I know that 0x0000 normally happens when the hardware is not known to Domoticz (right?).
But I have a standard Aeon Z-Stick gen5 that shows this!! The nodes I'we included sp far seems to show up as they should.
Any ideas anyone?
Running win10 and 3.8796.
Don't think it matters but I factory reset the stick to start over since I have had some issues and was going to start over clean....
Controller show 0x000 as ID/TYpe
leby
- Domoticz version: 2020.2
/lennart
leby
Re: Controller show 0x000 as ID/TYpe
Might add that the OZW control panel i blank...
I can however turn one of the node on and off...
/lennart
Gravityz
- Domoticz version: 2025.1
i have had this once.
i messed with the led settings(5 enable controller blinking) on the aeon stick and everything was gone. reboot also did not fix things.
you can go to setup-hardware, select the usb stick and select disabled and then update.
after that select it again and do an enabled and update.
this always helps getting the devices in sync with the stick so it also might revive the stick with the os
