ESPEasy LED dimming with LUA
MikeF
Domoticz version: V2022.2
Post by MikeF »
I'm using the following LUA script for dimming an LED strip connected to an ESP8266 running ESPEasy:
-- LED dimmer script script using ESPEasy
DomDevice = 'ESP_dimmer';
IP = 'xxxx';
PIN = "xx";
if devicechanged[DomDevice] then
   if(devicechanged[DomDevice]=='Off') then
		print ("OFF dim = "..uservariables['dimmer']);
		CalcValue = 0;
   	else if(devicechanged[DomDevice]=='On') then
   		DomValue = uservariables['dimmer'];
        print ("ON dim = "..uservariables['dimmer']);
        CalcValue = DomValue;
    	print("Other");
        DomValue = otherdevices_svalues[DomDevice];
        CalcValue = math.floor(DomValue / 100 * 1023);
        commandArray['Variable:dimmer'] = tostring(CalcValue);
        print ("dim Level = "..uservariables['dimmer']);
   	runcommand = "curl 'http://" .. IP .. "/control?cmd=PWM,"  ..PIN.. "," .. CalcValue .. "'";
   	os.execute(runcommand);
	print("PWM value= "..CalcValue);
This works well for me, and restores the last dim value if I switch off and back on by clicking the device's icon in Domoticz.
However, if I power off and then power on the ESP8266, the LED strip remains off, even though Domoticz shows the dimmer as on (and at its last dim value).
Is there any way in LUA (or dzVents) to change the device state on power on?
freijn
Domoticz version: Stable
Re: ESPEasy LED dimming with LUA
Post by freijn »
You can send 'system info' from the Easy ESP to the domoticz , as soon as something is fails you can reset the status.
MikeF
Post by MikeF »
Many thanks for this pointer!
I delved into ESPeasy Rules, and set up this simple rule:
On System#Boot do
   SendToHTTP 192.168.0.63,8080,/json.htm?type=command&param=switchlight&idx=269&switchcmd=Set%20Level&level=50
endon
(which turns it on at 50%)
haajee
Domoticz version: V4.10149
Post by haajee »
Why is it so difficult in Domoticz to add a dimmer from ESPEasy... I have a dimmer what would work perfectly with PWM commands. But integration in Domoticz looks like a nogo.
A copy and paste the script aboven but get contineusly a error:
2019-09-05 13:12:20.696 Status: LUA: Other
2019-09-05 13:12:20.696 Error: EventSystem: in v3-berging: [string "--..."]:64: attempt to call global 'toString' (a nil value)
How could i get my dimmer working in domoticz?? :(
