Measuring ampere with the Neo Coolcam power plug?
Aad3229
Post by Aad3229 »
I am using the Neo Coolcam Power Plug (GC00AM NAS - WR01ZE) with Domoticz version 3.8153 (latest stable) and the Aeotec ZW090 Z-Stick Gen5. I thought is was possible to measure Amps with this power plug but I cannot get this displayed. In the utility tab I only get kWh, Volt and 2 x Watt displayed.
Is it possible to display Amps and if so, how?
Domoticz V4.10717 on Synology, RFXtrx433E USB 433.92MHz Transceiver, 9 x KAKU Switch (APA3-1500R), 1 x ABST-604 KAKU Dusk sensor, MiLight iBox V6, OpenZwave USB-stick Aeon LabS, Zwave PIR, Zwave door sensors, Zwave powerplugs
manutremo
Re: Measuring ampere with the Neo Coolcam power plug?
Post by manutremo »
I got more sensors, including one showing the amps:
Maybe try to exclude and re-include.
This said, it is true that I have another one which showed a couple additional sensors after inclusions, so there seems to be some inconsistency when this devices are included.
EddyG
Post by EddyG »
Your device 134 is wrongly recognized that might be due OZW.
Upgrade to the latest OZW ( Version: 1.4-2713-ge2021e46-dirty )
manutremo
Post by manutremo »
It was my understanding that OZW can not be upgraded separately from Domoticz, can it?
Aad3229
Post by Aad3229 »
I have the Aeotec ZW090 Z-Stick Gen5 EU with firmware Version: 1.4-2501-g5af6780-dirty. I googled but can not find another firmware. On the Eotec website I find a message from: Mon, 4 Apr, 2016:
"There is no current firmware update for the Z-Stick Gen5. This page will be updated at a later time if there is a new firmware."
Anyone knows whre to get the above mentioned Version: 1.4-2713-ge2021e46-dirty ?
manutremo
Post by manutremo »
AAd3229, I think you are confusing the aeotec stick firmware version with the OpenZwave version which is what EddyG is relating to.
As you have discovered, there doesn't seem to be a any fw update for the stick itself.
The latest releases of OpenZwave (OZW) can be found at http://old.openzwave.com/snapshots/.
However OZW is integrated into Domoticz and, at least last time I checked, can't be upgraded separately.
My version of Domoticz is 3.8770 and it contains version 1.4-2824-g148ac06-dirty of OZW. If your version is Domoticz is an old one, you may want to try upgrade it to get a newer version of OZW.
EddyG
Post by EddyG »
I upgraded OZW several times, but you should stick to the 1.4 branch.
See: https://www.domoticz.com/wiki/Raspberry ... _OpenZWave
