Plugins are disabled?
blauwebuis
Domoticz version: current
Post by blauwebuis »
After an update the python plugins are not working and not appearing in the hardware list.
Have they been disabled again?
Siewert308SW
Domoticz version: Stable
Re: Plugins are disabled?
Post by Siewert308SW »
Upgrade to what?
At the moment running 3.8805 and all my plugins are running fine.
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
Toolman
Domoticz version: V3.8805
Post by Toolman »
I'm running 3.8805 and Python plugins are not running. So I've got the same problem as blauwebuis.
@blauwebuis: did you use the prebuilt beta?
@Siewert308SW: did you compile the source yourself?
Siewert308SW
Toolman wrote: Friday 12 January 2018 13:57 I'm running 3.8805 and Python plugins are not running. So I've got the same problem as blauwebuis.
Yep... I compiled it myself
Setup:
- DS923+ Docker
Toolman
Post by Toolman »
Siewert308SW wrote: Friday 12 January 2018 13:59 Yep... I compiled it myself
That probably explains the difference between your version and mine.
Siewert308SW
Toolman wrote: Friday 12 January 2018 14:01
hhmmmm... correct me if i'm wrong but latest beta is the same as the one we compile.
I mean, if you download the latest beta while i compile it should be the same.
There is one differnce, if somebody does a commit and i recompile it then i'm up to date while the precompiled can take up to one hour to be online.
Setup:
- DS923+ Docker
blauwebuis
pre-built here too.
The Smart Virtual Thermostat plugin is kinda important to me :-)
nx345
Post by nx345 »
I confirm that scripts based on virtual sensors (thermostat for instance) are disabled after a git pull to domoticz 3.8805
moroen
Post by moroen »
Siewert308SW wrote: Friday 12 January 2018 14:04
The difference is due to different build settings. When downloading from source, and just configured with "cmake .", python is enabled by default. Why it's not enabled in the latest prebuilt binary, I have no idea...
Regards,
M
Siewert308SW
@moroen
Can't be, test it out true the day today.
Even if i don't compile but use the normal bash command to install all my plugins work.
I didn't test the following, at the moment i run python 3.4 while is see crash report of user who are running 3.5.
Setup:
- DS923+ Docker
blauwebuis
The issue persists.
on my system:
python -> 2.9.7
python3 -> 3.4.2
Quax1507
Post by Quax1507 »
Same issue here:
python -V
Python 2.7.13
python3 -V
Python 3.5.3
Siewert308SW
Thx for the info.
I'm just trying to rule some stuff out.
Did you also install python3-dev?
Setup:
- DS923+ Docker
Quax1507
Post by Quax1507 »
All packages related to python installed here:
dh-python/stable,now 2.20170125 all [installed,automatic]
libpython-stdlib/stable,now 2.7.13-2 armhf [installed,automatic]
libpython2.7-minimal/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython2.7-stdlib/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
libpython3-dev/stable,now 3.5.3-1 armhf [installed,automatic]
libpython3-stdlib/stable,now 3.5.3-1 armhf [installed,automatic]
libpython3.5/stable,now 3.5.3-1 armhf [installed]
libpython3.5-dev/stable,now 3.5.3-1 armhf [installed,automatic]
libpython3.5-minimal/stable,now 3.5.3-1 armhf [installed,automatic]
libpython3.5-stdlib/stable,now 3.5.3-1 armhf [installed,automatic]
python/stable,now 2.7.13-2 armhf [installed]
python-apt-common/stable,now 1.1.0~beta5 all [installed,automatic]
