How to use Data from a Dust Sensor
matzeb74
Domoticz version: newest
Post by matzeb74 »
I build my own Dustsensor (https://luftdaten.info). I now would like to use the Data in Domoticz. There are only Scripts for Fhem and HAss.
The Sensor also showa data in an Json File like this:
{"software_version": "NRZ-2017-099", "age":"139", "sensordatavalues":[{"value_type":"SDS_P1","value":"7.63"},{"value_type":"SDS_P2","value":"4.23"},{"value_type":"temperature","value":"8.30"},{"value_type":"humidity","value":"27.30"},{"value_type":"samples","value":"617412"},{"value_type":"min_micro","value":"229"},{"value_type":"max_micro","value":"25617"},{"value_type":"signal","value":"-67"}]}
Also its possible to use an own api. Now my question is how to get the Data into domoticz?
Sensors used with an Nodemcu are DHT22 and SDS011.
matzeb74
Re: How to use Data from a Dust Sensor
Post by matzeb74 »
Is here no one who Knows how to parse the Data to Domoticz?
Toulon7559
Domoticz version: <2025
Post by Toulon7559 »
@matzeb74
Struggling with the same question.
Perhaps not a direct answer to your question, but in this thread a solution was found to 'dissect' an XML-file. Conversion from json to xml can be rather easily be made by a python-script.
For the xml-files in that thread the values are conveniently enclosed between unique 'header'-markers and 'tail'-markers like <gauge power> and </gauge power>, and then you can perform a string-search to determine within the string the unique start- and stop-positions for the values, enabling to pinpoint the extraction of the values, even if variable length.
But such 'marker-grip' is missing in the json-file coming from the Luftdaten-firmware:
that json-file does not have unique markers, but just has plenty of couples consisting of "value_type" and "value".
The derived XML-file is not much better, with only couples consisting of <value_type>+</value_type> and <value>+</value>
Simply counting characters in the string is also not a solution, because the values can have variable number of characters.
To demonstrate what I mean, below you find a json-file from Luftdaten and the equivalent XML-file.
{"age": "94", "sensordatavalues": [{"value_type": "SDS_P1", "value": "5.50"}, {"value_type": "SDS_P2", "value": "4.03"}, {"value_type": "temperature", "value": "19.80"}, {"value_type": "humidity", "value": "44.70"}, {"value_type": "samples", "value": "607696"}, {"value_type": "min_micro", "value": "234"}, {"value_type": "max_micro", "value": "966087"}, {"value_type": "signal", "value": "-66"}], "software_version": "NRZ-2017-099"
<?xml version="1.0" encoding="UTF-8" ?><root><age type="str">94</age><sensordatavalues type="list"><item type="dict"><value_type type="str">SDS_P1</value_type><value type="str">5.50</value></item><item type="dict"><value_type type="str">SDS_P2</value_type><value type="str">4.03</value></item><item type="dict"><value_type type="str">temperature</value_type><value type="str">19.80</value></item><item type="dict"><value_type type="str">humidity</value_type><value type="str">44.70</value></item><item type="dict"><value_type type="str">samples</value_type><value type="str">607696</value></item><item type="dict"><value_type type="str">min_micro</value_type><value type="str">234</value></item><item type="dict"><value_type type="str">max_micro</value_type><value type="str">966087</value></item><item type="dict"><value_type type="str">signal</value_type><value type="str">-66</value></item></sensordatavalues><software_version type="str">NRZ-2017-099</software_version></root>
Toulon7559
With hints from friends at Stackoverflow achieved the conversion from the basic file-layout from Luftdaten.info into a format with unique fieldnames.
Also the related script running, which then extracts the information and transfers towards Domoticz.
