Neo Coolcam cheap wifi plug
tontze
Domoticz version: Beta Ch
Post by tontze »
Any one tried these, can they be integrated to domoticz:
https://www.aliexpress.com/item/NEO-COO ... autifyAB=0
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
blauwebuis
Domoticz version: current
Re: Neo Coolcam cheap wifi plug
Post by blauwebuis »
I try to avoid wifi stuff. Too hackable.
SteGe
Post by SteGe »
@blauwebuis, what do you mean by to hackable? Why is a Wifi plug more hackable than for example the z-wave (or 433 mhz, which is far more hackable)?
Next to that, I saw the Coolcam Motion sensor wifi version also, don't know if that one is implemented in Domoticz?
Synology DS3615xs | Raspberry pi 3b |
RFXtrx433E | MySensors | Z-wave | Philips Hue | Ikea Tradfri |
Sunscreen | Power switches | Toon | Harmony | UE Smartradio |
Weatherstation | Doorbell | Letterbox reader | Lux | Temp | Humidity | Motion |
LouiS22
Post by LouiS22 »
SteGe wrote: Monday 16 April 2018 10:19 @blauwebuis, what do you mean by to hackable? Why is a Wifi plug more hackable than for example the z-wave (or 433 mhz, which is far more hackable)?
Not implemented (yet), but you're welcome to do it :)
SteGe
Post by SteGe »
haha I'm sure that I'ld be welcome, but I'm afraid that it will be far out of my league...
tontze
Post by tontze »
SteGe wrote: Monday 16 April 2018 14:04 haha I'm sure that I'ld be welcome, but I'm afraid that it will be far out of my league...
Same here :)
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
menrone
Post by menrone »
any changes? was someone able to implement it in Domoticz?
Greetings, Wim
jslegers
Domoticz version: 2025.2
Post by jslegers »
Would be nice if this will be supported in the future.
dextm80
Domoticz version: 4.10159
Post by dextm80 »
bad product, i bought 2 plug and one of these is already dead
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
krzemo
Target OS: OS X
Post by krzemo »
any changes? was someone able to implement it in Domoticz? :)
Regards,
Przemek
LouiS22
Post by LouiS22 »
krzemo wrote: Sunday 24 February 2019 22:07 Hi,
Regards,
Przemek
You can flash Tasmota to it...
sincze
Domoticz version: 2024.4
Post by sincze »
Just a gentle reminder:
These things have the ability to call their China Homeland Address :D , and z-wave does not.
Although I've seen them call an IP in Germany as well.
-> Tasmota nice solution, but takes some time for this plug.
In potential these things could be infected remotely. (unless you block them fron internet access ofcourse). As they probably have an IP on your main lan ... the intruder could also be on your main lan.
In addition they are not implemented in Domoticz yet,
Setting them up (search for TUYA plugin on the forum) and extracting the device keys take a lot of time.
And I noticed that these devices are constantly yelling (broadcasting) on my network.
For a bit additional money you have a working z-wave solution. :D
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
LouiS22
Post by LouiS22 »
sincze wrote: Monday 25 February 2019 16:36
I theory it should take 3 minutes to flash Tasmota, and if you're lucky, you don't even need to unscrew it... https://github.com/ct-Open-Source/tuya-convert
