Does anyone have any suggestions for a temperature probe to monitor an aquarium?
Mine is cooled by fans which I have replaced with quiet ones, but that still make more noise than I would like. I can turn them off but then on hot days the tank gets too hot so what would be perfect is a 433 temperature probe (that goes in the water) to read the water temp and then an inline switch so I can get Domoticz to monitor the temp and then turn the fans on and off accordingly.
As the switches seem so cheap (not tried one yet though) I could put one on each of the fans and have them ramp up and down, but first things first, I need to be able to read the temp.
Any suggestions? Something like the one I use for the BBQ would seem to be good if it could be read by RFXCom.
Hardware suggestions for aquarium temperature probe
- Target OS: -
Re: Hardware suggestions for aquarium temperature probe
the FT007TP, TFA 30.3177 or WSP320 can be used.
https://www.amazon.co.uk/FT007TP-Wirele ... B00HRW2DWM
https://www.weerstationkopen.nl/accesso ... atersensor
RFX-433, RFX-433EMC, RFX-868
Thank you!b_weijenberg wrote: ↑Friday 24 August 2018 9:07 the FT007TP, TFA 30.3177 or WSP320 can be used.