2-Step approach:
Step1 = Python-script running under cronjob, which
- calls the local measuring setup,
- changes the format of the json-file,
- makes a 2nd set of json-file + xml-file for upload, and
- uploads those 2 files to a server
[Reason for upload of json+xml: in that way the data is accessible for multiple applications also by other users]
Step2 = lua-script which
- reads the 2nd xml-file with the name given in step1 [therefore do no change filenames in Step1 unless you know what you do!],
- dissects that file and extracts temperature, humidity, PM2.5 and PM10, and
- uploads the extracted information to Domoticz
[upload of temperature+humidity is towards a virtual sensor which mimicks a DHT22, and towards 2 Custum sensors for PM2.5 respectively PM10]
Python-script for Step1
#!/usr/bin/python
# -*- coding = utf-8 to enable reading by simple editors -*-
# (c)2017 script compiled by Toulon7559 from various material from forums, version 00
# (c)2018 extended by extra step to extract info from json-file from Luftdaten.info
# Line006 = PREPARATION & SETTING
# Imports for script-operation
import json
import urllib
import dicttoxml
# SDS011 is dust-sensor at IP=192.168.0.141
# IP-address obviously to be tuned to YOUR configuration
# Line015 Read data and compile json-file + xml-file
page = urllib.urlopen('http://192.168.0.141/data.json')
content_test = page.read()
obj_test = json.loads(content_test)
print(obj_test)
with open('json_sds011_upload1.json', 'w') as outfile:
    json.dump(obj_test, outfile)
xml_test = dicttoxml.dicttoxml(obj_test)
print(xml_test)
xml_output = open("xml_sds011_upload1.xml",'w')
xml_output.write(xml_test)
xml_output.close()
# Line030 = Extract Field-names and values from json
import json
import pprint
with open('json_sds011_upload1.json') as j:
    data = json.load(j)
for sdv in data.pop('sensordatavalues'):
    data[sdv['value_type']] = sdv['value']
print(data)
pprint.pprint(data)
# Line043 Compile 2nd set of json-/xml-file
with open('json_sds011_upload2.json', 'w') as outfile:
    json.dump(data, outfile)
xml_test2 = dicttoxml.dicttoxml(data)
print(xml_test2)
xml_output = open("xml_sds011_upload2.xml",'w')
xml_output.write(xml_test2)
xml_output.close()
# Line054 = FTP_UPLOAD to Server
import ftplib
import os
# Definition of Upload_function
def upload(ftp, file):
    ext = os.path.splitext(file)[1]
    if ext in (".txt", ".htm", ".html"):
        ftp.storlines("STOR " + file, open(file))
    else:
        ftp.storbinary("STOR " + file, open(file, "rb"), 1024)
# Line068 = Actual FTP-Login & -Upload
ftp = ftplib.FTP("<ftp-server>")
ftp.login("<ftp-username>", "<ftp-password>")
upload(ftp, "json_sds011_upload2.json")
upload(ftp, "xml_sds011_upload2.xml")
Lua-script for Step2
-- Version 00 20180226
-- Domoticz lua script to convert XML output for SDS011-sensor plus related DHT22-sensor
-- Reads the status based on the unique web-address and passes values
-- to virtual sensor(s) in Domoticz
-- Original script by RATA1 at Domoticz-forum, adapted by Toulon7559 (c)2016-2018
-- Line 11: Start of script
function XML_Capture(cmd,flatten)
   local f = assert(io.popen(cmd, 'r'))
   local s = assert(f:read('*a'))
   f:close()
   if flatten  then
      s = string.gsub(s, '^%s+', '')
      s = string.gsub(s, '%s+$', '')
      s = string.gsub(s, '[\n\r]+', ' ')
   return s
-- Line 26: Set debug to true to print to log file, set to false is not.
debug = true
-- Line 29: Define the idx of YOUR virtual sensor(s) in Domoticz
-- => what you have called your sensor(s) and the related IDX number(s)
PT_SDS011M = 1582 -- Virtual device for DHT22, temp + baro
PT_SDS011A = 1583 -- Virtual device for SDS PM2.5 [= SDS_P2 in file], custom sensor
PT_SDS011B = 1584 -- Virtual device for SDS PM10  [= SDS_P1 in file], custom sensor
-- Line 35: Define your device IP-address: the xml-filename was set in Step1!
