Create a simple switch with JSON
lumjajo
Domoticz version: 4.10717
Post by lumjajo »
I want to create a virtual switch. This does not work within Domoticz, I always get Cannot create switch or soemthing like that. Now I want to use JSOn, but I can create sensors, like Humidity and others, but how do I create a simple switch?
Many thanks...
sion
Re: Create a simple switch with JSON
Post by sion »
Have you set up virtual hardware to link the switch to? When adding a virtual switch, you need to make sure that each one has a different code too.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
lumjajo wrote: Sunday 22 April 2018 0:40 I want to create a virtual switch. This does not work within Domoticz, I always get Cannot create switch or soemthing like that. Now I want to use JSOn, but I can create sensors, like Humidity and others, but how do I create a simple switch?
Many thanks...
Look here for the syntax
Look here for the type definitions (in hex)
if your virtual hardware number is 35 and you want it named "mySwitch" the json call would be:
http://domoticzIP:domoticzPort/json.htm?type=createdevice&idx=35&sensorname=mySwitch&devicetype=244&devicesubtype=73
btw: You can allways peek what the domoticz webpage sends when you enter a command by opening a developers tools window. (In Chrome: ctrl shift I)
lumjajo
Post by lumjajo »
All,
thanks, I did not find the simple switch type. That was all about.
Many thanks.,
Does anyone know why I cannot create a virtual switch out of native Domoticz (without using the json command)
I am on stable Version: 3.8153.
Many thanks, have a nice and sunny Sunday..