python-bluez/stable,now 0.22-1 armhf [installed]
python-cffi-backend/stable,now 1.9.1-2 armhf [installed,automatic]
python-chardet/stable,now 2.3.0-2 all [installed,automatic]
python-cryptography/stable,now 1.7.1-3+b2 armhf [installed,automatic]
python-enum34/stable,now 1.1.6-1 all [installed,automatic]
python-idna/stable,now 2.2-1 all [installed,automatic]
python-ipaddress/stable,now 1.0.17-1 all [installed,automatic]
python-minimal/stable,now 2.7.13-2 armhf [installed,automatic]
python-openssl/stable,now 16.2.0-1 all [installed,automatic]
python-pip-whl/stable,now 9.0.1-2+rpt1 all [installed,automatic]
python-pkg-resources/stable,now 33.1.1-1 all [installed,automatic]
python-pyasn1/stable,now 0.1.9-2 all [installed,automatic]
python-requests/stable,now 2.12.4-1 all [installed]
python-rpi.gpio/stable,now 0.6.3~stretch-1 armhf [installed]
python-setuptools/stable,now 33.1.1-1 all [installed,automatic]
python-six/stable,now 1.10.0-3 all [installed,automatic]
python-urllib3/stable,now 1.19.1-1 all [installed,automatic]
python2.7/stable,now 2.7.13-2+deb9u2 armhf [installed,automatic]
python3/stable,now 3.5.3-1 armhf [installed]
python3-apt/stable,now 1.1.0~beta5 armhf [installed,automatic]
python3-cffi-backend/stable,now 1.9.1-2 armhf [installed,automatic]
python3-crypto/stable,now 2.6.1-7 armhf [installed,automatic]
python3-cryptography/stable,now 1.7.1-3+b2 armhf [installed,automatic]
python3-dbus/stable,now 1.2.4-1 armhf [installed,automatic]
python3-dev/stable,now 3.5.3-1 armhf [installed]
python3-gi/stable,now 3.22.0-2 armhf [installed,automatic]
python3-idna/stable,now 2.2-1 all [installed,automatic]
python3-keyring/stable,now 10.1-1 all [installed,automatic]
python3-keyrings.alt/stable,now 1.3-1 all [installed,automatic]
python3-minimal/stable,now 3.5.3-1 armhf [installed,automatic]
python3-pip/stable,now 9.0.1-2+rpt1 all [installed]
python3-pkg-resources/stable,now 33.1.1-1 all [installed,automatic]
python3-pyasn1/stable,now 0.1.9-2 all [installed,automatic]
python3-secretstorage/stable,now 2.3.1-2 all [installed,automatic]
python3-setuptools/stable,now 33.1.1-1 all [installed,automatic]
python3-six/stable,now 1.10.0-3 all [installed,automatic]
python3-wheel/stable,now 0.29.0-2 all [installed,automatic]
python3-xdg/stable,now 0.25-4 all [installed,automatic]
python3.5/stable,now 3.5.3-1 armhf [installed,automatic]
[EDIT] RPi3 with Stretch
EddyG
Post by EddyG »
Prebuild is NOT the same as the only you compile yourself.
Libs might differ, OpenZwave might not be present. etc....
blauwebuis
python3-dev -> command not found
the only python plugin I had left, and that I just removed, was the Smart Virtual Thermostat.
Siewert308SW
EddyG wrote: Monday 15 January 2018 10:20
True...
But at the moment not running a compiled version but prebuild and it still works here.
Don't know what i'm doing different as even the prebuilds are working overhere and trying to reproduce the issue fails for me.
Setup:
- DS923+ Docker
Quax1507
Post by Quax1507 »
@Siewert308SW
Could You post the results of:
cat /etc/os-release
and
apt list --installed| fgrep -i python
Perhpas we could compare results ald find a hint?
(my result of "apt list --installed| fgrep -i python" is a few posts above)
my result of: "cat /etc/os-release" is:
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Siewert308SW
For sure...
