Plugins are disabled?
- Domoticz version: current
After an update the python plugins are not working and not appearing in the hardware list.
Have they been disabled again?
- Siewert308SW
- Domoticz version: Stable
Re: Plugins are disabled?
Upgrade to what?
At the moment running 3.8805 and all my plugins are running fine.
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
- rootfs @ USB HDD
- Domoticz version: V3.8805
I'm running 3.8805 and Python plugins are not running. So I've got the same problem as blauwebuis.
@blauwebuis: did you use the prebuilt beta?
@Siewert308SW: did you compile the source yourself?
- Siewert308SW
Yep... I compiled it myself
Setup:
- rootfs @ USB HDD
- rootfs @ USB HDD
That probably explains the difference between your version and mine.
- Siewert308SW
hhmmmm... correct me if i'm wrong but latest beta is the same as the one we compile.
I mean, if you download the latest beta while i compile it should be the same.
There is one differnce, if somebody does a commit and i recompile it then i'm up to date while the precompiled can take up to one hour to be online.
Setup:
- rootfs @ USB HDD
- rootfs @ USB HDD
pre-built here too.
The Smart Virtual Thermostat plugin is kinda important to me
I confirm that scripts based on virtual sensors (thermostat for instance) are disabled after a git pull to domoticz 3.8805
The difference is due to different build settings. When downloading from source, and just configured with "cmake .", python is enabled by default. Why it's not enabled in the latest prebuilt binary, I have no idea...Siewert308SW wrote: ↑Friday 12 January 2018 14:04hhmmmm... correct me if i'm wrong but latest beta is the same as the one we compile.
Regards,
M
- Siewert308SW
@moroen
Can't be, test it out true the day today.
Even if i don't compile but use the normal bash command to install all my plugins work.
I didn't test the following, at the moment i run python 3.4 while is see crash report of user who are running 3.5.
Setup:
- rootfs @ USB HDD
- rootfs @ USB HDD
The issue persists.
on my system:
python -> 2.9.7
python3 -> 3.4.2
on my system:
python -> 2.9.7
python3 -> 3.4.2
Same issue here:
python -V
Python 2.7.13
python3 -V
Python 3.5.3
python -V
Python 2.7.13
python3 -V
Python 3.5.3
- Siewert308SW
Thx for the info.
I'm just trying to rule some stuff out.
Did you also install python3-dev?
Setup:
- rootfs @ USB HDD
- rootfs @ USB HDD
All packages related to python installed here:
dh-python/stable,now 2.20170125 all [installed,automatic]
libpython-stdlib/stable,now 2.7.13-2 armhf [installed,automatic]
libpython2.7-minimal/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython2.7-stdlib/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython3-dev/stable,now 3.5.3-1 armhf [installed,automatic]
libpython3-stdlib/stable,now 3.5.3-1 armhf [installed,automatic]
libpython3.5/stable,now 3.5.3-1 armhf [installed]
libpython3.5-dev/stable,now 3.5.3-1 armhf [installed,automatic]
libpython3.5-minimal/stable,now 3.5.3-1 armhf [installed,automatic]
libpython3.5-stdlib/stable,now 3.5.3-1 armhf [installed,automatic]
python/stable,now 2.7.13-2 armhf [installed]
python-apt-common/stable,now 1.1.0~beta5 all [installed,automatic]
python-bluez/stable,now 0.22-1 armhf [installed]
python-cffi-backend/stable,now 1.9.1-2 armhf [installed,automatic]
python-chardet/stable,now 2.3.0-2 all [installed,automatic]
python-cryptography/stable,now 1.7.1-3+b2 armhf [installed,automatic]