-- Lines 37 ~ 45 define where the XML-file can be read
Device_IP = "xxxx.nl" -- if you read from a remote website xxxx.nl
-- Device_IP = "192.168.1.x/home/pi" --if you read from your local Domoticz@Raspberry
if debug == true then
        print("Reading values from: 'http://"..Device_IP.."/xml_sds011_upload2.xml'")
-- Line 43: Read the XML data from your device and from your XML-string
XML_string=XML_Capture("curl -s 'http://"..Device_IP.."/xml_sds011_upload2.xml'",1)
valid = string.find(XML_string, "<root>")    -- check that we are looking in the right place
    print("SDS011-string = "..XML_string)
if valid == nil then
    print ("Bad XML status read - info NOT updated")
-- Line 57: Find in the XML_string the info-fields based on their labels
-- Line 58: read position of SDS_strings
    s1 = string.find(XML_string,"<SDS_P1")  -- start of header SDS_P1
    print(s1)
    t1 = string.find(XML_string,"</SDS_P1")  -- start of tail SDS_P1
    print(t1)
    s2 = string.find(XML_string,"<SDS_P2") -- start of header SDS_P2
    print(s2)
    t2 = string.find(XML_string,"</SDS_P2") -- start of tail SDS_P2
    print(t2)
-- Line 67: read position of temperature & humidity strings
    s3 = string.find(XML_string,"<temperature")   -- start of header temperature
    print(s3)
    t3 = string.find(XML_string,"</temperature")   -- start of tail temperature
    print(t3)
    s4 = string.find(XML_string,"<humidity")      -- start of header humidity
    print(s4)
    t4 = string.find(XML_string,"</humidity")      -- start of tail humidity
    print(t4)
-- Line 76: Manually determine/set start/end-positions of the values within the substrings
    p1 = s1+19 -- number = characters of header-string SDS_P1
    print(p1)
    p2 = s2+19 -- number = characters of header-string SDS_P2
    print(p2)
    p3 = s3+24 -- number = characters of header-string temperature
    print(p3)
    p4 = s4+21 -- number = characters of header-string humidity
    print(p4)
-- Line 85: Extract the values and process for upload to Domoticz
-- Line 86: read SDS_P1 string
    SDSP1 = string.sub(XML_string,p1,t1-1)
    SDS_P1 = tonumber(SDSP1)
    print(SDS_P1)
-- Line 90: read SDS_P2 string
    SDSP2 = string.sub(XML_string,p2,t2-1)
    SDS_P2 = tonumber(SDSP2)
    print(SDS_P2)
-- Line 94: read temperature string
    tmp1 = string.sub(XML_string,p3,t3-1)
    DHT_T = tonumber(tmp1)
    print(DHT_T)
-- Line 98: read humidity string
    hm1 = string.sub(XML_string,p4,t4-1)
    DHT_H = tonumber(hm1)
    print(DHT_H)
-- Line 103: Upload to Domoticz
    commandArray[1] = {['UpdateDevice'] = PT_SDS011M.."|0|"..DHT_T..";"..DHT_H..";1"}  -- send updated values to Domoticz
--  with the virtual device set in line 31 the above { layout } as result mimicks a DHT22, except for the 3rd (static) value
    commandArray[2] = {['UpdateDevice'] = PT_SDS011A.."|0|"..SDS_P2}  -- send updated value for PM2.5 to Domoticz
    commandArray[3] = {['UpdateDevice'] = PT_SDS011B.."|0|"..SDS_P1}  -- send updated value for PM10 to Domoticz
            print("Temp/Hum = ".."'"..DHT_T.."/"..DHT_H.."'")
            print("PM2.5 = ".."'"..SDS_P2.."'")
            print("PM10  = ".."'"..SDS_P1.."'")
For testing & checking the scripts have plenty of print-lines, which obviously can be removed to get leaner scripts (with simultaneous adaptation or removal of the line-numbers)
matzeb74
Post by matzeb74 »
Many thanks @Toulon7559.
I´ll Try it this evening. For me its good with the printlines, helps me to understand and learn.
Hello @Toulon7559.
I just tried it, and after first error message trying the first script, i figured out that i had to add: "import urllib.request".
Then i got another error, and now i´m stuck.