cat /etc/os-release:
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
apt list --installed| fgrep -i python:
dh-python/oldstable,now 1.20141111-2 all [installed,automatic]
libboost-mpi-python-dev/oldstable,now 1.55.0.2 armhf [installed,automatic]
libboost-mpi-python1.55-dev/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libboost-mpi-python1.55.0/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libboost-python-dev/oldstable,now 1.55.0.2 armhf [installed,automatic]
libboost-python1.55-dev/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libboost-python1.55.0/oldstable,now 1.55.0+dfsg-3 armhf [installed,automatic]
libpython-dev/oldstable,now 2.7.9-1 armhf [installed,automatic]
libpython-stdlib/oldstable,now 2.7.9-1 armhf [installed,automatic]
libpython2.7/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython2.7-dev/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython2.7-minimal/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython2.7-stdlib/oldstable,now 2.7.9-2+deb8u1 armhf [installed,automatic]
libpython3-all-dbg/oldstable,now 3.4.2-2 armhf [installed]
libpython3-all-dev/oldstable,now 3.4.2-2 armhf [installed]
libpython3-dbg/oldstable,now 3.4.2-2 armhf [installed]
libpython3-dev/oldstable,now 3.4.2-2 armhf [installed]
libpython3-stdlib/oldstable,now 3.4.2-2 armhf [installed]
libpython3.2/oldstable,now 3.2.4-1+b1 armhf [installed]
libpython3.3/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-dbg/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-dev/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-minimal/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-stdlib/oldstable,now 3.3.5-1 armhf [installed]
libpython3.3-testsuite/oldstable,now 3.3.5-1 all [installed]
libpython3.4/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-dbg/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-dev/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-minimal/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-stdlib/oldstable,now 3.4.2-1 armhf [installed]
libpython3.4-testsuite/oldstable,now 3.4.2-1 all [installed]
python/oldstable,now 2.7.9-1 armhf [installed]
python-apt/oldstable,now 0.9.3.12 armhf [installed,automatic]
python-apt-common/oldstable,now 0.9.3.12 all [installed,automatic]
python-chardet/oldstable,now 2.3.0-1 all [installed,automatic]
python-colorama/oldstable,now 0.3.2-1 all [installed,automatic]
python-distlib/oldstable,now 0.1.9-1 all [installed,automatic]
python-html5lib/oldstable,now 0.999-3 all [installed,automatic]
python-jinja2/oldstable,now 2.7.3-1 all [installed]
python-markupsafe/oldstable,now 0.23-1 armhf [installed,automatic]
python-minimal/oldstable,now 2.7.9-1 armhf [installed,automatic]
python-ndg-httpsclient/oldstable,now 0.3.2-1 all [installed,automatic]
python-openssl/oldstable,now 0.13.1-2 armhf [installed,automatic]
python-pip/oldstable,now 1.5.6-5 all [installed]
python-pkg-resources/oldstable,now 5.5.1-1 all [installed,automatic]
python-psutil/oldstable,now 2.1.1-1 armhf [installed]
python-pyasn1/oldstable,now 0.1.7-1 all [installed,automatic]
python-requests/oldstable,now 2.4.3-6 all [installed,automatic]
python-rpi.gpio/oldstable,now 0.6.3~jessie-1 armhf [installed]
python-serial/oldstable,now 2.6-1.1 all [installed]
python-setuptools/oldstable,now 5.5.1-1 all [installed,automatic]
python-six/oldstable,now 1.8.0-1 all [installed,automatic]
python-smbus/oldstable,now 3.1.1+svn-2 armhf [installed]
python-support/oldstable,now 1.0.15 all [installed,automatic]
python-urllib3/oldstable,now 1.9.1-3 all [installed,automatic]
python-wheel/oldstable,now 0.24.0-1 all [installed,automatic]
python-xmltodict/oldstable,now 0.9.0-1 all [installed]
python3/oldstable,now 3.4.2-2 armhf [installed]
python3-minimal/oldstable,now 3.4.2-2 armhf [installed,automatic]
python3.2/oldstable,now 3.2.4-1+b1 armhf [installed,automatic]
python3.2-minimal/oldstable,now 3.2.4-1+b1 armhf [installed,automatic]
python3.4/oldstable,now 3.4.2-1 armhf [installed,automatic]
python3.4-dev/oldstable,now 3.4.2-1 armhf [installed,automatic]
python3.4-minimal/oldstable,now 3.4.2-1 armhf [installed,automatic]
Setup:
- DS923+ Docker
blauwebuis
With the latest update my plugins are working again.
CAT OS:
VERSION_ID="8"
ID=raspbian
ID_LIKE=debian
WARNING: apt does not have a stable CLI interface yet. Use with caution in scripts.
