RF button
remko2000
RF button
Post by remko2000 »
I have this button:
https://nl.aliexpress.com/item/F51-Wire ... 0.0.bqhmkd
I want to use this in domoticz and I want to switch a lamp with it.
When I press this button I see a in the log in domiticz:
2018-01-26 17:29:00.922 RFLink: 20;B7;Eurodomest;ID=03fb93;SWITCH=06;CMD=ALLON
when I press it again I see:
2018-01-26 17:29:28.899 RFLink: 20;B8;Eurodomest;ID=23fb93;SWITCH=05;CMD=OFF;
What is the easiest way to switch a lamp X with this button?
I have already added a dummyswitch ' eurodomest' in domoticz.
I tried it with Blocky but it will not toggle with the dummyswitch 'eurodomest'
(in blocky: if ' eurodomest' is off do set ' lamp x' on). The lamp switch only on and not out.
remko2000
Re: RF button
Post by remko2000 »
Nobody?
midomot
Re: RF button
Post by midomot »
Hello
I assume it did not work when you authorized new devices then pushed the button, i.e. no new device created ?
To me it sounds like Domoticz/RFink sees the command, but you created yourself a device- which is then stand-alone.
I believe what you need is Domoticz/RFlink to create a new device when you push the button
Have you tried teaching the Rflink the signals sent by your RF button ?
Here's how I've done it for this cheap aliexpress remote, I now have 5 on/off switches in domoticz
First hook up your RFlink to your laptop/desktop, launch the RFlink loader then follow instructions as described here:
www.rflink.nl/blog2/faq
You need to scroll to the section called RFlink 'RF Signal Learning' mechanism
After applying the procedure, hook up your RFlink back to your Domoticz hardware, authorize new devices
When you push the button, Domoticz should detect it (through RFlink that learnt it) and then you can add it from the devices section
Good luck, let us know how it went !