  File "feinstaubstep1.py", line 20, in <module>
  File "/usr/lib/python3.5/json/__init__.py", line 312, in loads
    s.__class__.__name__))
TypeError: the JSON object must be str, not 'bytes'
i´m using python 3.5.3
I found this https://github.com/llSourcell/antivirus_demo/issues/3, and exactly this helped me.
Now my Script looks like:
#!/usr/bin/python
import json
import urllib
import dicttoxml
page = urllib.request.urlopen('http://192.168.178.71/data.json')
content_test = page.read().decode('utf-8')
print(obj_test)
print(xml_test)
xml_output = open("xml_sds011_upload1.xml",'wb')
xml_output.close()
import json
import pprint
    data = json.load(j)
print(data)
pprint.pprint(data)
print(xml_test2)
xml_output = open("xml_sds011_upload2.xml",'wb')
xml_output.close()
#import ftplib
#import os
#def upload(ftp, file):
#    ext = os.path.splitext(file)[1]
#    if ext in (".txt", ".htm", ".html"):
#        ftp.storlines("STOR " + file, open(file))
#    else:
#        ftp.storbinary("STOR " + file, open(file, "rb"), 1024)
#ftp = ftplib.FTP("<adress>")
#ftp.login("<login>", "<pass>")
#upload(ftp, "json_sds011_upload2.json")
#upload(ftp, "xml_sds011_upload2.xml")
I Commented the ftp part out, cause the Script runs on same RPI like my domoticz. It writes me 4 files
Now trying to get the second script working. I just put the Script as lua event into domotictz and get an error in the log:
2018-02-26 22:35:00.436 LUA: Reading values from: 'http://192.168.178.74/home/domoticz/scripts/python/feinstaub/xml_sds011_upload2.xml'
2018-02-26 22:35:00.475 LUA: SDS011-string =
2018-02-26 22:35:00.475 LUA: Bad XML status read - info NOT updated
My Script:
   f:close()
   if flatten  then
   return s
debug = true
Aussensensor = 89 -- Virtual device for DHT22, temp + baro
Feinstaub_PM2 = 88 -- Virtual device for SDS PM2.5 [= SDS_P2 in file], custom sensor
Feinstaub_PM10 = 87 -- Virtual device for SDS PM10  [= SDS_P1 in file], custom sensor
--Device_IP = "xxxx.nl" -- if you read from a remote website xxxx.nl
Device_IP = "192.168.178.74/home/domoticz/scripts/python/feinstaub" --if you read from your local Domoticz@Raspberry
    print(s1)
    print(t1)
    print(s2)
    print(t2)
    print(s3)
    print(t3)
    print(s4)
    print(t4)
    print(p1)
    print(p2)
    print(p3)
    print(p4)
    print(SDS_P1)
    print(SDS_P2)
    print(DHT_T)
    print(DHT_H)
    commandArray[1] = {['UpdateDevice'] = Aussensensor.."|0|"..DHT_T..";"..DHT_H..";1"}  -- send updated values to Domoticz
    commandArray[2] = {['UpdateDevice'] = Feinstaub_PM2.."|0|"..SDS_P2}  -- send updated value for PM2.5 to Domoticz
    commandArray[3] = {['UpdateDevice'] = Feinstaub_PM10.."|0|"..SDS_P1}  -- send updated value for PM10 to Domoticz
What happened?
Toulon7559
:-( Different versions of Python sometimes cause trouble ....
Looking at the error report IMHO you should look at the Device_IP:
is in line 39 the path towards the XML-file correct?
The scriptline looking for the XML-String obviously looks for the occurrence of <root> in the XML-file, and apparently not finding.
Double-check also the contents of the XML-file.
