Selector Switch operations
Jem101
Post by Jem101 »
My apologies as this is probably a very simple thing to do but I've not found an easy way of doing this.
I have a number of 'push on' switches, five in total, lets call them 'Switch 1', 'Switch 2' etc. What I want to do is create a dummy selector switch with five settings such that if I press one of the options on it, then the corresponding Switch 1 etc. is triggered.
I'm sure it's trivially easy to do using Lua or (even better) dzVents but I've not been able to work out how to read the status change of the selector switch (let's call that 'Main Switch') and based on that, trigger the matching push-on switch.
Any hints or advise would be gratefully received.
Many thanks in advance
I firmly believe in having an open mind - although not so open that your brain falls out!
- sometimes attributed to Carl Sagan, but the original quote is much older than that
emme
Domoticz version: latest
Re: Selector Switch operations
Post by emme »
I thin you won't need to create a selector that act a pushbutton that act something else
let's have the selector act streight the action you need....
then... you probably want (to simulate a pushbutton) that once pressed the selector will return to off position.
Well, I do have few scenarios like this...
example: SkyQ decoder, my selector uses both commands and shortcuts
the configuration of the switch will trigger an action (in my case a bash/python script)
and to be able to move back the selector to 0 I use a dzScript
	active = true,
	on = { devices = {'skyQ'},
	execute = function(dz, devVol)
           devVol.switchOff().afterSec(2).checkFirst().silent()
hope this would help
ciao
M
"We always done this way"
