Capacitive Soil Moisture Sensor Wemos ESPeasy
Everything about esp8266 and more.
JHO01
Domoticz version: Stable
Post by JHO01 »
Finally got the capacitive soil moisture sensor working in Domoticz
Hardware:
-capacitive soil moisture sensor, does not corrode (Aliexpress)
-Wemos D1 Mini
-connect moisture sensor VCC=>5V (Wemos), GND=>G (Wemos), AUDT=>A0 (Wemos)
Software steps:
Domoticz:
-Create Virtual Sensor, Leaf Wetness (because I like the little green icon); note IDX (in my case 1883)
Wemos:
-Flash Wemos with ESPeasy
ESPEasy:
-Config: Connect to your wifi network
-Controllers: Connect to your Domoticz HTTP
-Devices: add Analog input - internal, !st GPIO-14 (D5) enabled,
Do NOT enable send to Controler.
Memorize Name sensor (in my case Soil) and # name of Values (in my case Analog)
Add formula: (840-%value%)/425*100 (The A0 value is varying between 840-425, Dry-Wet)
Submit
-Tools, advanced, check rules, Submit
-Rules: add
on Soil#Analog do
 SendToHTTP,192.168.2.30,8080,/json.htm?param=udevice&type=command&idx=1883&nvalue=[Soil#Analog]
endon
Submit.
Now the number below the Leaf Wetness icon is showing the moisture percentage
Done
RPI-3, Z-stick Gen5, RFlink, Zigbee2mqtt, 1-wire DS18B20, Fibaro switches, various RF-433 sockets, BMP018, Somfy, Wemos, Tradfri.
JHO01
Re: Capacitive Soil Moisture Sensor Wemos ESPeasy
Post by JHO01 »
Next challenge is to make the capacitive moisture sensor water proof. Have a look at my banana collection
1) cut out some plastic of the connector and clamp and solder a telephone wire:
2) Use a 2 cm diameter hose
3) Fill up the inside with silicone
misko903
Domoticz version: Latest
Post by misko903 »
Thank you, I will try it.
Wemos itself is somewhere in the waterproof box together with power adapter?
JHO01
Post by JHO01 »
misko903
Post by misko903 »
Thanks for sharing, really great idea, and it is working out of the box!
the basic parts are working, yeah!
now i want to integrate it into something like this:
maybe i can add some more sensors to it?
misko903
Post by misko903 »
I have inverted the formula, to correspond the Soil Moisture sensor values in Domoticz (using theme Aurora)
00 - 09 ==> "saturated
10 - 19 ==> "adequately wet"
20 - 59 ==> "irrigation advice"
60 - 99 ==> "irrigation"
> 99 ==> "Dangerously dry"
(definitions from this post viewtopic.php?t=23443#p180501)
now the formula is: (%value%-350)/(800-350)*100
where the values are 350 = sensor in the water, 800 = dry sensor - not real clay values!
I used the same sensor - DIY More Capacitive Soil Moisture Sensor v1.2
manuloup
Post by manuloup »
I just installed Espeasy on my Wemos D1, and I also have a soil sensor connected (YL-67 type).
The soil is connected to A0-Gnd and 3.3V. It seems working, has the soil sensor has been detected.
espeasy 1.jpg (101.01 KiB) Viewed 16468 times
espeasy 2.jpg (81.78 KiB) Viewed 16468 times
If I enable send data, my device is updated in domoticz but stays at 0.
If I disable it, even with the rule, nothing happens, my device is not updated anymore in domoticz.
espeasy 3.jpg (50.38 KiB) Viewed 16468 times
I did not understand : -Devices: add Analog input - internal, !st GPIO-14 (D5) enabled,
I only have A0 connected. I did not find anything for GPIO 14 - D5 to enable it.
Any idea ?
Thanks for your help.
Manu
Rapberry PI B+ (RaspBian), RFXtrx433E USB 433.92MHz Transceiver, AEON LABS Controler Z-Wave, Aeon Labs Z-Stick S2, Everspring ST814 Temperature Sensor, Everspring SF812 Smoke Detector, 2x Fibaro Wallplug, Aeon Zwave Miniremote , Xbee Teleinfo USB
tlambin
Post by tlambin »
here the same issue
I hope someone can help us
Mdieli
Post by Mdieli »
manuloup wrote: Sunday 12 May 2019 19:22
tlambin wrote: Sunday 12 May 2019 22:22 ...
It is good i came across both of your posts. I changed Domoticz server a few days ago, and forgot to update the soil sensor to the new server.
I did it yesterday, but was wondering why the data still didn't got updated. It wasn't since the 12th.
I first thought of problems with my server and the reachability from it. Even tried to force a browser JSON but that worked.
Unfortunately, i have no clue where to find the solution.. :(
marcojpolet
Post by marcojpolet »
Which version of ESPEasy do you use? Also, did you check the log in the ESPEasy menu? You could also set that to a higher level of detail, perhaps that gives a clue.
Regards,
Marco
tlambin
Post by tlambin »
Hi Marco
I use R120 version of esp easy
marcojpolet
Thanks. Perhaps consider the mega branch, for me it's very stable (15 days+ without interruptions). But please also share the log details, this might help too.
Regards,
Marco
tlambin
Post by tlambin »
:D it’s working :D
If have installed the ESPEasy_mega-20190511
Here some pictures
tlambin
Post by tlambin »
more pictures to come
tlambin
Post by tlambin »
the last pictures
Nilesh579
Post by Nilesh579 »
Quite practical answer!!
manuloup
Post by manuloup »
I guess I also have to calibrate the sensor. Is there a simple way to do it ?
Thanks,
Manu
tlambin
Post by tlambin »
Put soil in a jar and put it in the oven until all moisture is vaporized.
Read the value in the devices tab. In my case 820 This will be your 0%
Add water over the soil until the water stays on the soil. Read the value in the devices tab again. In my case 360 This will be your 100%
Now check the “calibration enable“ checkbox in the tab “devices” “task settings” and fill out your values
acaonweb
Post by acaonweb »
JHO01 wrote: Monday 09 July 2018 17:14 Finally got the capacitive soil moisture sensor working in Domoticz
Hardware:
-Wemos D1 Mini
Software steps:
Domoticz:
Wemos:
ESPEasy:
Submit
-Rules: add
on Soil#Analog do
endon
Submit.
Done
Just two questions to understand better :)
why don't send value to controller but use rules?
why use http instead mqtt?
manjh
Post by manjh »
I connected to an ESP, using VCC, Gnd and A0. How difficult could it be.
Then added a device as described.
Should work, but doesn't: my A0 value stays at zero....
Any ideas?
Hans