It should look like
<?xml version="1.0" encoding="UTF-8" ?><root><max_micro type="str">26645</max_micro><temperature type="str">19.20</temperature><software_version type="str">NRZ-2017-099</software_version><age type="str">36</age><SDS_P1 type="str">6.35</SDS_P1><humidity type="str">41.50</humidity><min_micro type="str">243</min_micro><samples type="str">587059</samples><SDS_P2 type="str">5.20</SDS_P2><signal type="str">-73</signal></root>
matzeb74
Post by matzeb74 »
The path to my xml is right. my xml is in /home/domoticz/scripts/python/feinstaub and the ip is the ip from my rpi
My xml file looks like:
<?xml version="1.0" encoding="UTF-8" ?><root><min_micro type="str">230</min_micro><age type="str">10</age><SDS_P2 type="str">3.83</SDS_P2><max_micro type="str">25769</max_micro><humidity type="str">34.00</humidity><software_version type="str">NRZ-2017-099</software_version><samples type="str">615520</samples><signal type="str">-70</signal><temperature type="str">1.40</temperature><SDS_P1 type="str">4.27</SDS_P1></root>
matzeb74
Post by matzeb74 »
I got the Error!!?!
I tried to upload the xml files to my external root server and point the script to there, and it works. So calling the file from the same RPI must be different i think.
Toulon7559
;-) ;-) Always those puzzles ........
The construction you used to read the file within your RPI looked OK, but apparently still something amiss.
:-( Have now same kind of problem on next part of the trajectory:
- both virtual sensors in Domoticz for dust are identical technical layout [singlefield, custom sensor]
- display etc. in Domoticz in widgets and in svalues is OK
- reading by script of value for PM2.5 is OK
- reading by same script using comparable line for PM10 results in report that value is nil [?????], although certainly the value is not nil
Headscratching to find the differences .....
[;-) Probably when solution has been found, it is an aspect of the kind 'Of course .....']
Addition 27th of Feb:
pragmatic, quick & dirty, temporary solution is that the lua-script from this message is extended to do the desired job with the available data from SDS011 and DHT22 .....
matzeb74
Post by matzeb74 »
Mine runs with xml Upload to my root-server and reload via the Lua script into domoticz perfectly. Fetching the xml file local will not work for me. If i try this, i get no data.
Now i tried something:
I just put the URL from Remote Site into Local.
2018-02-27 22:44:34.811 LUA: Reading values from: 'http://beliarsblog.de/xml_sds011_upload2.xml'
2018-02-27 22:44:34.926 LUA: SDS011-string =
2018-02-27 22:44:34.926 LUA: Bad XML status read - info NOT updated
If i use the same URL for external request:
2018-02-27 22:45:00.490 LUA: Reading values from: 'http://beliarsblog.de/xml_sds011_upload2.xml'
2018-02-27 22:45:00.645 LUA: SDS011-string = 13.9061680522.231232301.20-6825723NRZ-2017-09928.70
2018-02-27 22:45:00.645 LUA: 115
2018-02-27 22:45:00.645 LUA: 139
2018-02-27 22:45:00.645 LUA: 46
2018-02-27 22:45:00.645 LUA: 70
2018-02-27 22:45:00.645 LUA: 210
2018-02-27 22:45:00.645 LUA: 238
2018-02-27 22:45:00.645 LUA: 382
2018-02-27 22:45:00.645 LUA: 408
2018-02-27 22:45:00.645 LUA: 134
2018-02-27 22:45:00.645 LUA: 65
2018-02-27 22:45:00.645 LUA: 234
2018-02-27 22:45:00.645 LUA: 403
2018-02-27 22:45:00.645 LUA: 22.23
2018-02-27 22:45:00.645 LUA: 13.9
2018-02-27 22:45:00.645 LUA: 1.2
2018-02-27 22:45:00.645 LUA: 28.7
2018-02-27 22:45:00.645 LUA: Temp/Hum = '1.2/28.7'
2018-02-27 22:45:00.645 LUA: PM2.5 = '13.9'
2018-02-27 22:45:00.645 LUA: PM10 = '22.23'
2018-02-27 22:45:00.647 EventSystem: Script event triggered: Feinstaub
PieterS
Domoticz version: 2024.7
Post by PieterS »
Strugling with same issue. How to upload data from my Luftdatensensor to Domoticz.
Did anyone have success and can you write an HowTo? This thread is not clear to me.
Succeeded to upload straight into my own InfluxDB. Or is there a way to import from InfluxDB into the database of Domoticz? :?
