 27 September 2018 11:34
by Dirk79
Thanks for all the input guys! Whitelisting the IP did the trick.
Posted: Friday 17 May 2019 11:02
by OedzesG
Hallo everyone!
Anny news on this?
I have a Plex script (python) witch updates my user variable, but when it changes (for example: Movie Pause) it is not triggering DzVents.
Posted: Friday 17 May 2019 14:29
by waaren
OedzesG wrote: Friday 17 May 2019 11:02 I have a Plex script (python) witch updates my user variable, but when it changes (for example: Movie Pause) it is not triggering DzVents.
Can you change the script is such a way that it updates a virtual domoticz device ? That could trigger the dzVents script.
One way would be to use a selector switch and set it to a pre-defined level. Or just update the variable and switchOn a switch. dzVents would be triggered by the switch and read the value of the var in the body of the script.
Posted: Friday 17 May 2019 17:24
by OedzesG
The script is updating a text device, but i dont know if i can get my trigger out of it!
Sorry, im not an expert in python cripting.
Exapple:
No media.JPG (14.65 KiB) Viewed 3117 times
Posted: Friday 17 May 2019 17:27
by waaren
OedzesG wrote: Friday 17 May 2019 17:24 The script is updating a text device, but i dont know if i can get my trigger out of it!
Can you please share the Python and dzVents scripts (and please use code tags </>) related to this question here ?
Posted: Friday 17 May 2019 17:32
by OedzesG
!/usr/bin/python
# -*- coding: utf-8 -*-
from __future__ import division
import traceback
import sys
import datetime
import time
import os
import urllib, urllib2, hashlib,subprocess
from xml.etree import ElementTree as ET
ErrorCount = 0
#general Script settings
plex_Interval                 = 4     # Poll Interval. The Plex Server updates the session status every 10 seconds. Leave at 5 to not mis any state change.
plex_ShowPlayProgress         = True
plex_AutoClearPlayLog         = True  # Should be enabled when showing Play Progress
plex_AutoCreateUserVariables  = True  # Automatically create a user variable for each Client listed under dom_PlexPlayers
plex_ViewOffsetTimeout        = 20    # In seconds.
plex_MaxErrorCount            = 3     # number of consecutive errors until Plex is considered Offline
#RunState values (for user variable)
plex_ServerOffline    = -1
plex_Idle             = 0
plex_Video_Playing    = 1
plex_Video_Paused     = 2
plex_Video_Stopped    = 3
plex_Video_Buffering  = 4
plex_Audio_Playing    = 11
plex_Audio_Paused     = 12
plex_Audio_Stopped    = 13
plex_Audio_Buffering  = 14
#Plex Server Settings
plexIP                 = '192.168.2.142'
plexPort               = '32400'          # (default port = 32400)
plexToken              = ''
#domoticz settings
domoticz_host          = '192.168.2.148'
domoticz_port          = '8080'
domoticz_url           = 'json.htm'
#Translation Array - It's also possible to specify custom search strings. Place them at the beginning of the array.
transl_search 	= ['Playing','Stopped','Buffering','Paused','Video','Movie','Episode','Clip','Audio','Slideshow']
transl_replace 	= ['','','','','','','','','',''] #place replacement string on the same index as the search string. empty strings are not processed.
#Plex Players Settings - This script handles multiple players
dom_PlexPlayers        = ['OpenELEC-PHT','Jasper-TPC'] #Players not on this list will be ignored
dom_PlexPlayInfo_ID    = ['24','30']
dom_PlexPlayState_ID   = ['','']          # Name of User Variable. Is overwrriten when plex_AutoCreateUserVariables=True
#Various Variables
plex_TimeLastUpdate    = ""
plex_LastOffsetUpdate  = []  # of loop iterations
plex_LastOffset        = []
plex_PreviousState     = []
plex_PreviousTitle     = []
plex_AlreadyIdle       = []
#building url
requestURL = 'http://'+ plexIP + ':' + plexPort + '/status/sessions?X-Plex-Token=' + plexToken
#lock file
pidfile = sys.argv[0] + '_' + plexIP + '.pid'
if os.path.isfile( pidfile ):
  if (time.time() - os.path.getmtime(pidfile)) < (float(5) * 4):
    print datetime.datetime.now().strftime("%H:%M:%S") + "- script seems to be still running, exiting"
    print datetime.datetime.now().strftime("%H:%M:%S") + "- If this is not correct, please delete file " + pidfile
    sys.exit(0)
  else:
    print datetime.datetime.now().strftime("%H:%M:%S") + "- Seems to be an old file, ignoring."
