https://nl.aliexpress.com/item/F51-Wire ... 0.0.bqhmkd
I want to use this in domoticz and I want to switch a lamp with it.
When I press this button I see a in the log in domiticz:
when I press it again I see:2018-01-26 17:29:00.922 RFLink: 20;B7;Eurodomest;ID=03fb93;SWITCH=06;CMD=ALLON
What is the easiest way to switch a lamp X with this button?2018-01-26 17:29:28.899 RFLink: 20;B8;Eurodomest;ID=23fb93;SWITCH=05;CMD=OFF;
I have already added a dummyswitch ' eurodomest' in domoticz.
I tried it with Blocky but it will not toggle with the dummyswitch 'eurodomest'
(in blocky: if ' eurodomest' is off do set ' lamp x' on). The lamp switch only on and not out.