idle-python2.7/oldstable,now 2.7.9-2+deb8u1 all [installed,automatic]
idle-python3.4/oldstable,now 3.4.2-1 all [installed,automatic]
libboost-python-dev/oldstable,now 1.55.0.2 armhf [installed]
libpython3-dev/oldstable,now 3.4.2-2 armhf [installed,automatic]
libpython3-stdlib/oldstable,now 3.4.2-2 armhf [installed,automatic]
libpython3.4-dev/oldstable,now 3.4.2-1 armhf [installed,automatic]
libpython3.4-minimal/oldstable,now 3.4.2-1 armhf [installed,automatic]
libpython3.4-stdlib/oldstable,now 3.4.2-1 armhf [installed,automatic]
python-blinker/oldstable,now 1.3.dfsg2-1 all [installed,automatic]
python-bluez/oldstable,now 0.20-1 armhf [installed]
python-cairo/oldstable,now 1.8.8-1 armhf [installed,automatic]
python-crypto/oldstable,now 2.6.1-5+deb8u1 armhf [installed,automatic]
python-dbus/oldstable,now 1.2.0-2+b1 armhf [installed,automatic]
python-dbus-dev/oldstable,now 1.2.0-2 all [installed,automatic]
python-dev/oldstable,now 2.7.9-1 armhf [installed]
python-dnspython/oldstable,now 1.12.0-1 all [installed,automatic]
python-flask/oldstable,now 0.10.1-2 all [installed]
python-gconf/oldstable,now 2.28.1+dfsg-1.1 armhf [installed,automatic]
python-gi/oldstable,now 3.14.0-1 armhf [installed,automatic]
python-gi-cairo/oldstable,now 3.14.0-1 armhf [installed,automatic]
python-glade2/oldstable,now 2.24.0-4 armhf [installed,automatic]
python-gnome2/oldstable,now 2.28.1+dfsg-1.1 armhf [installed,automatic]
python-gobject/oldstable,now 3.14.0-1 all [installed,automatic]
python-gobject-2/oldstable,now 2.28.6-12 armhf [installed,automatic]
python-gpiozero/now 1.3.2 all [installed,upgradable to: 1.4.0]
python-gtk2/oldstable,now 2.24.0-4 armhf [installed,automatic]
python-itsdangerous/oldstable,now 0.24+dfsg1-1 all [installed,automatic]
python-jinja2/oldstable,now 2.7.3-1 all [installed,automatic]
python-ldb/oldstable,now 2:1.1.20-0+deb8u1 armhf [installed,automatic]
python-lxml/oldstable,now 3.4.0-1 armhf [installed,automatic]
python-minecraftpi/oldstable,now 0.1.1-4 armhf [installed]
python-mosquitto/oldstable,now 1.3.4-2+deb8u1 all [installed]
python-notify/oldstable,now 0.1.1-4 armhf [installed,automatic]
python-ntdb/oldstable,now 1.0-5 armhf [installed,automatic]
python-numpy/oldstable,now 1:1.8.2-2 armhf [installed,automatic]
python-picamera/oldstable,now 1.13 armhf [installed]
python-picraft/oldstable,now 1.0 all [installed]
python-pifacecommon/oldstable,now 4.2.1-1 all [installed]
python-pifacedigitalio/oldstable,now 3.1.0-1 all [installed]
python-pigpio/oldstable,now 1.60-1 all [installed]
python-pil/oldstable,now 2.6.1-2+deb8u3 armhf [installed,automatic]
python-pygame/oldstable,now 1.9.2~pre~r3348-2~bpo8+rpi1 armhf [installed]
python-pyinotify/oldstable,now 0.9.4-1 all [installed,automatic]
python-pyorbit/oldstable,now 2.24.0-7 armhf [installed,automatic]
python-requests/oldstable,now 2.4.3-6 all [installed]
python-rtimulib/oldstable,now 7.2.1-3 armhf [installed,automatic]
python-samba/oldstable,now 2:4.2.14+dfsg-0+deb8u9 armhf [installed,automatic]
python-sense-emu/oldstable,now 1.0 all [installed]
python-sense-emu-doc/oldstable,now 1.0 all [installed]
python-sense-hat/oldstable,now 2.2.0-1 armhf [installed,automatic]
python-spidev/oldstable,now 2.0~git20150907 armhf [installed]
python-talloc/oldstable,now 2.1.2-0+deb8u1 armhf [installed,automatic]
python-tdb/oldstable,now 1.3.6-0+deb8u1 armhf [installed,automatic]