else:
  open(pidfile, 'w').close()
#Ensure equal list sizes
while len(dom_PlexPlayInfo_ID)<len(dom_PlexPlayers):
  dom_PlexPlayInfo_ID.append('-1')
while len(dom_PlexPlayState_ID)<len(dom_PlexPlayers):
  dom_PlexPlayState_ID.append('-1')
while len(plex_LastOffsetUpdate)<len(dom_PlexPlayers):
  plex_LastOffsetUpdate.append(1)
while len(plex_LastOffset)<len(dom_PlexPlayers):
  plex_LastOffset.append(1)
while len(plex_PreviousState)<len(dom_PlexPlayers):
  plex_PreviousState.append('0')
while len(plex_PreviousTitle)<len(dom_PlexPlayers):
  plex_PreviousTitle.append('0')
while len(plex_AlreadyIdle)<len(dom_PlexPlayers):
  plex_AlreadyIdle.append(False)
while len(transl_replace)<len(transl_search):
  transl_replace.append('')
statusValue = 0
# create play Status user variable for each client
if plex_AutoCreateUserVariables:
  for client in dom_PlexPlayers:
    try:
      name = "PLEX STATUS [" + client + "]"
      url = "http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=saveuservariable&vname=" + name + "&vtype=Integer&vvalue=" + str(plex_Idle)
      url = urllib.quote(url.encode('utf-8'), safe="%/:=&?~#+!$,;'@()*[]'")
      urllib2.urlopen(url , timeout = 5)
      idx = dom_PlexPlayers.index(client)
      dom_PlexPlayState_ID[idx] = name
    except Exception:
      print 'Connection Error'
def translate(playstring):
  returnstring = playstring
  for idx in range(0, len(transl_search)):
    if transl_replace[idx]!='':
      returnstring = returnstring.replace(transl_search[idx],transl_replace[idx])
  print returnstring;
  return returnstring;
while 1==1:
  try:
    #call session url
    test = urllib2.urlopen(requestURL,timeout = 5).read()
    root = ET.XML(test)
    ProcessedIDs=[]
    #Video Support
    for video in root.findall('Video'):
      # Get Attributes for each player
      player = video.find('Player').attrib['title']
      state = video.find('Player').attrib['state']
      parenttitle = video.get('grandparentTitle')
      videotitle = video.get('title')
      videotype = video.get('type')
      videoduration = video.get('duration')
      viewOffset = video.get('viewOffset')
      PlayProgress=''
      if plex_ShowPlayProgress and videoduration is not None:
        durTotalSeconds = long(long(videoduration) / 1000)
        durSeconds = int(durTotalSeconds % 60)
        durTotalSeconds /=60
        durMinutes = int(durTotalSeconds % 60)
        durHours = int(durTotalSeconds)
        if viewOffset is not None:
          runTotalSeconds = long(long(viewOffset) / 1000)
          runSeconds = int(runTotalSeconds % 60)
          runTotalSeconds /=60
          runMinutes = int(runTotalSeconds % 60)
          runHours = int(runTotalSeconds)
        else:
          runSeconds=0
          runMinutes=0
          runHours=0
        PlayProgress= ' (' + str(runHours) + ':' + str(runMinutes).zfill(2) + ':' + str(runSeconds).zfill(2) + '/' + str(durHours) + ':' + str(durMinutes).zfill(2) + ':' + str(durSeconds).zfill(2) + ')'
      else:
        PlayProgress=""
      PlayString = ""
      StateChange = 0
      PlayerID = dom_PlexPlayers.index(player) if player in dom_PlexPlayers else -1
      if PlayerID >= 0:  #only process players that are on the list
        try:
          # Check if there is progress
          if (viewOffset>plex_LastOffset[PlayerID] and state=="playing") or  (videotitle!=plex_PreviousTitle[PlayerID]):
            plex_LastOffsetUpdate[PlayerID] = 0
          elif viewOffset == plex_LastOffset[PlayerID]:
            plex_LastOffsetUpdate[PlayerID] += 1
          if plex_LastOffsetUpdate[PlayerID] >= int(plex_ViewOffsetTimeout/plex_Interval) and state == "playing" and viewOffset is not None:
            state = "stopped"
          if plex_PreviousState[PlayerID] == state:
