Variable doesn't trigger script
Dirk79
- Domoticz version: 4.9700
Hi All,
After a few days of searching I hope you can help me. I've got the following time script that updates a uservariable 'Night' with True of False:
--Haal de huidige tijd op
timenow = os.date("*t")
minutesnow = timenow.min + timenow.hour * 60
--Vergelijk de tijd met zonsondergang - 30 minuten en zet variabele Nacht op True als ze overeenkomen
if (minutesnow == timeofday['SunsetInMinutes'] - 30) then
commandArray['Variable:Nacht']='True'
--Vergelijk de tijd met zonsopgang - 0 minuten en zet variabele Nacht op False als ze overeenkomen
if (minutesnow == timeofday['SunriseInMinutes'] - 0) then
commandArray['Variable:Nacht']='False'
This works fine. The following uservariable script should be triggered when 'Night' is updated. The problem is that it isn't triggered:
if (uservariables['Thuis'] == 'True' and uservariables['Nacht'] == 'True') then
commandArray['Lampen bij bank']='On'
commandArray['Lamp bij tv']='On'
commandArray['Vensterbank']='On'
if uservariables['Thuis'] == 'False' then
commandArray['Lampen bij bank']='Off'
commandArray['Lamp bij tv']='Off'
commandArray['Vensterbank']='Off'
if uservariables['Nacht'] == 'False' then
The other variable 'Home' is updated via API/JSON. When 'Night' is True all is fine and lights switch on.
Do you have ideas what might be the problem?
- jvdz
- Domoticz version: 4.107
Re: Variable doesn't trigger script
There use to be a remark in the Wiki about this, so don't know whether it has changed, but it use to be the case that UserVariable events would ONLY trigger when the uservariable was updated by a JSON call and not by a Commandarray[] action.
The remark isn't there anymore so maybe it was updated in a recent version?
My scripts still use a http request to update the variable with a JSON call to trigger the event system.
Jos
Jos
Dirk79
Thank you! Most likely that only JSON will trigger uservariable scripts then.
How did you write your http request in the script?
I've tried different 'versions' of the following line:
But keep getting errors:
commandArray['OpenURL']="http://127.0.0.1:8080/json.htm?param=updateuservariable&type=command&vname=Nacht&vtype=2&vvalue=False"Code: Select all
2018-09-26 16:05:56.788 Error: Error opening url: http://127.0.0.1:8080/json.htm?param=updateuservariable&type=command&vname=Nacht&vtype=2&vvalue=False- emme
- Domoticz version: latest
look into the settings if 127.0.0.1 is in the IP whitelist
try also to open it into your browser (replacing 127.0.0.1 with the dz box ip) and post the error
"We always done this way"
- jvdz
Try this variant without the http:// prefix:
Jos
commandArray['OpenURL'] = "127.0.0.1:8080/json.htm?type=command¶m=updateuservariable&vname=Nacht&vtype=2&vvalue=False"
- waaren
I just tested this with a Lua and with a dzVents script. The Lua script (using commandArray) does not trigger an event. The dzVents script does.jvdz wrote: Wednesday 26 September 2018 11:52 There use to be a remark in the Wiki about this, so don't know whether it has changed, but it use to be the case that UserVariable events would ONLY trigger when the uservariable was updated by a JSON call and not by a Commandarray[] action.
Jos
- jvdz
That is pretty strange that we aren't worried about an indefinite trigger loop in dzVents and still are with LUA.waaren wrote: Thursday 27 September 2018 10:51 I just tested this with a Lua and with a dzVents script. The Lua script (using commandArray) does not trigger an event. The dzVents script does.
I've already mentioned this before that I never understood why this "safeguard" was build in for uservariables. It is just a nuisance having to resort to a JSON call to update a uservariable and want to trigger subsequent events.
I vote for changing this behavior.
Jos
Dirk79
Thanks for all the input guys! Whitelisting the IP did the trick.
OedzesG
Hallo everyone!
Anny news on this?
I have a Plex script (python) witch updates my user variable, but when it changes (for example: Movie Pause) it is not triggering DzVents.
Anny news on this?
- waaren
Can you change the script is such a way that it updates a virtual domoticz device ? That could trigger the dzVents script.OedzesG wrote: Friday 17 May 2019 11:02 I have a Plex script (python) witch updates my user variable, but when it changes (for example: Movie Pause) it is not triggering DzVents.
One way would be to use a selector switch and set it to a pre-defined level. Or just update the variable and switchOn a switch. dzVents would be triggered by the switch and read the value of the var in the body of the script.
OedzesG
The script is updating a text device, but i dont know if i can get my trigger out of it!
Sorry, im not an expert in python cripting.
Exapple:
Exapple:
- waaren
Can you please share the Python and dzVents scripts (and please use code tags </>) related to this question here ?OedzesG wrote: Friday 17 May 2019 17:24 The script is updating a text device, but i dont know if i can get my trigger out of it!
OedzesG
- Spoiler: show
OedzesG
And this is the script..
I am just started with domoticz, so hope the script is oke!?
- waaren
Please use code tags ( use </> button in the edit window and put your code between the tags )OedzesG wrote: Friday 17 May 2019 17:34 And this is the script..
- waaren
Can you try this ?OedzesG wrote: Friday 17 May 2019 17:34 And this is the script..
on = { devices = { 'Plex_Status_Chrome' }},
logging = { level = domoticz.LOG_DEBUG,
marker = "plexTest" },
execute = function(dz)
plexVar = dz.variables('PLEX STATUS [Chrome]')
testSwitch = dz.devices('test1')
if tostring(plexVar.value) == '1' then
testSwitch.switchOn()
elseif tostring(plexVar.value) == '2' then
testSwitch.switchOff()
dz.log('Value of vatiable ' .. plexVar.name .. " is " .. plexVar.value,dz.log_DEBUG )
OedzesG
IT WORKS !!! amazing!!!
But.......... the script is updating every X seconds, so my log is going crazy right now.
- waaren
It only means that the text sensor is updated (very) frequently. If you don't wan't to fill your log and only send a command to the switch when it should change state then adjust script toOedzesG wrote: Friday 17 May 2019 18:18 But.......... the script is updating every X seconds, so my log is going crazy right now.
logging = { level = domoticz.LOG_ERROR,
testSwitch.switchOn().checkFirst()
testSwitch.switchOff().checkFirst()
-- dz.log('Value of vatiable ' .. plexVar.name .. " is " .. plexVar.value,dz.log_DEBUG )
}Debian buster, bullseye on RPI-4, Intel NUC.
Just to up the topic, just tested on very last version (2022.1) still, lua's scripts updating user variables doesn't trigger a change event.
So problem is still there on this version.
I will implement the json API response from here.
Thank you for the workaround.
Soulwax62
Soulwax62