python-enum34/stable,now 1.1.6-1 all [installed,automatic]
python-idna/stable,now 2.2-1 all [installed,automatic]
python-ipaddress/stable,now 1.0.17-1 all [installed,automatic]
python-minimal/stable,now 2.7.13-2 armhf [installed,automatic]
python-openssl/stable,now 16.2.0-1 all [installed,automatic]
python-pip-whl/stable,now 9.0.1-2+rpt1 all [installed,automatic]
python-pkg-resources/stable,now 33.1.1-1 all [installed,automatic]
python-pyasn1/stable,now 0.1.9-2 all [installed,automatic]
python-requests/stable,now 2.12.4-1 all [installed]
python-rpi.gpio/stable,now 0.6.3~stretch-1 armhf [installed]
python-setuptools/stable,now 33.1.1-1 all [installed,automatic]
python-six/stable,now 1.10.0-3 all [installed,automatic]
python-urllib3/stable,now 1.19.1-1 all [installed,automatic]
python2.7/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
python3/stable,now 3.5.3-1 armhf [installed]
python3-apt/stable,now 1.1.0~beta5 armhf [installed,automatic]
python3-cffi-backend/stable,now 1.9.1-2 armhf [installed,automatic]
python3-crypto/stable,now 2.6.1-7 armhf [installed,automatic]
python3-cryptography/stable,now 1.7.1-3+b2 armhf [installed,automatic]
python3-dbus/stable,now 1.2.4-1 armhf [installed,automatic]
python3-dev/stable,now 3.5.3-1 armhf [installed]
python3-gi/stable,now 3.22.0-2 armhf [installed,automatic]
python3-idna/stable,now 2.2-1 all [installed,automatic]
python3-keyring/stable,now 10.1-1 all [installed,automatic]
python3-keyrings.alt/stable,now 1.3-1 all [installed,automatic]
python3-minimal/stable,now 3.5.3-1 armhf [installed,automatic]
python3-pip/stable,now 9.0.1-2+rpt1 all [installed]
python3-pkg-resources/stable,now 33.1.1-1 all [installed,automatic]
python3-pyasn1/stable,now 0.1.9-2 all [installed,automatic]
python3-secretstorage/stable,now 2.3.1-2 all [installed,automatic]
python3-setuptools/stable,now 33.1.1-1 all [installed,automatic]
python3-six/stable,now 1.10.0-3 all [installed,automatic]
python3-wheel/stable,now 0.29.0-2 all [installed,automatic]
python3-xdg/stable,now 0.25-4 all [installed,automatic]
python3.5/stable,now 3.5.3-1 armhf [installed,automatic]
[EDIT] RPi3 with Stretch
Prebuild is NOT the same as the only you compile yourself.Siewert308SW wrote: ↑Friday 12 January 2018 14:04hhmmmm... correct me if i'm wrong but latest beta is the same as the one we compile.
Libs might differ, OpenZwave might not be present. etc....
python3-dev -> command not found
the only python plugin I had left, and that I just removed, was the Smart Virtual Thermostat.
- Siewert308SW
True...EddyG wrote: ↑Monday 15 January 2018 10:20Prebuild is NOT the same as the only you compile yourself.Siewert308SW wrote: ↑Friday 12 January 2018 14:04hhmmmm... correct me if i'm wrong but latest beta is the same as the one we compile.
But at the moment not running a compiled version but prebuild and it still works here.
Don't know what i'm doing different as even the prebuilds are working overhere and trying to reproduce the issue fails for me.
Setup:
- rootfs @ USB HDD
- rootfs @ USB HDD
@Siewert308SW
Could You post the results of:
(my result of "apt list --installed| fgrep -i python" is a few posts above)
my result of: "cat /etc/os-release" is:
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
andcat /etc/os-release
Perhpas we could compare results ald find a hint?apt list --installed| fgrep -i python
VERSION_ID="9"
ID=raspbian
ID_LIKE=debian
- Siewert308SW
For sure...