            StateChange = 0
          else:
            StateChange = 1
            plex_PreviousState[PlayerID]=state
          plex_PreviousTitle[PlayerID] = videotitle
          if videotype == 'movie':
            PlayString = state.capitalize() + " Movie: " + videotitle + PlayProgress
          elif videotype =='episode':
            PlayString = state.capitalize() + " Episode: " + parenttitle + " - " + videotitle + PlayProgress
          elif videotype =='clip':
            PlayString = state.capitalize() + " Clip: " + parenttitle + " - " + videotitle + PlayProgress
          else:
            PlayString = state.capitalize() + "Video " + ": " + videotitle + PlayProgress
          #uploading log message to domoticz
          PlayString = urllib.quote(translate(PlayString).encode("utf-8"))
          if StateChange == 1:
            url = "http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command&param=addlogmessage&message=" + PlayString
            plex_AlreadyIdle[PlayerID] = False
          #uploading values to domoticz
          url = "http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command&param=udevice&idx=" + dom_PlexPlayInfo_ID[PlayerID] + "&nvalue=0&svalue=" + PlayString
          if state == "playing":
            statusValue = plex_Video_Playing
          elif state == "paused":
            statusValue = plex_Video_Paused
          elif state == "stopped":
            statusValue = plex_Video_Stopped
          elif state =="buffering":
            statusValue = plex_Video_Buffering
          if plex_LastOffset[PlayerID] != viewOffset or state == "stopped":
            if plex_AutoClearPlayLog:
              url = "http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command&param=clearlightlog&idx=" + dom_PlexPlayInfo_ID[PlayerID]
            url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command&param=updateuservariable&vname=" + dom_PlexPlayState_ID[PlayerID] + "&vtype=integer&vvalue=" + str(statusValue))
            urllib2.urlopen(url,timeout = 5)
          plex_LastOffset[PlayerID] = viewOffset
          ProcessedIDs.append(PlayerID)
        except Exception,e:
          print 'IDLE'
          print e
          print traceback.print_exc()
          url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=udevice&idx=" + dom_PlexPlayInfo_ID[PlayerID] + "&nvalue=0&svalue=No%20Media%20Playing")
          pass
    #Audio Support
    for audio in root.findall('Track'):
      player = audio.find('Player').attrib['title']
      state = audio.find('Player').attrib['state']
      parenttitle = "Unknown"
      parenttitle = audio.get('grandparentTitle')
      audiotitle = audio.get('title')
      audioduration = audio.get('duration')
      viewOffset = audio.get('viewOffset')
      PlayProgress=''
      if plex_ShowPlayProgress:
        durTotalSeconds = long(long(audioduration) / 1000)
        else:
          runSeconds=0
          runMinutes=0
          runHours=0
      else:
        PlayProgress=""
      PlayString = ""
      StateChange = 0
        try:
          if (viewOffset>plex_LastOffset[PlayerID] and state=="playing") or  (audiotitle!=plex_PreviousTitle[PlayerID]):
          if plex_LastOffsetUpdate[PlayerID] >= int(plex_ViewOffsetTimeout/plex_Interval) and state == "playing":
            state = "stopped"
            StateChange = 0
          else:
            StateChange = 1
          plex_PreviousTitle[PlayerID] = audiotitle
          PlayString = state.capitalize() + " Audio: " + parenttitle + " - " + audiotitle + PlayProgress
          PlayString = urllib.quote(translate(PlayString).encode('utf-8'))
            statusValue = plex_Audio_Playing
            statusValue = plex_Audio_Paused
            statusValue = plex_Audio_Stopped
