Hi everyone,
I was wonder if Device Change command in Lua also applicable to the virtual device in thermostat type.
For example I would like to turn on a switch / light / or something if the set temperature of the thermostat has been changed.
Some thing like
if Device thermostat = "changed" then
Commandarray = switch == On
Or is there other suggestion ?
thanks
Lua virtual device thermostat device change
- jvdz
- Domoticz version: 4.107
Re: Lua virtual device thermostat device change
That should work fine. Did you actually give it a try to see what happens as the shown code doesn't have the proper syntax?
Jos
Jos
Thanks jvdz. No I have not tried it yet. It was just a quick type example. And I don't know the proper syntax either. I could not find the correct syntax for the device change. The wiki page only show the example of device change == on. That's why I was wondering if my idea was possible.
- jvdz
This would be a good point to start in case you want to write LUA scripts: https://www.domoticz.com/wiki/Events
Jos
Jos
I did something like this but does not work
--Thermostat setpoint
local WNKT = '1 thermostat'
local HSLPT = '2 Thermostat'
local KLNKT = '3 thermostat'
--Maxscript (Virtual switch)
local Max ="Maxscript"
if (devicechanged[WKT] == true or devicechanged[HSLPT] == true or devicechanged[KLNKT] == true) then
print('Run Maxscript')
commandArray[Max]='On AFTER 3'
- jvdz
The devicechanged table will contain the device(s) changed and their new value while you compare them to true.
try:
Jos
try:
- Thermostat setpoint
local Max = "Maxscript"
if (devicechanged[WKT] or devicechanged[HSLPT] or devicechanged[KLNKT]) then
commandArray[Max] = 'On AFTER 3'
jvdz
YOU ARE AWESOME.
Thanks a lot.
I though DeviceChanged only respons to 'On' or 'Off'
YOU ARE AWESOME.
Thanks a lot.
- Domoticz version: v3.8153
Hi.
I am using thermostat too.
Here is my examples of my action, if thermostat setpoint is changed.
In my case, it sends command to my device with setpoint value, but you can write your own action.
LUA:
But I prefer dzVents now:
LUA:
if devicechanged['Kacka_Setpoint'] then
DomDevice = 'Kacka_Setpoint'
DomValue = otherdevices_svalues[DomDevice]
CalcValue = (DomValue*1)
print(CalcValue)
url= 'http://192.168.1.102/control?cmd=event,HeatSetpoint='..(CalcValue)..''
print(url)
commandArray['OpenURL']= url
devices = {
'Kacka_Setpoint'
local url= 'http://192.168.1.102/control?cmd=event,HeatSetpoint='..(device.state)..''
print(url)
domoticz.openURL(url)
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
1 x Shelly 1
1 x RFLink
4x Cam IPC-T240H