Thanks in advance! :D
Synology with Domoticz build (V2024.7) in Docker
Toulon7559
@Matzeb74
Looking at your result for the External Request you now get all info desired!
Same 'practical' method I presently use:
- first, make XML-files and upload XML-files to (remote) server
- second, read back and dissect for application of values
Locally reading the xml-file caused me (too many) headaches as well:
line 39 of the second script should do that job, but (during my experiments) occasionally also refuses for no clear reason.
;-) Then you accept 'less logical' solutions like uploading more remote and reading back.
Wondering what happens if you locally upload to a different directory at the Raspberry, and then read back.
The problem seems to be something very subtle in the handling of files .........
The present 'solution' it is a very big detour to get from the dustsensor-values into Domoticz, but who knows a practical shortcut?
Toulon7559
Application of the InFluxDB for Domoticz is described in https://www.domoticz.com/wiki/HttpLink
At first sight does not look 'simple & short' ........
Involver
Domoticz version: 3.4834
Post by Involver »
Hi All,
I have converted a script I found elsewhere (I'm by no means a Python expert!) and that works for me. I have 1 sensor for now and in Domoticz I have added two custom sensors (one for 2,5um and one for 10um readings). In the script you need to change the variables to match your setup, see the comments in the script.
First get the required components:
sudo apt install git-core python-serial python-enum
Then you need to add this script to /home/pi/domoticz/scripts/pyhton:
#!/usr/bin/python
# coding=utf-8
# "DATASHEET": http://cl.ly/ekot
# https://gist.github.com/kadamski/92653913a53baf9dd1a8
from __future__ import print_function
import serial, struct, sys, time, json, urllib
DEBUG = 0
CMD_MODE = 2
CMD_QUERY_DATA = 4
CMD_DEVICE_ID = 5
CMD_SLEEP = 6
CMD_FIRMWARE = 7
CMD_WORKING_PERIOD = 8
MODE_ACTIVE = 0
MODE_QUERY = 1
# domoticz values, pls fill in your device ID for 2,5 and 10 um and domoticz IP and port
IDX25 = 197
IDX10 = 198
DOMOTICZ = 'http://10.11.12.23:8080'
# get your tty device ID using dmesg command first
ser = serial.Serial()
ser.port = "/dev/ttyUSB1"
ser.baudrate = 9600
ser.open()
ser.flushInput()
byte, data = 0, ""
def dump(d, prefix=''):
    print(prefix + ' '.join(x.encode('hex') for x in d))
def construct_command(cmd, data=[]):
    assert len(data) <= 12
    data += [0,]*(12-len(data))
    checksum = (sum(data)+cmd-2)%256
    ret = "\xaa\xb4" + chr(cmd)
    ret += ''.join(chr(x) for x in data)
    ret += "\xff\xff" + chr(checksum) + "\xab"
    if DEBUG:
        dump(ret, '> ')
    return ret
def process_data(d):
    r = struct.unpack('<HHxxBB', d[2:])
    pm25 = r[0]/10.0
    pm10 = r[1]/10.0
    checksum = sum(ord(v) for v in d[2:8])%256
    return [pm25, pm10]
    #print("PM 2.5: {} μg/m^3  PM 10: {} μg/m^3 CRC={}".format(pm25, pm10, "OK" if (checksum==r[2] and r[3]==0xab) else "NOK"))
def process_version(d):
    r = struct.unpack('<BBBHBB', d[3:])
    print("Y: {}, M: {}, D: {}, ID: {}, CRC={}".format(r[0], r[1], r[2], hex(r[3]), "OK" if (checksum==r[4] and r[5]==0xab) else "NOK"))
def read_response():
    byte = 0
    while byte != "\xaa":
        byte = ser.read(size=1)
    d = ser.read(size=9)
    if DEBUG:
        dump(d, '< ')
    return byte + d
def cmd_set_mode(mode=MODE_QUERY):
    ser.write(construct_command(CMD_MODE, [0x1, mode]))
    read_response()
def cmd_query_data():
    ser.write(construct_command(CMD_QUERY_DATA))
    d = read_response()
    values = []
    if d[1] == "\xc0":
        values = process_data(d)