            statusValue = plex_Audio_Buffering
          if plex_LastOffset[PlayerID] != viewOffset:
        except Exception,e:
          print 'IDLE'
          print e
          pass
    for photo in root.findall('Photo'):
      player = photo.find('Player').attrib['title']
      state = photo.find('Player').attrib['state']
      parenttitle = photo.get('parentTitle')
      phototitle = photo.get('title')
      PlayString = ""
      StateChange = 0
        try:
            StateChange = 0
          else:
            StateChange = 1
          plex_PreviousTitle[PlayerID] = phototitle
          PlayString = state.capitalize() + " Slideshow: " + parenttitle + " - " + phototitle
        except Exception,e:
          print 'IDLE'
          pass
    #set play status to IDLE
    for i in range(0, len(dom_PlexPlayers)):
      if i not in ProcessedIDs and plex_AlreadyIdle[i] == False:
        plex_PreviousState[i]=-2
        print 'No Media Playing'
        url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=udevice&idx=" + dom_PlexPlayInfo_ID[i] + "&nvalue=0&svalue=No%20Media%20Playing")
        url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=updateuservariable&vname=" + dom_PlexPlayState_ID[i] + "&vtype=integer&vvalue=0")
        plex_AlreadyIdle[i] = True
    ErrorCount = 0
  except Exception,e:
   try:
      ErrorCount+=1
      if ErrorCount == plex_MaxErrorCount:
         print 'PLEX OFFLINE'
            if plex_AlreadyIdle[i] == False:
               url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command&param=updateuservariable&vname=" + dom_PlexPlayState_ID[i] + "&vtype=integer&vvalue=" + str(plex_ServerOffline))
               pass
   except Exception,e:
  time.sleep (plex_Interval)
Posted: Friday 17 May 2019 17:34
by OedzesG
And this is the script..
I am just started with domoticz, so hope the script is oke!?
Posted: Friday 17 May 2019 17:48
by waaren
OedzesG wrote: Friday 17 May 2019 17:34 And this is the script..
Please use code tags ( use </> button in the edit window and put your code between the tags )
Posted: Friday 17 May 2019 18:00
by waaren
Can you try this ?
        on = {  devices = { 'Plex_Status_Chrome' }},
    logging =   {   level   =   domoticz.LOG_DEBUG,
                    marker  =   "plexTest" },
    execute = function(dz)
        plexVar = dz.variables('PLEX STATUS [Chrome]')
        testSwitch = dz.devices('test1')
        if tostring(plexVar.value) == '1' then
            testSwitch.switchOn()
        elseif tostring(plexVar.value) == '2' then
            testSwitch.switchOff()
        dz.log('Value of vatiable ' .. plexVar.name .. " is " .. plexVar.value,dz.log_DEBUG )
Posted: Friday 17 May 2019 18:18
by OedzesG
IT WORKS !!! amazing!!!
But.......... the script is updating every X seconds, so my log is going crazy right now.
Posted: Friday 17 May 2019 19:35
by waaren
OedzesG wrote: Friday 17 May 2019 18:18 But.......... the script is updating every X seconds, so my log is going crazy right now.
It only means that the text sensor is updated (very) frequently. If you don't wan't to fill your log and only send a command to the switch when it should change state then adjust script to
    logging =   {   level   =   domoticz.LOG_ERROR,
            testSwitch.switchOn().checkFirst()
            testSwitch.switchOff().checkFirst()
        -- dz.log('Value of vatiable ' .. plexVar.name .. " is " .. plexVar.value,dz.log_DEBUG )
Posted: Thursday 20 October 2022 19:09
by Soulwax62
Just to up the topic, just tested on very last version (2022.1) still, lua's scripts updating user variables doesn't trigger a change event.
So problem is still there on this version.
I will implement the json API response from here.
Thank you for the workaround.
Soulwax62
