I want to create a virtual switch. This does not work within Domoticz, I always get Cannot create switch or soemthing like that. Now I want to use JSOn, but I can create sensors, like Humidity and others, but how do I create a simple switch?
Many thanks...
Create a simple switch with JSON
sion
Re: Create a simple switch with JSON
Have you set up virtual hardware to link the switch to? When adding a virtual switch, you need to make sure that each one has a different code too.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
- waaren
Look here for the syntaxlumjajo wrote: Sunday 22 April 2018 0:40 I want to create a virtual switch. This does not work within Domoticz, I always get Cannot create switch or soemthing like that. Now I want to use JSOn, but I can create sensors, like Humidity and others, but how do I create a simple switch?
Many thanks...
Look here for the type definitions (in hex)
if your virtual hardware number is 35 and you want it named "mySwitch" the json call would be:
http://domoticzIP:domoticzPort/json.htm?type=createdevice&idx=35&sensorname=mySwitch&devicetype=244&devicesubtype=73Debian buster, bullseye on RPI-4, Intel NUC.
lumjajo
- Domoticz version: 4.10717
All,
thanks, I did not find the simple switch type. That was all about.
Many thanks.,
Does anyone know why I cannot create a virtual switch out of native Domoticz (without using the json command)
I am on stable Version: 3.8153.
Many thanks, have a nice and sunny Sunday..
Many thanks.,
