Plugins are disabled?
Posted: Friday 12 January 2018 13:37
After an update the python plugins are not working and not appearing in the hardware list.
Have they been disabled again?
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
Yep... I compiled it myselfToolman wrote: Friday 12 January 2018 13:57 I'm running 3.8805 and Python plugins are not running. So I've got the same problem as blauwebuis.
@blauwebuis: did you use the prebuilt beta?
@Siewert308SW: did you compile the source yourself?
That probably explains the difference between your version and mine.
hhmmmm... correct me if i'm wrong but latest beta is the same as the one we compile.Toolman wrote: Friday 12 January 2018 14:01That probably explains the difference between your version and mine.
The difference is due to different build settings. When downloading from source, and just configured with "cmake .", python is enabled by default. Why it's not enabled in the latest prebuilt binary, I have no idea...Siewert308SW wrote: Friday 12 January 2018 14:04hhmmmm... correct me if i'm wrong but latest beta is the same as the one we compile.Toolman wrote: Friday 12 January 2018 14:01That probably explains the difference between your version and mine.
I mean, if you download the latest beta while i compile it should be the same.
There is one differnce, if somebody does a commit and i recompile it then i'm up to date while the precompiled can take up to one hour to be online.
Prebuild is NOT the same as the only you compile yourself.Siewert308SW wrote: Friday 12 January 2018 14:04hhmmmm... correct me if i'm wrong but latest beta is the same as the one we compile.Toolman wrote: Friday 12 January 2018 14:01That probably explains the difference between your version and mine.
True...EddyG wrote: Monday 15 January 2018 10:20Prebuild is NOT the same as the only you compile yourself.Siewert308SW wrote: Friday 12 January 2018 14:04hhmmmm... correct me if i'm wrong but latest beta is the same as the one we compile.Toolman wrote: Friday 12 January 2018 14:01
Libs might differ, OpenZwave might not be present. etc....
andcat /etc/os-release
Perhpas we could compare results ald find a hint?apt list --installed| fgrep -i python
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
dh-python/oldstable,now 1.20141111-2 all [installed,automatic]
libboost-mpi-python-dev/oldstable,now 1.55.0.2 armhf [installed,automatic]
libboost-mpi-python1.55-dev/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libboost-mpi-python1.55.0/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libboost-python-dev/oldstable,now 1.55.0.2 armhf [installed,automatic]
libboost-python1.55-dev/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libboost-python1.55.0/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libpython-dev/oldstable,now 2.7.9-1 armhf [installed,automatic]
libpython-stdlib/oldstable,now 2.7.9-1 armhf [installed,automatic]
libpython2.7/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython2.7-dev/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython2.7-minimal/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython2.7-stdlib/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython3-all-dbg/oldstable,now 3.4.2-2 armhf [installed]
libpython3-all-dev/oldstable,now 3.4.2-2 armhf [installed]
libpython3-dbg/oldstable,now 3.4.2-2 armhf [installed]
libpython3-dev/oldstable,now 3.4.2-2 armhf [installed]
libpython3-stdlib/oldstable,now 3.4.2-2 armhf [installed]
libpython3.2/oldstable,now 3.2.4-1+b1 armhf [installed]
libpython3.3/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-dbg/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-dev/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-minimal/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-stdlib/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-testsuite/oldstable,now 3.3.5-1 all [installed]
libpython3.4/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-dbg/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-dev/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-minimal/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-stdlib/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-testsuite/oldstable,now 3.4.2-1 all [installed]
python/oldstable,now 2.7.9-1 armhf [installed]
python-apt/oldstable,now 0.9.3.12 armhf [installed,automatic]
python-apt-common/oldstable,now 0.9.3.12 all [installed,automatic]
python-chardet/oldstable,now 2.3.0-1 all [installed,automatic]
python-colorama/oldstable,now 0.3.2-1 all [installed,automatic]
python-distlib/oldstable,now 0.1.9-1 all [installed,automatic]
python-html5lib/oldstable,now 0.999-3 all [installed,automatic]
python-jinja2/oldstable,now 2.7.3-1 all [installed]
python-markupsafe/oldstable,now 0.23-1 armhf [installed,automatic]
python-minimal/oldstable,now 2.7.9-1 armhf [installed,automatic]
python-ndg-httpsclient/oldstable,now 0.3.2-1 all [installed,automatic]
python-openssl/oldstable,now 0.13.1-2 armhf [installed,automatic]
python-pip/oldstable,now 1.5.6-5 all [installed]
python-pkg-resources/oldstable,now 5.5.1-1 all [installed,automatic]
python-psutil/oldstable,now 2.1.1-1 armhf [installed]
python-pyasn1/oldstable,now 0.1.7-1 all [installed,automatic]
python-requests/oldstable,now 2.4.3-6 all [installed,automatic]
python-rpi.gpio/oldstable,now 0.6.3~jessie-1 armhf [installed]
python-serial/oldstable,now 2.6-1.1 all [installed]
python-setuptools/oldstable,now 5.5.1-1 all [installed,automatic]
python-six/oldstable,now 1.8.0-1 all [installed,automatic]
python-smbus/oldstable,now 3.1.1+svn-2 armhf [installed]
python-support/oldstable,now 1.0.15 all [installed,automatic]
python-urllib3/oldstable,now 1.9.1-3 all [installed,automatic]
python-wheel/oldstable,now 0.24.0-1 all [installed,automatic]
python-xmltodict/oldstable,now 0.9.0-1 all [installed]
python3/oldstable,now 3.4.2-2 armhf [installed]
python3-minimal/oldstable,now 3.4.2-2 armhf [installed,automatic]
python3.2/oldstable,now 3.2.4-1+b1 armhf [installed,automatic]
python3.2-minimal/oldstable,now 3.2.4-1+b1 armhf [installed,automatic]
python3.4/oldstable,now 3.4.2-1 armhf [installed,automatic]
python3.4-dev/oldstable,now 3.4.2-1 armhf [installed,automatic]
python3.4-minimal/oldstable,now 3.4.2-1 armhf [installed,automatic]
WARNING: apt does not have a stable CLI interface yet. Use with caution in scripts.
