Page 1 of 2
Capacitive Soil Moisture Sensor Wemos ESPeasy
Posted: Monday 09 July 2018 17:14
by JHO01
Finally got the capacitive soil moisture sensor working in Domoticz
Hardware:
-capacitive soil moisture sensor, does not corrode (Aliexpress)
-Wemos D1 Mini
-connect moisture sensor VCC=>5V (Wemos), GND=>G (Wemos), AUDT=>A0 (Wemos)
Software steps:
Domoticz:
-Create Virtual Sensor, Leaf Wetness (because I like the little green icon); note IDX (in my case 1883)
Wemos:
-Flash Wemos with ESPeasy
ESPEasy:
-Config: Connect to your wifi network
-Controllers: Connect to your Domoticz HTTP
-Devices: add Analog input - internal, !st GPIO-14 (D5) enabled,
Do
NOT enable send to Controler.
Memorize Name sensor (in my case Soil) and # name of Values (in my case Analog)
Add formula: (840-%value%)/425*100 (The A0 value is varying between 840-425, Dry-Wet)
Submit
-Tools, advanced, check rules, Submit
-Rules: add
on Soil#Analog do
SendToHTTP,192.168.2.30,8080,/json.htm?param=udevice&type=command&idx=1883&nvalue=[Soil#Analog]
endon
Submit.
Now the number below the Leaf Wetness icon is showing the moisture percentage
Done
Re: Capacitive Soil Moisture Sensor Wemos ESPeasy
Posted: Friday 27 July 2018 9:25
by JHO01
Next challenge is to make the capacitive moisture sensor water proof. Have a look at my banana collection
1) cut out some plastic of the connector and clamp and solder a telephone wire:
2) Use a 2 cm diameter hose
3) Fill up the inside with silicone
- 1.jpg (29.39 KiB) Viewed 18881 times
- 2.jpg (22.71 KiB) Viewed 18881 times
- 3.jpg (35.07 KiB) Viewed 18881 times
Posted: Saturday 20 October 2018 21:15
by misko903
Thank you, I will try it.
Wemos itself is somewhere in the waterproof box together with power adapter?
Posted: Tuesday 23 October 2018 20:38
by JHO01
Posted: Friday 16 November 2018 22:48
by misko903
Thanks for sharing, really great idea, and it is working out of the box!
the basic parts are working, yeah!
now i want to integrate it into something like this:
maybe i can add some more sensors to it?
Posted: Saturday 17 November 2018 22:18
by misko903
I have inverted the formula, to correspond the Soil Moisture sensor values in Domoticz (using theme Aurora)
00 - 09 ==> "saturated
10 - 19 ==> "adequately wet"
20 - 59 ==> "irrigation advice"
60 - 99 ==> "irrigation"
> 99 ==> "Dangerously dry"
(definitions from this post
viewtopic.php?t=23443#p180501)
now the formula is:
(%value%-350)/(800-350)*100
where the values are 350 = sensor in the water, 800 = dry sensor - not real clay values!
I used the same sensor - DIY More Capacitive Soil Moisture Sensor v1.2
Posted: Sunday 12 May 2019 19:22
by manuloup
I just installed Espeasy on my Wemos D1, and I also have a soil sensor connected (YL-67 type).
The soil is connected to A0-Gnd and 3.3V. It seems working, has the soil sensor has been detected.
- espeasy 1.jpg (101.01 KiB) Viewed 16489 times
- espeasy 2.jpg (81.78 KiB) Viewed 16489 times
If I enable send data, my device is updated in domoticz but stays at 0.
If I disable it, even with the rule, nothing happens, my device is not updated anymore in domoticz.
- espeasy 3.jpg (50.38 KiB) Viewed 16489 times
I did not understand : -Devices: add Analog input - internal, !st GPIO-14 (D5) enabled,
I only have A0 connected. I did not find anything for GPIO 14 - D5 to enable it.
Any idea ?
Thanks for your help.
Manu
Posted: Sunday 12 May 2019 22:22
by tlambin
here the same issue
I hope someone can help us
Posted: Friday 17 May 2019 9:14
by Mdieli
manuloup wrote: Sunday 12 May 2019 19:22
tlambin wrote: Sunday 12 May 2019 22:22
It is good i came across both of your posts. I changed Domoticz server a few days ago, and forgot to update the soil sensor to the new server.
I did it yesterday, but was wondering why the data still didn't got updated. It wasn't since the 12th.
I first thought of problems with my server and the reachability from it. Even tried to force a browser JSON but that worked.
Unfortunately, i have no clue where to find the solution..
Posted: Friday 17 May 2019 10:30
by marcojpolet
Which version of ESPEasy do you use? Also, did you check the log in the ESPEasy menu? You could also set that to a higher level of detail, perhaps that gives a clue.
Regards,
Marco
Posted: Friday 17 May 2019 23:20
by tlambin
Hi Marco
I use R120 version of esp easy
Posted: Sunday 19 May 2019 8:49
by marcojpolet
Thanks. Perhaps consider the mega branch, for me it's very stable (15 days+ without interruptions). But please also share the log details, this might help too.
Regards,
Marco
Posted: Sunday 19 May 2019 22:47
by tlambin
it’s working
If have installed the ESPEasy_mega-20190511
Here some pictures
Posted: Sunday 19 May 2019 23:15
by tlambin
more pictures to come
by tlambin
the last pictures
Posted: Monday 03 June 2019 13:34
by Nilesh579
Quite practical answer!!
Posted: Monday 03 June 2019 14:00
by manuloup
I guess I also have to calibrate the sensor. Is there a simple way to do it ?
Thanks,
Manu
Posted: Monday 03 June 2019 16:31
by tlambin
Put soil in a jar and put it in the oven until all moisture is vaporized.
Read the value in the devices tab. In my case 820 This will be your 0%
Add water over the soil until the water stays on the soil. Read the value in the devices tab again. In my case 360 This will be your 100%
Now check the “calibration enable“ checkbox in the tab “devices” “task settings” and fill out your values
Posted: Tuesday 11 June 2019 14:52
by acaonweb
JHO01 wrote: Monday 09 July 2018 17:14
Hardware:
-Wemos D1 Mini
Software steps:
Domoticz:
Wemos:
ESPEasy:
Do
Submit
-Rules: add
on Soil#Analog do
endon
Submit.
Done
Just two questions to understand better
why don't send value to controller but use rules?
why use http instead mqtt?
Posted: Wednesday 24 July 2019 18:08
by manjh
I connected to an ESP, using VCC, Gnd and A0. How difficult could it be.
Then added a device as described.
Should work, but doesn't: my A0 value stays at zero....
Any ideas?