    return values
def cmd_set_sleep(sleep=1):
    mode = 0 if sleep else 1
    ser.write(construct_command(CMD_SLEEP, [0x1, mode]))
    read_response()
def cmd_set_working_period(period):
    ser.write(construct_command(CMD_WORKING_PERIOD, [0x1, period]))
    read_response()
def cmd_firmware_ver():
    ser.write(construct_command(CMD_FIRMWARE))
    d = read_response()
    process_version(d)
def cmd_set_id(id):
    id_h = (id>>8) % 256
    id_l = id % 256
    ser.write(construct_command(CMD_DEVICE_ID, [0]*10+[id_l, id_h]))
    read_response()
if __name__ == "__main__":
    while True:
        cmd_set_sleep(0)
        cmd_set_mode(10);
        for t in range(4):
            values = cmd_query_data();
            if values is not None:
                print("PM2.5: ", values[0], ", PM10: ", values[1])
                time.sleep(2)
# Disabled the ## lines since no need for output to file as in original script
        # open stored data
##        with open('/home/pi/domoticz/scripts/python/data/aqi.json') as json_data:
##            data = json.load(json_data)
        # check if length is more than 100 and delete first element
##        if len(data) > 100:
##            data.pop(0)
        # append new values
##        data.append({'pm25': values[0], 'pm10': values[1], 'time': time.strftime("%d.%m.%Y %H:%M:%S")})
	# post it to domoticz device
	httpresponse = urllib.urlopen(str(DOMOTICZ)+"/json.htm?type=command&param=udevice&idx="+str(int(IDX25))+"&nvalue=0&svalue=" + str(values[0]))
	httpresponse = urllib.urlopen(str(DOMOTICZ)+"/json.htm?type=command&param=udevice&idx="+str(int(IDX10))+"&nvalue=0&svalue=" + str(values[1]))
        # save it
##       with open('/home/pi/domoticz/scripts/python/data/aqi.json', 'w') as outfile:
##            json.dump(data, outfile)
        print("Going to sleep for 5min...")
        cmd_set_mode(0);
        cmd_set_sleep()
        time.sleep(300)
This script needs to be changed to executable:
 chmod +x aqi.py
You can manually execute:
$ ./aqi.py
Which will produce a few lines with measurements (10 seconds to make sure the air is flowing sufficiently), write the data to domoticz and than halts for 5 minutes (to save the sensor).
When done testing (everything works for you) you need to add the script to the crontab:
$ crontab -e
... and add the following to the end:
@reboot cd /home/pi/domoticz/scripts/python/ && ./aqi.py
That should do it...
Domoticz - RPi - RFXCom - KaKu - Synology - HikVision - Oregon Scientific - YouLess - Anna
matzeb74
Post by matzeb74 »
F**k
Suddenly i got following Error. But i changed nothing... :
2018-07-03 20:35:05.770 Status: LUA: Reading values from: 'http://beliarsblog.de/xml_sds011_upload2.xml'
2018-07-03 20:35:05.976 Status: LUA: SDS011-string = <?xml version="1.0" encoding="UTF-8" ?><root><software_version type="str">NRZ-2018-103</software_version><min_micro type="str">228</min_micro><signal type="str">-59</signal><SDS_P1 type="str">520.63</SDS_P1><max_micro type="str">25862</max_micro><age type="str">101</age><samples type="str">620823</samples><SDS_P2 type="str">313.17</SDS_P2></root>
2018-07-03 20:35:05.976 Status: LUA: 174
2018-07-03 20:35:05.976 Status: LUA: 199
2018-07-03 20:35:05.976 Status: LUA: 308
2018-07-03 20:35:05.976 Status: LUA: 333
2018-07-03 20:35:05.976 Status: LUA: 193
2018-07-03 20:35:05.976 Status: LUA: 327
2018-07-03 20:35:05.976 Error: EventSystem: in Feinstaub: [string "---------------------------------------------..."]:80: attempt to perform arithmetic on global 's3' (a nil value)
assenzuid
Post by assenzuid »
I have created a dummy device and some virtual sensors and use a LUA script.