cat /etc/os-release:
apt list --installed| fgrep -i python:
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
dh-python/oldstable,now 1.20141111-2 all [installed,automatic]
libboost-mpi-python-dev/oldstable,now 1.55.0.2 armhf [installed,automatic]
libboost-mpi-python1.55-dev/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libboost-mpi-python1.55.0/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libboost-python-dev/oldstable,now 1.55.0.2 armhf [installed,automatic]
libboost-python1.55-dev/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libboost-python1.55.0/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libpython-dev/oldstable,now 2.7.9-1 armhf [installed,automatic]
libpython-stdlib/oldstable,now 2.7.9-1 armhf [installed,automatic]
libpython2.7/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython2.7-dev/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython2.7-minimal/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython2.7-stdlib/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython3-all-dbg/oldstable,now 3.4.2-2 armhf [installed]
libpython3-all-dev/oldstable,now 3.4.2-2 armhf [installed]
libpython3-dbg/oldstable,now 3.4.2-2 armhf [installed]
libpython3-dev/oldstable,now 3.4.2-2 armhf [installed]
libpython3-stdlib/oldstable,now 3.4.2-2 armhf [installed]
libpython3.2/oldstable,now 3.2.4-1+b1 armhf [installed]
libpython3.3/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-dbg/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-dev/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-minimal/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-stdlib/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-testsuite/oldstable,now 3.3.5-1 all [installed]
libpython3.4/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-dbg/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-dev/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-minimal/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-stdlib/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-testsuite/oldstable,now 3.4.2-1 all [installed]
python/oldstable,now 2.7.9-1 armhf [installed]
python-apt/oldstable,now 0.9.3.12 armhf [installed,automatic]
python-apt-common/oldstable,now 0.9.3.12 all [installed,automatic]
python-chardet/oldstable,now 2.3.0-1 all [installed,automatic]
python-colorama/oldstable,now 0.3.2-1 all [installed,automatic]
python-distlib/oldstable,now 0.1.9-1 all [installed,automatic]
python-html5lib/oldstable,now 0.999-3 all [installed,automatic]
python-jinja2/oldstable,now 2.7.3-1 all [installed]
python-markupsafe/oldstable,now 0.23-1 armhf [installed,automatic]
python-minimal/oldstable,now 2.7.9-1 armhf [installed,automatic]
python-ndg-httpsclient/oldstable,now 0.3.2-1 all [installed,automatic]
python-openssl/oldstable,now 0.13.1-2 armhf [installed,automatic]
python-pip/oldstable,now 1.5.6-5 all [installed]
python-pkg-resources/oldstable,now 5.5.1-1 all [installed,automatic]
python-psutil/oldstable,now 2.1.1-1 armhf [installed]
python-pyasn1/oldstable,now 0.1.7-1 all [installed,automatic]
python-requests/oldstable,now 2.4.3-6 all [installed,automatic]
python-rpi.gpio/oldstable,now 0.6.3~jessie-1 armhf [installed]
python-serial/oldstable,now 2.6-1.1 all [installed]
python-setuptools/oldstable,now 5.5.1-1 all [installed,automatic]
python-six/oldstable,now 1.8.0-1 all [installed,automatic]
python-smbus/oldstable,now 3.1.1+svn-2 armhf [installed]
python-support/oldstable,now 1.0.15 all [installed,automatic]
python-urllib3/oldstable,now 1.9.1-3 all [installed,automatic]
python-wheel/oldstable,now 0.24.0-1 all [installed,automatic]
python-xmltodict/oldstable,now 0.9.0-1 all [installed]
python3/oldstable,now 3.4.2-2 armhf [installed]
python3-minimal/oldstable,now 3.4.2-2 armhf [installed,automatic]
python3.2/oldstable,now 3.2.4-1+b1 armhf [installed,automatic]
python3.2-minimal/oldstable,now 3.2.4-1+b1 armhf [installed,automatic]
python3.4/oldstable,now 3.4.2-1 armhf [installed,automatic]
python3.4-dev/oldstable,now 3.4.2-1 armhf [installed,automatic]
python3.4-minimal/oldstable,now 3.4.2-1 armhf [installed,automatic]
Setup:
- rootfs @ USB HDD
- rootfs @ USB HDD
With the latest update my plugins are working again.
CAT OS:
VERSION_ID="8"
ID=raspbian
ID_LIKE=debian
CAT OS:
VERSION_ID="8"
ID=raspbian
ID_LIKE=debian
WARNING: apt does not have a stable CLI interface yet. Use with caution in scripts.
