hi friends, has anyone been able to integrate this into DOMOTICZ? It only gives me the value of ON every time I press the switch, I do not see how to set it.
Could you help me some?
WXKG03LM AQARA WIRELESS "SMART" SWITCH (STICKUP VERSION)
chetele6725
- waaren
Re: WXKG03LM AQARA WIRELESS "SMART" SWITCH (STICKUP VERSION)
Is this the same / similar as the WXKG02LM ?
I have that one setup as selector and control the actions with dzVents script.
on = { devices = { "XDual" } },
execute = function(dz, switch )
if switch.state == "left" then
dz.devices("Kastenkamer lamp").toggleSwitch()
elseif switch.state == "right" then
dz.devices("Kastenkamer rolluik").switchOn()
elseif switch.state == "both" then
dz.devices("Kastenkamer rolluik").close()
dz.devices("Slaapkamer rolluik").close().afterSec(5)
}Debian buster, bullseye on RPI-4, Intel NUC.
chetele6725
Hello, thank you very much for your answer.
It is similar but it is not the same.
The WXKG03LM only has one button.
1º. It appears on devices
2º. I add it to DOMOTICZ (PRUEBA)
in SWITCHES it appears
3º. I edit the switch and assign a selector with 2 levels, Click and double Click. Then I save the changes.
4º I go back to switches and only the OFF status appears.
5º I try to edit again and I can not do anything with that switch
If instead of setting it as a selector I set it as ON / OFF it only shows me the ON value permanently. Whenever I activate it, it sends me ON
- waaren
Would this dzVents script work for you ?
Turn off PRUEBA
on = { devices = { "PRUEBA" } },
if switch.state ~= "Off" then
switch.switchOff().silent()
chetele6725
IT WORKS!!!
I will try some event
thanks a lot
thanks a lot
