-- LED dimmer script script using ESPEasy
DomDevice = 'ESP_dimmer';
IP = 'xxxx';
PIN = "xx";
if devicechanged[DomDevice] then
if(devicechanged[DomDevice]=='Off') then
print ("OFF dim = "..uservariables['dimmer']);
CalcValue = 0;
else if(devicechanged[DomDevice]=='On') then
DomValue = uservariables['dimmer'];
print ("ON dim = "..uservariables['dimmer']);
CalcValue = DomValue;
print("Other");
DomValue = otherdevices_svalues[DomDevice];
CalcValue = math.floor(DomValue / 100 * 1023);
commandArray['Variable:dimmer'] = tostring(CalcValue);
print ("dim Level = "..uservariables['dimmer']);
runcommand = "curl 'http://" .. IP .. "/control?cmd=PWM," ..PIN.. "," .. CalcValue .. "'";
os.execute(runcommand);
print("PWM value= "..CalcValue);
return commandArrayHowever, if I power off and then power on the ESP8266, the LED strip remains off, even though Domoticz shows the dimmer as on (and at its last dim value).
Is there any way in LUA (or dzVents) to change the device state on power on?
