Yeelight Color temperature
BullFrog
Post by BullFrog »
Tried to find solution (google, youtube, this forum), but in the last 2 days I didn't have luck, so I'm begging you to help me achieve the most simple task ever!
Xiaomi YeeLight RGBW color temperature, read WIKI, but as a newbie it kinda misses a few steps, and I might try to do something easy and forgetting a crucial step somewhere.
Domoticz Beta V3.8701 for Synology DS215j
Making the dummy Hardware
Dummy selector switch named : "Color Temperature"
Code I copy-pasted from wiki, and changed IP for the current IP address of the RGBW bulb (fix IP from router with DHCP), I guess the port is fix, so I haven't really changed it.
Changed selector switch to DIMMER and tried to ADD the bulb as a sub/slave, but also tried to do without this step, same outcome.
When I added as a sub, it changed the original Bulb Switch on/off, but in fact the bulb stayed ON all the time, never turned off or on by this, it maybe a helpful info.
Log when I use the dimmer for color temperature, no error messages :(
 2017-12-03 19:48:05.796 User: BullFrog initiated a switch command (56/Color Temperature/Set Level)
2017-12-03 19:48:05.803 (Dummy) Light/Switch (Color Temperature)
2017-12-03 19:48:05.839 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",3812, 75]}\r\n' | nc -w1 192.168.0.221 55443
2017-12-03 19:48:05.839 LUA: Color Temp= 3812
2017-12-03 19:48:09.048 User: BullFrog initiated a switch command (56/Color Temperature/Set Level)
2017-12-03 19:48:09.055 (Dummy) Light/Switch (Color Temperature)
2017-12-03 19:48:09.093 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",6404, 75]}\r\n' | nc -w1 192.168.0.221 55443
2017-12-03 19:48:09.093 LUA: Color Temp= 6404
2017-12-03 19:48:10.707 User: BullFrog initiated a switch command (56/Color Temperature/Set Level)
2017-12-03 19:48:10.714 (Dummy) Light/Switch (Color Temperature)
2017-12-03 19:48:10.787 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",0, 75]}\r\n' | nc -w1 192.168.0.221 55443
2017-12-03 19:48:10.787 LUA: Color Temp= 0
2017-12-03 19:48:15.178 (YeeLight Controller) Lighting Limitless/Applamp (Hálószoba - RGBW LED)
2017-12-03 19:48:15.217 LUA: sudo echo -ne '{"id":1, "method":"set_scene","params":["ct",6452, 75]}\r\n' | nc -w1 192.168.0.221 55443
2017-12-03 19:48:15.217 LUA: Color Temp= 6452
What step did I miss or screw up? :\
BullFrog
Re: Yeelight Color temperature
Post by BullFrog »
Any chance for a little help? I'm really desperate :(
BullFrog
Post by BullFrog »
Please help! me or at least give me some hints! :(
woody4165
Post by woody4165 »
Try this command
warm_white=(255*65536)+(172*256)+68
runcommand25 = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"color\", "..warm_white..", 25]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
os.execute(runcommand25);
where warm_white is obtained with the RGB formula as above (R*65536)+(G*256)+B
in this case you will set the color and the brightness (25)
I've transformed your script in dzVents and it's working fine, included the Off that turns off the lamp.
Just added the off command in case CalcValue is nil
		devices = {
			'ColorTemp'
        IP = '192.168.xx.xx';
        PORT = 'xxxxx'
        if device.state == 'Off' then -- turn off
            runcommandoff = "sudo echo -ne '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
            os.execute(runcommandoff);
       --  print(runcommandoff)
            CalcValue = ((device.level-1)*48)+1700;
            if CalcValue==nil then
                CalcValue=0
                print("CalcValue = "..CalcValue)
                runcommand = " sudo echo -ne '{\"id\":1,\"method\":\"set_scene\", \"params\":[\"ct\", "..CalcValue..", 50]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
                os.execute(runcommand);
Do someone know the formula to use dimmer to change color from 0% to 100% on all the RGB values?
BullFrog
Post by BullFrog »
Thank you for trying to help me, I really appreciate it!
Tried to copy paste your 2nd code and overwrite the previous one but keeping the IP and port numbers, but the dummy slider switch seems to do nothing.
In the log I get this, but nothing changes :
" 2017-12-14 23:12:22.550 User: BullFrog initiated a switch command (56/Color Temperature/Set Level)
2017-12-14 23:12:22.990 (Dummy) Light/Switch (Color Temperature)
2017-12-14 23:12:48.186 User: BullFrog initiated a switch command (56/Color Temperature/Set Level)
2017-12-14 23:12:48.218 (Dummy) Light/Switch (Color Temperature) "
woody4165
Post by woody4165 »
I imagine you changed the events from Lua to dzVents
and set it to Device, like the image above
lamouette
Post by lamouette »
Why don't you use a scene ?
BullFrog
Post by BullFrog »
lamouette wrote: Friday 15 December 2017 9:53 Why don't you use a scene ?
I want to, but there is absolutely no option in events to change color temperature :\
using only the RGB colors I can't manage to get that warm color I want to use, it is neutral white or simple yellow, there is nothing inbetween here.
I think yeelight is using different leds for warm-neutral-cold color emperatures.
@woody4165
yes, tried it with that also, in theory it is working, but physically it does nothing for me:
 2017-12-17 19:13:03.604 User: BullFrog initiated a switch command (71/ColorTemp/Set Level)
2017-12-17 19:13:03.616 (Dummy) Light/Switch (ColorTemp)
2017-12-17 19:13:03.746 dzVents: Info: Handling events for: "ColorTemp", value: "Off"
2017-12-17 19:13:03.746 dzVents: Info: ------ Start internal script: RGBW_dz: Device: "ColorTemp (Dummy)", Index: 71
2017-12-17 19:13:03.979 dzVents: Info: ------ Finished RGBW_dz
2017-12-17 19:13:05.075 User: BullFrog initiated a switch command (71/ColorTemp/Set Level)
2017-12-17 19:13:05.082 (Dummy) Light/Switch (ColorTemp)
2017-12-17 19:13:05.232 dzVents: Info: Handling events for: "ColorTemp", value: "On"
2017-12-17 19:13:05.232 dzVents: Info: ------ Start internal script: RGBW_dz: Device: "ColorTemp (Dummy)", Index: 71
2017-12-17 19:13:05.232 dzVents: CalcValue = 6404
2017-12-17 19:13:05.271 dzVents: Info: ------ Finished RGBW_dz
Tried to rename/redo the switch and script, the IP address for bulb is fix, I get no error message, it just does nothing.
Using this beta domoticz (also didnt work with previous version...) : domoticz_armada375-6.1_3.0.8770-7.spk 03-Dec-2017 22:00 15M
QSKONE
Post by QSKONE »
Hi , Hi , it is possible create selector switch with kelvin settings like Yeelight app?
Image[/url]
madrian
Post by madrian »
It is on the way:
viewtopic.php?f=11&t=13016