idle-python2.7/oldstable,now 2.7.9-2+deb8u1 all [installed,automatic]
idle-python3.4/oldstable,now 3.4.2-1 all [installed,automatic]
libboost-python-dev/oldstable,now 1.55.0.2 armhf [installed]
libpython3-dev/oldstable,now 3.4.2-2 armhf [installed,automatic]
libpython3-stdlib/oldstable,now 3.4.2-2 armhf [installed,automatic]
libpython3.4-dev/oldstable,now 3.4.2-1 armhf [installed,automatic]
libpython3.4-minimal/oldstable,now 3.4.2-1 armhf [installed,automatic]
libpython3.4-stdlib/oldstable,now 3.4.2-1 armhf [installed,automatic]
python-blinker/oldstable,now 1.3.dfsg2-1 all [installed,automatic]
python-bluez/oldstable,now 0.20-1 armhf [installed]
python-cairo/oldstable,now 1.8.8-1 armhf [installed,automatic]
python-crypto/oldstable,now 2.6.1-5+deb8u1 armhf [installed,automatic]
python-dbus/oldstable,now 1.2.0-2+b1 armhf [installed,automatic]
python-dbus-dev/oldstable,now 1.2.0-2 all [installed,automatic]
python-dev/oldstable,now 2.7.9-1 armhf [installed]
python-dnspython/oldstable,now 1.12.0-1 all [installed,automatic]
python-flask/oldstable,now 0.10.1-2 all [installed]
python-gconf/oldstable,now 2.28.1+dfsg-1.1 armhf [installed,automatic]
python-gi/oldstable,now 3.14.0-1 armhf [installed,automatic]
python-gi-cairo/oldstable,now 3.14.0-1 armhf [installed,automatic]
python-glade2/oldstable,now 2.24.0-4 armhf [installed,automatic]
python-gnome2/oldstable,now 2.28.1+dfsg-1.1 armhf [installed,automatic]
python-gobject/oldstable,now 3.14.0-1 all [installed,automatic]
python-gobject-2/oldstable,now 2.28.6-12 armhf [installed,automatic]
python-gpiozero/now 1.3.2 all [installed,upgradable to: 1.4.0]
python-gtk2/oldstable,now 2.24.0-4 armhf [installed,automatic]
python-itsdangerous/oldstable,now 0.24+dfsg1-1 all [installed,automatic]
python-jinja2/oldstable,now 2.7.3-1 all [installed,automatic]
python-ldb/oldstable,now 2:1.1.20-0+deb8u1 armhf [installed,automatic]
python-lxml/oldstable,now 3.4.0-1 armhf [installed,automatic]
python-minecraftpi/oldstable,now 0.1.1-4 armhf [installed]
python-mosquitto/oldstable,now 1.3.4-2+deb8u1 all [installed]
python-notify/oldstable,now 0.1.1-4 armhf [installed,automatic]
python-ntdb/oldstable,now 1.0-5 armhf [installed,automatic]
python-numpy/oldstable,now 1:1.8.2-2 armhf [installed,automatic]
python-picamera/oldstable,now 1.13 armhf [installed]
python-picraft/oldstable,now 1.0 all [installed]
python-pifacecommon/oldstable,now 4.2.1-1 all [installed]
python-pifacedigitalio/oldstable,now 3.1.0-1 all [installed]
python-pigpio/oldstable,now 1.60-1 all [installed]
python-pil/oldstable,now 2.6.1-2+deb8u3 armhf [installed,automatic]
python-pygame/oldstable,now 1.9.2~pre~r3348-2~bpo8+rpi1 armhf [installed]
python-pyinotify/oldstable,now 0.9.4-1 all [installed,automatic]
python-pyorbit/oldstable,now 2.24.0-7 armhf [installed,automatic]
python-requests/oldstable,now 2.4.3-6 all [installed]
python-rtimulib/oldstable,now 7.2.1-3 armhf [installed,automatic]
python-samba/oldstable,now 2:4.2.14+dfsg-0+deb8u9 armhf [installed,automatic]
python-sense-emu/oldstable,now 1.0 all [installed]
python-sense-emu-doc/oldstable,now 1.0 all [installed]
python-sense-hat/oldstable,now 2.2.0-1 armhf [installed,automatic]
python-spidev/oldstable,now 2.0~git20150907 armhf [installed]
python-talloc/oldstable,now 2.1.2-0+deb8u1 armhf [installed,automatic]
python-tdb/oldstable,now 1.3.6-0+deb8u1 armhf [installed,automatic]
python-tk/oldstable,now 2.7.8-2 armhf [installed]
