Lua virtual device thermostat device change
433Mhz opensource Receiver & Transmitter.
Chakkie
Post by Chakkie »
Hi everyone,
I was wonder if Device Change command in Lua also applicable to the virtual device in thermostat type.
For example I would like to turn on a switch / light / or something if the set temperature of the thermostat has been changed.
Some thing like
if Device thermostat = "changed" then
Commandarray = switch == On
Or is there other suggestion ?
thanks
jvdz
Domoticz version: 4.107
Re: Lua virtual device thermostat device change
Post by jvdz »
That should work fine. Did you actually give it a try to see what happens as the shown code doesn't have the proper syntax?
Jos
Chakkie
Post by Chakkie »
Thanks jvdz. No I have not tried it yet. It was just a quick type example. And I don't know the proper syntax either. I could not find the correct syntax for the device change. The wiki page only show the example of device change == on. That's why I was wondering if my idea was possible.
jvdz
Post by jvdz »
This would be a good point to start in case you want to write LUA scripts: https://www.domoticz.com/wiki/Events
Jos
Chakkie
Post by Chakkie »
I did something like this but does not work
--Thermostat setpoint
local WNKT = '1 thermostat'
local HSLPT = '2 Thermostat'
local KLNKT = '3 thermostat'
--Maxscript (Virtual switch)
local Max ="Maxscript"
if (devicechanged[WKT] == true or devicechanged[HSLPT] == true or devicechanged[KLNKT] == true) then
print('Run Maxscript')
commandArray[Max]='On AFTER 3'
jvdz
Post by jvdz »
The devicechanged table will contain the device(s) changed and their new value while you compare them to true.
try:
 - Thermostat setpoint
local Max = "Maxscript"
if (devicechanged[WKT] or devicechanged[HSLPT] or devicechanged[KLNKT]) then
	commandArray[Max] = 'On AFTER 3'
Jos
Chakkie
Post by Chakkie »
jvdz
YOU ARE AWESOME.
Thanks a lot.
I though DeviceChanged only respons to 'On' or 'Off'
kimot
Domoticz version: v3.8153
Post by kimot »
Hi.
I am using thermostat too.
Here is my examples of my action, if thermostat setpoint is changed.
In my case, it sends command to my device with setpoint value, but you can write your own action.
LUA:
        if devicechanged['Kacka_Setpoint'] then
            DomDevice = 'Kacka_Setpoint'
            DomValue = otherdevices_svalues[DomDevice]
            CalcValue = (DomValue*1)
            print(CalcValue)
            url= 'http://192.168.1.102/control?cmd=event,HeatSetpoint='..(CalcValue)..''
            print(url)
            commandArray['OpenURL']= url
But I prefer dzVents now:
	active = true, -- set to false to disable this script
		devices = {
			'Kacka_Setpoint'
            local url= 'http://192.168.1.102/control?cmd=event,HeatSetpoint='..(device.state)..''
            print(url)
            domoticz.openURL(url)
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
