Write a value from Dimmer to Percent Display
Stanislaw
Post by Stanislaw »
Good morning,
I need a little help with a simple exercise. I would like to rewrite a value from a virtual dimmer to a percentage display. How I'm trying to do that:
local iDimmer = tonumber (otherdevices['Dimmer']) --Input
local qDimmer = 'Percent' --Output
--I'v tried:
qDimmer = iDimmer
--And like that
commandArray[qDimmer] = tonumber(iDimmer)
I created a virtual sensor "Percentage" named "Percent" but it doesn't work.
I'm learning LUA, I understand how to read a value from devices but I don't know how to write values for example to a virtual indicators :/
Is there any tutorial about that? I'm trying to google that but without luck...
freijn
Domoticz version: Stable
Re: Write a value from Dimmer to Percent Display
Post by freijn »
I do not have an answer for you but my plan of attack would be :
make a print statement in your script like :
with the Debug you can then turn it on and off easy :-)
local Debug
Debug = "YES"                    -- Turn debugging on ("YES") or off ("NO")
-- header text
some code here  bla bla bal
if Debug=="YES" then
    print( "My text to write in debug file  debug: ")
    print(">>qDimmer =   " ..qDimmer)
Stanislaw
Post by Stanislaw »
freijn thanks for help but I'm watching values of variables by using prDebug:
function prDebug(sString)
  if(bDebug) then
   print ( sString )
Still can't solve the problem....So many hours lost :(
dzVents hides most of the complexity of using LUA in combination with domoticz for you and therefore is much easier to learn. This is especial true when starting with programming in this area.
Happy to help if you still have questions after looking at
http://www.domoticz.com/forum/viewtopic ... 59&t=18143
and
http://www.domoticz.com/forum/viewtopic ... 59&t=18674
Stanislaw
Post by Stanislaw »
waaren wrote: Wednesday 28 February 2018 14:41 dzVents hides most of the complexity of using LUA in combination with domoticz for you and therefore is much easier to learn. This is especial true when starting with programming in this area.
and
Thanks waaren, dzVents looks great and I will learn it for sure. Really good stuff :)
But for now, i will focus on LUA because I'v got some good code this type that I want to use.
With a simple code like below, I am able to write a value from code to outside variable. Take a look on that masterpiece ;)
print ("All based event fired");
internal_var1 = 5 + 10
print(internal_var1)
commandArray['Variable:outside_var1'] = tostring(internal_var1)
So now I'm wondering how can I display this variable? What kind of indicator should I use?
Then next step is to rewrite a value from a dimmer to this outside variable and then visualize it for example in Percentage indicator.
I tried like this but it doesn't work:
local i_dimmer = otherdevices['Dimmer']
local internal_var1 = i_dimmer
commandArray['Variable:outside_var1'] = tonumber(internal_var1)
Any suggestions? :)
Stanislaw
Post by Stanislaw »
Sorry that I'm asking for a such basic things but I'm not a software developer, just trying to have some fun :)
Can somebody tell me just last more thing? If I'm using command:
commandArray['UpdateDevice'] = '13|0|30'
To write something to a Percentage Display, can I put somehow a value from another variable instead a constatnt "30"?
for example:
var1 = 55
commandArray['UpdateDevice'] = '13|0|var1'
That code above doesn't work - is there some other way?
---------------EDIT:
OK It's working :)
local i_dimmer = otherdevices_svalues['Dimmer']
commandArray['UpdateDevice'] = '13|0|'..internal_var1
By that we can write a value from dimmer to indicator (for example Custom Sensor)
Thanks for help :)