idle-python2.7/oldstable,now 2.7.9-2+deb8u1 all [installed,automatic]
idle-python3.4/oldstable,now 3.4.2-1 all [installed,automatic]
libboost-python-dev/oldstable,now 1.55.0.2 armhf [installed]
libpython3-dev/oldstable,now 3.4.2-2 armhf [installed,automatic]
libpython3-stdlib/oldstable,now 3.4.2-2 armhf [installed,automatic]
libpython3.4-dev/oldstable,now 3.4.2-1 armhf [installed,automatic]
libpython3.4-minimal/oldstable,now 3.4.2-1 armhf [installed,automatic]
libpython3.4-stdlib/oldstable,now 3.4.2-1 armhf [installed,automatic]
python-blinker/oldstable,now 1.3.dfsg2-1 all [installed,automatic]
python-bluez/oldstable,now 0.20-1 armhf [installed]
python-cairo/oldstable,now 1.8.8-1 armhf [installed,automatic]
python-crypto/oldstable,now 2.6.1-5+deb8u1 armhf [installed,automatic]
python-dbus/oldstable,now 1.2.0-2+b1 armhf [installed,automatic]
python-dbus-dev/oldstable,now 1.2.0-2 all [installed,automatic]
python-dev/oldstable,now 2.7.9-1 armhf [installed]
python-dnspython/oldstable,now 1.12.0-1 all [installed,automatic]
python-flask/oldstable,now 0.10.1-2 all [installed]
python-gconf/oldstable,now 2.28.1+dfsg-1.1 armhf [installed,automatic]
python-gi/oldstable,now 3.14.0-1 armhf [installed,automatic]
python-gi-cairo/oldstable,now 3.14.0-1 armhf [installed,automatic]
python-glade2/oldstable,now 2.24.0-4 armhf [installed,automatic]
python-gnome2/oldstable,now 2.28.1+dfsg-1.1 armhf [installed,automatic]
python-gobject/oldstable,now 3.14.0-1 all [installed,automatic]
python-gobject-2/oldstable,now 2.28.6-12 armhf [installed,automatic]
python-gpiozero/now 1.3.2 all [installed,upgradable to: 1.4.0]
python-gtk2/oldstable,now 2.24.0-4 armhf [installed,automatic]
python-itsdangerous/oldstable,now 0.24+dfsg1-1 all [installed,automatic]
python-jinja2/oldstable,now 2.7.3-1 all [installed,automatic]
python-ldb/oldstable,now 2:1.1.20-0+deb8u1 armhf [installed,automatic]
python-lxml/oldstable,now 3.4.0-1 armhf [installed,automatic]
python-minecraftpi/oldstable,now 0.1.1-4 armhf [installed]
python-mosquitto/oldstable,now 1.3.4-2+deb8u1 all [installed]
python-notify/oldstable,now 0.1.1-4 armhf [installed,automatic]
python-ntdb/oldstable,now 1.0-5 armhf [installed,automatic]
python-numpy/oldstable,now 1:1.8.2-2 armhf [installed,automatic]
python-picamera/oldstable,now 1.13 armhf [installed]
python-picraft/oldstable,now 1.0 all [installed]
python-pifacecommon/oldstable,now 4.2.1-1 all [installed]
python-pifacedigitalio/oldstable,now 3.1.0-1 all [installed]
python-pigpio/oldstable,now 1.60-1 all [installed]
python-pil/oldstable,now 2.6.1-2+deb8u3 armhf [installed,automatic]
python-pygame/oldstable,now 1.9.2~pre~r3348-2~bpo8+rpi1 armhf [installed]
python-pyinotify/oldstable,now 0.9.4-1 all [installed,automatic]
python-pyorbit/oldstable,now 2.24.0-7 armhf [installed,automatic]
python-requests/oldstable,now 2.4.3-6 all [installed]
python-rtimulib/oldstable,now 7.2.1-3 armhf [installed,automatic]
python-samba/oldstable,now 2:4.2.14+dfsg-0+deb8u9 armhf [installed,automatic]
python-sense-emu/oldstable,now 1.0 all [installed]
python-sense-emu-doc/oldstable,now 1.0 all [installed]
python-sense-hat/oldstable,now 2.2.0-1 armhf [installed,automatic]
python-spidev/oldstable,now 2.0~git20150907 armhf [installed]
python-talloc/oldstable,now 2.1.2-0+deb8u1 armhf [installed,automatic]
python-tdb/oldstable,now 1.3.6-0+deb8u1 armhf [installed,automatic]
