World Cup Scoreboard - new version
elmortero
Domoticz version: 3.9639
Post by elmortero »
Not a real football fan myself but with the World Cup I make a little exception.
For that reason - and because I am always looking for data sources to play with the asynchronous http requests - I wrote this script.
The data are fetched from http://worldcup.sfg.io/ and they offer other data sets. I was only interested in the status of the current game.
changed: now using the /today endpoint. This way at the end of the game the winner is displayed
In the code below I check if one of the teams is a team I want notifications about. If you don't want to use that remove line 30 to 32 and 47 to 49
		timer = { 'every 2 minutes' },
		httpResponses = { 'scoreboard2' } -- matches callback string below
	execute = function(domoticz, triggerItem)
    local board = domoticz.devices('Scoreboard2')    --a virtual text sensor
    local prevboard = tostring(board.text)          --get current value of text sensor
		if (triggerItem.isTimer) then
			domoticz.openURL({
				url = 'http://worldcup.sfg.io/matches/today',
				method = 'GET',
				callback = 'scoreboard2'
		elseif (triggerItem.isHTTPResponse) then
	local response = triggerItem
			if (response.ok and response.isJSON) then
			tl = #response.json
			tc = 1
			repeat
				local status = tostring(response.json[tc].status)
				local home = tostring(response.json[tc].home_team.country)
				local away = tostring(response.json[tc].away_team.country)
				local hgoal = tostring(response.json[tc].home_team.goals)
				local agoal = tostring(response.json[tc].away_team.goals)
					if away == 'Spain' or away == 'Belgium' or home == 'Spain' or home == 'Belgium' then
					 sender = true
				show = (home..' '..hgoal..' - '..agoal..' '..away)
					if status == 'in progress' then tc = tl + 1 end
					if status == 'completed' then
						local score = (hgoal..' - '..agoal)
						local winner = tostring(response.json[tc].winner)
						show = ('Match won by '..winner..' with '..score)
						tc = tc + 1
					if status == 'future' then tc = tl + 1 end
				until tc > tl
					if show ~= prevboard then
					    print ('result '..show)
						board.updateText(show)
							if sender then
							 --put your notification method here (mine is telegram)
					print('**scoreboard2 failed to fetch info')
The attachment Capture.JPG is no longer available
jia175891641
Domoticz version: V3.9000
Re: World Cup Scoreboard
Post by jia175891641 »
good work!
只要够努力 时间总会给你想要的
ulisesrdg
Post by ulisesrdg »
Very useful!!!, Thank you for sharing!
elmortero
Post by elmortero »
Found an error (needed a match in progress to test)
it should be: if #response.json > 0 then and not > 1
EdwinK
Post by EdwinK »
Screen Shot 2018-06-16 at 13.23.44.png (41.87 KiB) Viewed 4527 times
Thanks. I don't like soccer/football but this things are funny to play with.
corederoma82
Re: World Cup Scoreboard - new version
Post by corederoma82 »
how is the procedure for installation?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
EdwinK
Post by EdwinK »
Copy the lines of the scripts in the events editor, make sure to select dzVents.
Make a text device and name it scoreboard.
That's all
corederoma82
EdwinK wrote: Sunday 17 June 2018 23:21 Copy the lines of the scripts in the events editor, make sure to select dzVents.
That's all
Ok
CaesarPL
Post by CaesarPL »
Thank you very much. Just curious - as I am still on last stable - will it work on old dzVents?
MikeF
Domoticz version: V2022.2
Post by MikeF »
I've just set this up as described, but I'm getting this dzVents error:
Error: dzVents: Error: ...omoticz/scripts/dzVents/generated_scripts/scoreboard.lua:11: attempt to index local 'triggerItem' (a nil value)
elmortero
Post by elmortero »
MikeF wrote: Monday 18 June 2018 15:06 I've just set this up as described, but I'm getting this dzVents error:
That means that you are on a dzVents version prior to 2.4
MikeF
Post by MikeF »
Well, that's a shame - yes, I'm on version 2.2, with Domoticz stable 3.8153. I believe I would need to upgrade to Domoticz beta in order to get dzVents 2.4.
elmortero
Post by elmortero »
MikeF wrote: Monday 18 June 2018 19:54 Well, that's a shame - yes, I'm on version 2.2, with Domoticz stable 3.8153. I believe I would need to upgrade to Domoticz beta in order to get dzVents 2.4.
You should, there are some nice features in the later versions of dzVents.
Meanwhile, I took the time to make a pre-httpresponse version of the script. Should work, have not domoticz running on an older version to check all functions.
