Zwave Aetonic S2 stick Topic is solved
BartSr
Domoticz version: V2024.7
Post by BartSr »
Dear all. I used the zwave stick with domoticz running on pc. I included a swich with kw meter facility. This worked well in domoticz.
Than i placed same stick in raspberry pi with domoticz. Stick can be seen in hardware but list with nodes is empty. Also not possible to include more devices (switches).
Do I overlook something?
Kr
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
D'rMorris
Re: Zwave Aetonic S2 stick
Post by D'rMorris »
I don't have a Z-wave stick, but I think that I read somewhere that you need to exclude the device first on the "old" machine before you can include it in the "new" machine?
gizmocuz
Post by gizmocuz »
You adjusted the com port setup ?
You do not have to exclude/include again
BartSr
Post by BartSr »
adjusting the com port setup did the trick
thanks!
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
antwan
Domoticz version: Latest
Post by antwan »
Check the wiki for persistent USB.
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