python-tk/oldstable,now 2.7.8-2 armhf [installed]
python-twython/oldstable,now 3.1.2-1 all [installed]
python-werkzeug/oldstable,now 0.9.6+dfsg-1+deb8u1 all [installed,automatic]
python-wicd/oldstable,now 1.7.2.4-4.1 all [installed,automatic]
python-xklavier/oldstable,now 0.4-4 armhf [installed,automatic]
python3-apt/oldstable,now 0.9.3.12 armhf [installed,automatic]
python3-chardet/oldstable,now 2.3.0-1 all [installed,automatic]
python3-codebug-i2c-tether/oldstable,now 0.2.3-1 all [installed]
python3-codebug-tether/oldstable,now 0.7.0-1 all [installed]
python3-colorama/oldstable,now 0.3.2-1 all [installed,automatic]
python3-debian/oldstable,now 0.1.27 all [installed,automatic]
python3-distlib/oldstable,now 0.1.9-1 all [installed,automatic]
python3-docutils/oldstable,now 0.12+dfsg-1 all [installed,automatic]
python3-flask/oldstable,now 0.10.1-2 all [installed]
python3-gi/oldstable,now 3.14.0-1 armhf [installed,automatic]
python3-gpiozero/now 1.3.2 all [installed,upgradable to: 1.4.0]
python3-html5lib/oldstable,now 0.999-3 all [installed,automatic]
python3-itsdangerous/oldstable,now 0.24+dfsg1-1 all [installed,automatic]
python3-jinja2/oldstable,now 2.7.3-1 all [installed,automatic]
python3-markupsafe/oldstable,now 0.23-1 armhf [installed,automatic]
python3-minecraftpi/oldstable,now 0.1.1-4 armhf [installed,automatic]
python3-numpy/oldstable,now 1:1.8.2-2 armhf [installed]
python3-openssl/oldstable,now 0.13.1-2 armhf [installed,automatic]
python3-pgzero/oldstable,now 1.1-1 armhf [installed]
python3-picamera/oldstable,now 1.13 armhf [installed]
python3-picraft/oldstable,now 1.0 all [installed]
python3-pifacecommon/oldstable,now 4.2.1-1 all [installed]
python3-pifacedigital-scratch-handler/oldstable,now 2.0.5-1 all [installed]
python3-pifacedigitalio/oldstable,now 3.1.0-1 all [installed]
python3-pigpio/oldstable,now 1.60-1 all [installed]
python3-pil/oldstable,now 2.6.1-2+deb8u3 armhf [installed,automatic]
python3-pip/oldstable,now 1.5.6-5 all [installed]
python3-pkg-resources/oldstable,now 5.5.1-1 all [installed,automatic]
python3-pygame/oldstable,now 1.9.2~pre~r3348-2~bpo8+rpi1 armhf [installed]
python3-pygments/oldstable,now 2.0.1+dfsg-1.1+deb8u1 all [installed,automatic]
python3-pyinotify/oldstable,now 0.9.4-1 all [installed,automatic]
python3-requests/oldstable,now 2.4.3-6 all [installed,automatic]
python3-roman/oldstable,now 2.0.0-1 all [installed,automatic]
python3-rpi.gpio/oldstable,now 0.6.3~jessie-1 armhf [installed]
python3-rtimulib/oldstable,now 7.2.1-3 armhf [installed,automatic]
python3-sense-emu/oldstable,now 1.0 all [installed]
python3-sense-hat/oldstable,now 2.2.0-1 armhf [installed,automatic]
python3-serial/oldstable,now 2.6-1.1 all [installed]
python3-setuptools/oldstable,now 5.5.1-1 all [installed,automatic]
python3-six/oldstable,now 1.8.0-1 all [installed,automatic]
python3-smbus/oldstable,now 3.1.1+svn-2 armhf [installed]
python3-sphinx/oldstable,now 1.2.3+dfsg-1 all [installed]
python3-spidev/oldstable,now 2.0~git20150907 armhf [installed]
python3-tk/oldstable,now 3.4.2-1 armhf [installed]
python3-twython/oldstable,now 3.1.2-1 all [installed]
python3-uno/oldstable,now 1:4.3.3-2+rpi4 armhf [installed]
python3-urllib3/oldstable,now 1.9.1-3 all [installed,automatic]
python3-werkzeug/oldstable,now 0.9.6+dfsg-1+deb8u1 all [installed,automatic]
python3-wheel/oldstable,now 0.24.0-1 all [installed,automatic]
