Aqara wall plug
slydiman
Aqara wall plug
Post by slydiman »
I have installed the Aqara wall plug (ZigBee), model QBCZ11LM.
I don't see it in Domoticz.
It looks like that plug reports the following json:
{"cmd":"read_ack","model":"","sid":"***","short_id":***,"data":"{\"voltage\":3600}"}
Yes, the model is empty. I don't know how to correctly handle it.
Any ideas?
ak97
Domoticz version: latest
Re: Aqara wall plug
Post by ak97 »
I have same problem with new Aqara wall switches !
2018-02-03 17:31:56.907 XiaomiGateway: unhandled model:
2018-02-03 17:31:56.907 {"cmd":"read_ack","model":"","sid":"158d0001f99222","short_id":53738,"data":"{\"voltage\":3600,\"channel_0\":\"on\"}"}
2018-02-03 17:31:56.907 {"cmd":"read_ack","model":"","sid":"158d0001fa1960","short_id":53211,"data":"{\"voltage\":3600}"}
2018-02-03 17:31:56.907 {"cmd":"read_ack","model":"","sid":"158d0001fa18e7","short_id":12953,"data":"{\"voltage\":3600}"}
slydiman
Re: Aqara wall plug
Post by slydiman »
My Aqara wall switches report the correct model. The only problem is voltage 3300 which means 110%.
{"cmd":"read_ack","model":"ctrl_neutral1","sid":"***","short_id":32104,"data":"{\"voltage\":3300,\"channel_0\":\"off\"}"}
{"cmd":"read_ack","model":"ctrl_neutral2","sid":"***","short_id":4179,"data":"{\"voltage\":3300,\"channel_0\":\"off\",\"channel_1\":\"off\"}"}
Probably the problem is Xiaomi Gateway firmware.
It looks like a bug in the developer protocol.
Let's wait for the firmware update...
ak97
Re: Aqara wall plug
Post by ak97 »
I have two versions of Aqara wall switches:
1) without zero line (For example - QBKG04LM)
2) with zero line (For example - QBKG11LM)
Aqara switches without zero line (1) work correctly
But Aqara switches with zero line (2) have a support problem with domoticz
Luis97
Re: Aqara wall plug
Post by Luis97 »
Same problem, the wall plug dont appear in the list.
Chatissimus
Domoticz version: 4.10717
Re: Aqara wall plug
Post by Chatissimus »
Hi Slydiman,
is your wall plug this one ?
https://xiaomi-mi.com/sockets-and-senso ... e-version/
slydiman
Re: Aqara wall plug
Post by slydiman »
Yes, exactly.
vdbjimmy
Re: Aqara wall plug
Post by vdbjimmy »
Same problem here. I bought 2 wall plugs QBKG11LM and they are not visible in domoticz. I updated to the last beta version 3.9439 an it is still the same.
Have you succeeded in getting this verson of the wall plugs visible in Domoticz? Thank you.
DAVIZINHO
Re: Aqara wall plug
Post by DAVIZINHO »
WOW!, not works??? :-(
i bought one the last week and i thought it will works :-(
DAVIZINHO
Re: Aqara wall plug
Post by DAVIZINHO »
Hello again.
I have this wall plug zigbee:
I installed it today and the domoticz detect the plug as switch type.
Works fine, no problem
But domoticz not detect the aditional device with the consumption kwh.
I have various zigbee plug, and allways detects 2 devices.
any idea??
1981nick1981
Re: Aqara wall plug
Post by 1981nick1981 »
The problem is also with the new aqara cube. Domoticz recognizes the model but it is not visible between the devices.
