Dear all. I used the zwave stick with domoticz running on pc. I included a swich with kw meter facility. This worked well in domoticz.
Than i placed same stick in raspberry pi with domoticz. Stick can be seen in hardware but list with nodes is empty. Also not possible to include more devices (switches).
Do I overlook something?
Kr
-Bart
Zwave Aetonic S2 stick Topic is solved
BartSr
- Domoticz version: V2024.7
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
D'rMorris
Re: Zwave Aetonic S2 stick
I don't have a Z-wave stick, but I think that I read somewhere that you need to exclude the device first on the "old" machine before you can include it in the "new" machine?
- gizmocuz
You adjusted the com port setup ?
You do not have to exclude/include again
BartSr
adjusting the com port setup did the trick
thanks!
thanks!
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
antwan
- Domoticz version: Latest
Check the wiki for persistent USB.
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