python-twython/oldstable,now 3.1.2-1 all [installed]
python-werkzeug/oldstable,now 0.9.6+dfsg-1+deb8u1 all [installed,automatic]
python-wicd/oldstable,now 1.7.2.4-4.1 all [installed,automatic]
python-xklavier/oldstable,now 0.4-4 armhf [installed,automatic]
python3-apt/oldstable,now 0.9.3.12 armhf [installed,automatic]
python3-chardet/oldstable,now 2.3.0-1 all [installed,automatic]
python3-codebug-i2c-tether/oldstable,now 0.2.3-1 all [installed]
python3-codebug-tether/oldstable,now 0.7.0-1 all [installed]
python3-colorama/oldstable,now 0.3.2-1 all [installed,automatic]
python3-debian/oldstable,now 0.1.27 all [installed,automatic]
python3-distlib/oldstable,now 0.1.9-1 all [installed,automatic]
python3-docutils/oldstable,now 0.12+dfsg-1 all [installed,automatic]
python3-flask/oldstable,now 0.10.1-2 all [installed]
python3-gi/oldstable,now 3.14.0-1 armhf [installed,automatic]
python3-gpiozero/now 1.3.2 all [installed,upgradable to: 1.4.0]
python3-html5lib/oldstable,now 0.999-3 all [installed,automatic]
python3-itsdangerous/oldstable,now 0.24+dfsg1-1 all [installed,automatic]
python3-jinja2/oldstable,now 2.7.3-1 all [installed,automatic]
python3-markupsafe/oldstable,now 0.23-1 armhf [installed,automatic]
python3-minecraftpi/oldstable,now 0.1.1-4 armhf [installed,automatic]
python3-numpy/oldstable,now 1:1.8.2-2 armhf [installed]
python3-openssl/oldstable,now 0.13.1-2 armhf [installed,automatic]
python3-pgzero/oldstable,now 1.1-1 armhf [installed]
python3-picamera/oldstable,now 1.13 armhf [installed]
python3-picraft/oldstable,now 1.0 all [installed]
python3-pifacecommon/oldstable,now 4.2.1-1 all [installed]
python3-pifacedigital-scratch-handler/oldstable,now 2.0.5-1 all [installed]
python3-pifacedigitalio/oldstable,now 3.1.0-1 all [installed]
python3-pigpio/oldstable,now 1.60-1 all [installed]
python3-pil/oldstable,now 2.6.1-2+deb8u3 armhf [installed,automatic]
python3-pip/oldstable,now 1.5.6-5 all [installed]
python3-pkg-resources/oldstable,now 5.5.1-1 all [installed,automatic]
python3-pygame/oldstable,now 1.9.2~pre~r3348-2~bpo8+rpi1 armhf [installed]
python3-pygments/oldstable,now 2.0.1+dfsg-1.1+deb8u1 all [installed,automatic]
python3-pyinotify/oldstable,now 0.9.4-1 all [installed,automatic]
python3-requests/oldstable,now 2.4.3-6 all [installed,automatic]
python3-roman/oldstable,now 2.0.0-1 all [installed,automatic]
python3-rpi.gpio/oldstable,now 0.6.3~jessie-1 armhf [installed]
python3-rtimulib/oldstable,now 7.2.1-3 armhf [installed,automatic]
python3-sense-emu/oldstable,now 1.0 all [installed]
python3-sense-hat/oldstable,now 2.2.0-1 armhf [installed,automatic]
python3-serial/oldstable,now 2.6-1.1 all [installed]
python3-setuptools/oldstable,now 5.5.1-1 all [installed,automatic]
python3-six/oldstable,now 1.8.0-1 all [installed,automatic]
python3-smbus/oldstable,now 3.1.1+svn-2 armhf [installed]
python3-sphinx/oldstable,now 1.2.3+dfsg-1 all [installed]
python3-spidev/oldstable,now 2.0~git20150907 armhf [installed]
python3-tk/oldstable,now 3.4.2-1 armhf [installed]
python3-twython/oldstable,now 3.1.2-1 all [installed]
python3-uno/oldstable,now 1:4.3.3-2+rpi4 armhf [installed]
python3-urllib3/oldstable,now 1.9.1-3 all [installed,automatic]
python3-werkzeug/oldstable,now 0.9.6+dfsg-1+deb8u1 all [installed,automatic]
python3-wheel/oldstable,now 0.24.0-1 all [installed,automatic]
Users browsing this forum: Amazon [Bot], Bing [Bot] and 1 guest
