I've recently started migrating my Domoticz setup to an x86 box as I've had a couple of SD card problems with the Pi.
I have compiled the software from source and have everything working as expected apart from SSL access - I am now starting to forward ports so I can log-in remotely.
The error that appears in the log is:
Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 9443: use_certificate_chain_file: No such file or directory
I am currently using v3.8796.
I have had a search around but most of the errors appear to be due to permissions on ports below 1024, however I've decided not to use any of these ports.
So far I have tried differing port numbers and recreation of the systemd service but it appears the problem lies elsewhere.
Any suggestions would be greatly appreciated.
Fred
Cannot start server using SSL
Jzjr
- Domoticz version: 4.10717
Fred Boniface
- Dell Optiplex 390 - Ubuntu Linux 18.04.01 LTS - Aeotec Z-Wave USB - RFXtrx433 - Hue Hub 2 - LGTV Plugin -
Hue Bulbs in every room, Temp Sensors on each floor, Temp-Monitoring Fridge, LightWaveRF 'Mood Switches'
Fred Boniface