Try it if you want and let me know if it gives issues (the first time it runs you might get an error about the /tmp file not being available, on the second run it should be ok.
local scorefile = '/tmp/score.json'
local fetchIntervalMins = 3     -- interval to check the info (don't set to lower than 3)
active = true,
	timer = { 'every minute' },
local callUrl = false
	if (os.date('*t').min % fetchIntervalMins) == 0 then
	callUrl = true
	elseif ((os.date('*t').min -1) % fetchIntervalMins) ~= 0 then
	return
local board = domoticz.devices('Scoreboard')
local linker = tostring('http://worldcup.sfg.io/matches/today')
	if callUrl then
	os.execute('curl -s "'..linker..'" > '..scorefile..'&')
	 print('json written to file')
	return -- Nothing more to do for now, we'll be back in a minute to read the data!
		local function readLuaFromJsonFile(fileName)
		local file = io.open(fileName, 'r')
				if file then
				package.path = './scripts/lua/?.lua;'..package.path
				local jsonParser = require('JSON')
				local _json = file:read('*a')
				local json = jsonParser:decode(_json)
				io.close(file)
				return json
		return nil
local scoreData = readLuaFromJsonFile(scorefile)
	if not scoreData then
	print('** Scoreboard// Could not read scoreData from file: '.. scorefile)
	return
	tl = #scoreData
	if tl > 0  then
			tc = 1
			repeat
				local status = tostring(scoreData[tc].status)
				local home = tostring(scoreData[tc].home_team.country)
				local away = tostring(scoreData[tc].away_team.country)
				local hgoal = tostring(scoreData[tc].home_team.goals)
				local agoal = tostring(scoreData[tc].away_team.goals)
						local winner = tostring(scoreData[tc].winner)
						if winner == 'Draw' then
						   show = ('Draw '..home..' '..hgoal..' - '..agoal..' '..away)
						tc = tc + 1
				until tc > tl
LennartIsHigh
Domoticz version: 4.9700
Post by LennartIsHigh »
elmortero wrote: Monday 18 June 2018 20:45 Try it if you want and let me know if it gives issues (the first time it runs you might get an error about the /tmp file not being available, on the second run it should be ok.
I don't have a clue about what version I've got running but this version of yours works for me.
MikeF
Post by MikeF »
elmortero wrote: Monday 18 June 2018 20:45 Meanwhile, I took the time to make a pre-httpresponse version of the script. Should work, have not domoticz running on an older version to check all functions.
Thanks for taking the time to do this - works well for me. :D
MikeF
Post by MikeF »
I've made a change (to the pre-HTTPresponse version) to show kick-off time for future matches:
active = true,
	callUrl = true
	return
	if callUrl then
				if file then
				io.close(file)
				return json
		return nil
	return
	tl = #scoreData
	if tl > 0  then
			tc = 1
			repeat
				local date = tostring(scoreData[tc].datetime)
				local pattern = "(%d+)%-(%d+)%-(%d+)T(%d+):(%d+):(%d+)"
				local year, month, day, hour, minute, seconds = date:match(pattern)
				hour = hour + 1
						tc = tc + 1
					    show = (show..' KO '..hour..':'..minute)
					    tc = tl + 1
				until tc > tl
Line 56 (hour = hour + 1) should be changed for different timezones (mine is UK BST).
MikeF
Post by MikeF »
I've added the elapsed match time - although this will lag, as the script runs every 3 minutes:
active = true,
	callUrl = true
	return
	if callUrl then
				if file then
				io.close(file)
				return json
		return nil
	return
	tl = #scoreData
	if tl > 0  then
			tc = 1
			repeat
				local time = tostring(scoreData[tc].time)
				hour = hour + 1
					    show = (show..' '..time)
					    tc = tl + 1
						tc = tc + 1
					    tc = tl + 1
				until tc > tl
freakshock
Post by freakshock »
Thanks for the scripts elmortero & mike! :P
MikeF
Post by MikeF »
I'm now getting this error when I run this (the pre-HTTPresponses version):
2018-06-22 18:01:04.516 Error: dzVents: Error: An error occured when calling event handler scoreboarrd
2018-06-22 18:01:04.516 Error: dzVents: Error: Lua script execution exceeds maximum number of lines
Any clues? Is it looping (more than it should!)?
MikeF
Post by MikeF »
There are problems with the feed today. The matches are in the wrong order, with the wrong times, and the 3rd match (which appears second) is showing a status of 'pending correction' - which the dzVents script doesn't recognise.