python-tk/oldstable,now 2.7.8-2 armhf [installed]
python-twython/oldstable,now 3.1.2-1 all [installed]
python-werkzeug/oldstable,now 0.9.6+dfsg-1+deb8u1 all [installed,automatic]
python-wicd/oldstable,now 1.7.2.4-4.1 all [installed,automatic]
python-xklavier/oldstable,now 0.4-4 armhf [installed,automatic]
python3-apt/oldstable,now 0.9.3.12 armhf [installed,automatic]
python3-chardet/oldstable,now 2.3.0-1 all [installed,automatic]
python3-codebug-i2c-tether/oldstable,now 0.2.3-1 all [installed]
python3-codebug-tether/oldstable,now 0.7.0-1 all [installed]
python3-colorama/oldstable,now 0.3.2-1 all [installed,automatic]
python3-debian/oldstable,now 0.1.27 all [installed,automatic]
python3-distlib/oldstable,now 0.1.9-1 all [installed,automatic]
python3-docutils/oldstable,now 0.12+dfsg-1 all [installed,automatic]
python3-flask/oldstable,now 0.10.1-2 all [installed]
python3-gi/oldstable,now 3.14.0-1 armhf [installed,automatic]
python3-gpiozero/now 1.3.2 all [installed,upgradable to: 1.4.0]
python3-html5lib/oldstable,now 0.999-3 all [installed,automatic]
python3-itsdangerous/oldstable,now 0.24+dfsg1-1 all [installed,automatic]
python3-jinja2/oldstable,now 2.7.3-1 all [installed,automatic]
python3-markupsafe/oldstable,now 0.23-1 armhf [installed,automatic]
python3-minecraftpi/oldstable,now 0.1.1-4 armhf [installed,automatic]
python3-numpy/oldstable,now 1:1.8.2-2 armhf [installed]
python3-openssl/oldstable,now 0.13.1-2 armhf [installed,automatic]
python3-pgzero/oldstable,now 1.1-1 armhf [installed]
python3-picamera/oldstable,now 1.13 armhf [installed]
python3-picraft/oldstable,now 1.0 all [installed]
python3-pifacecommon/oldstable,now 4.2.1-1 all [installed]
python3-pifacedigital-scratch-handler/oldstable,now 2.0.5-1 all [installed]
python3-pifacedigitalio/oldstable,now 3.1.0-1 all [installed]
python3-pigpio/oldstable,now 1.60-1 all [installed]
python3-pil/oldstable,now 2.6.1-2+deb8u3 armhf [installed,automatic]
python3-pip/oldstable,now 1.5.6-5 all [installed]
python3-pkg-resources/oldstable,now 5.5.1-1 all [installed,automatic]
python3-pygame/oldstable,now 1.9.2~pre~r3348-2~bpo8+rpi1 armhf [installed]
python3-pygments/oldstable,now 2.0.1+dfsg-1.1+deb8u1 all [installed,automatic]
python3-pyinotify/oldstable,now 0.9.4-1 all [installed,automatic]
python3-requests/oldstable,now 2.4.3-6 all [installed,automatic]
python3-roman/oldstable,now 2.0.0-1 all [installed,automatic]
python3-rpi.gpio/oldstable,now 0.6.3~jessie-1 armhf [installed]
python3-rtimulib/oldstable,now 7.2.1-3 armhf [installed,automatic]
python3-sense-emu/oldstable,now 1.0 all [installed]
python3-sense-hat/oldstable,now 2.2.0-1 armhf [installed,automatic]
python3-serial/oldstable,now 2.6-1.1 all [installed]
python3-setuptools/oldstable,now 5.5.1-1 all [installed,automatic]
python3-six/oldstable,now 1.8.0-1 all [installed,automatic]
python3-smbus/oldstable,now 3.1.1+svn-2 armhf [installed]
python3-sphinx/oldstable,now 1.2.3+dfsg-1 all [installed]
python3-spidev/oldstable,now 2.0~git20150907 armhf [installed]
python3-tk/oldstable,now 3.4.2-1 armhf [installed]
python3-twython/oldstable,now 3.1.2-1 all [installed]
python3-uno/oldstable,now 1:4.3.3-2+rpi4 armhf [installed]
python3-urllib3/oldstable,now 1.9.1-3 all [installed,automatic]
python3-werkzeug/oldstable,now 0.9.6+dfsg-1+deb8u1 all [installed,automatic]
python3-wheel/oldstable,now 0.24.0-1 all [installed,automatic]
