I must be going mad: when running domoticz on port 8080 it is not possible to switch icon in edit mode of device and the log is showing less. If I start on port 8081, all is ok...
Thanks for any advise on how to resolve this... Not really a problem to run on 8081 but it bugs me that I can not find the reason...
different behaviour on port 8080?
huey
- CaptureEditOKport8081.PNG (66.03 KiB) Viewed 941 times
- CaptureEditNOKport8080.PNG (39.26 KiB) Viewed 942 times
huey
Re: different behaviour on port 8080?
And the log:
- CaptureLogNOKport8080.PNG (78.38 KiB) Viewed 940 times
huey
While ok:
- CaptureLogOKport8081.PNG (146.49 KiB) Viewed 939 times
- waaren
If I look very closely at you screen shots I can see that you use V3.9288 but I cannot see what your hardware or OS you are using for your domoticz instance.
That information might be useful in getting to an answer
huey
Hi waaren,
Yes, you are right: I use the beta builds on a Raspberry PI 2, Debian Stretch, added python 3.6.5 and build from source with USE_OPENSSL_STATIC=NO so I can make use of ptyhon plugins without segmentation faults. Although
I think the last items are not relevant for this matter. I have this behaviour also on earlier beta builds.
huey
Hm, just noticed that giving the host a different name also solves the issue. I guess the webserver does not like the host to be domoticz as it maybe uses it internally as well fro some check on port 8080?
Renamed the host to domoticz-prod.local and know am running on port 8080 with the proper edit and log functionality...
Still interested to know what is really going on. Would be great if someone was able to explain/elaborate?
- gizmocuz
Try clearing your browser cache and appcache (two different things)
huey
Ok, I will give that a try!gizmocuz wrote:Try clearing your browser cache and appcache (two different things)
huey
Ok, my bad: clearing the appcache did it! Must admit I was not aware/stumbled upon the existance, of that cache. Must browse more topics.
@gizmocuz: Thanks for solving this issue for me!
