I've recently started migrating my Domoticz setup to an x86 box as I've had a couple of SD card problems with the Pi.
I have compiled the software from source and have everything working as expected apart from SSL access - I am now starting to forward ports so I can log-in remotely.
The error that appears in the log is:
Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 9443: use_certificate_chain_file: No such file or directory
I am currently using v3.8796.
I have had a search around but most of the errors appear to be due to permissions on ports below 1024, however I've decided not to use any of these ports.
So far I have tried differing port numbers and recreation of the systemd service but it appears the problem lies elsewhere.
Any suggestions would be greatly appreciated.
Fred
Cannot start server using SSL
- Domoticz version: 4.10717
Fred Boniface
- Dell Optiplex 390 - Ubuntu Linux 18.04.01 LTS - Aeotec Z-Wave USB - RFXtrx433 - Hue Hub 2 - LGTV Plugin -
Hue Bulbs in every room, Temp Sensors on each floor, Temp-Monitoring Fridge, LightWaveRF 'Mood Switches'
Fred Boniface