local FQDN = 'IP DOMOTICZ'
        active = true,
                timer = { 'every minute' },
                httpResponses = { 'luftdatenRetrieved' } -- matches callback string below
                if (item.isTimer) then
                        domoticz.openURL({
                                url = 'http://' .. FQDN .. '/data.json',
                                method = 'GET',
                                callback = 'luftdatenRetrieved'
                elseif (item.isHTTPResponse) then
                        if (item.ok and item.isJSON) then -- statusCode == 2xx
                                if tonumber(item.json.age) < 60 then
-- 1: SDS_P1 PM10, 2: SDS_P2 PM2.5, 3: DHT22 temp, 4: DHT22 hum, 5: BME280 temp, 6: BME280 hum, 7: BME280 baro
                                        domoticz.devices('Luftdaten PM10').updateCustomSensor(item.json.sensordatavalues[1].value)
                                        domoticz.devices('Luftdaten PM2.5').updateCustomSensor(item.json.sensordatavalues[2].value)
                                        domoticz.devices('Luftdaten DHT22').updateTempHum(item.json.sensordatavalues[3].value,item.json.sensordatavalues[4].value,0)
                                        domoticz.devices('Luftdaten BME280').updateTempHumBaro(item.json.sensordatavalues[5].value,item.json.sensordatavalues[6].value,0,(item.json.sensordatavalues[7].value/100),0)
                                -- oops
                                domoticz.log('Error fetching Luftdaten data', domoticz.LOG_ERROR)
                                domoticz.log(item.data, domoticz.LOG_ERROR)
I'm also publishing the valuses at my site.
http://emmenzuidwest.nl/weather/index.p ... #data-area
Toulon7559
That's a nice short lua-script!
;-) Something for ToDo-list.
poostrom
Domoticz version: Latest
Post by poostrom »
Hi guys,
Another way of doing this, via bash script on raspberry.
You need a recent OS and install jq ( sudo apt install jq ).
If you create custom sensors for the different value's (10PPM, 2.5PPM etc) and fill the right IDX's from Domoticz in the script...
All value's that are being exported in the JSON output from the dustsensor are loaded into an array, so you can always get any info coming from the dustsensor. See script for the example. I only use the PPM values right now because I got a faulty BME280 from China...
Crontab the file to run every x minutes..
Good luck!
Regards,
Patrick
#!/bin/bash
# Settings
DOMO_IP="192.168.200.15"          # Domoticz IP adres
DOMO_PORT="8080"                  # Domoticz port
FIJNSTOFSENSOR="192.168.200.135"  # Fijnstofsensor IP adres
SDS10IDX="5487"                   # IDX in domoticz voor PM10
SDS25IDX="5488"                   # IDX in domoticz voor PM2.5
# Laad alle waarden in een array
mapfile -t FIJNSTOF < <(curl -s $FIJNSTOFSENSOR/data.json | jq -r '.sensordatavalues[].value')
declare -p FIJNSTOF > /dev/null
# Stuur data naar domoticz
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$SDS10IDX&nvalue=0&svalue=${FIJNSTOF[0]}" > /dev/null 2>&1
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$SDS25IDX&nvalue=0&svalue=${FIJNSTOF[1]}" > /dev/null 2>&1
rene2716
Post by rene2716 »
hi, works great, can you add the syntax for putting dht22 data in a temp/hum sensor also?
thanks
René
poostrom
Post by poostrom »
This is working when you have a BME280 attached as well:
#!/bin/bash
# Settings
TEMPHUMBARO="5598"                # IDX in domoticz voor BME280
BARO=$(echo -e scale=0 "\n" ${FIJNSTOF[4]} \/ 100|bc -l)
curl -s -i -H "Accept: application/json" "http://$DOMO_IP:$DOMO_PORT/json.htm?type=command&param=udevice&idx=$TEMPHUMBARO&nvalue=0&svalue=${FIJNSTOF[2]};${FIJNSTOF[3]};0;$BARO;0" > /dev/null  2>&1
