How to enable logging
DomoticaRob
Domoticz version: V4.9700
Post by DomoticaRob »
I use Domoticz V3.8153 and can make dzVents scripts. Unfortunately I have no logging. The dzVents Wiki says that I can enable logging in the settings:
In my settings there is not such an option.
In the normal lua I could use print().
How can I get it?
dannybloe
Re: How to enable logging
Post by dannybloe »
There should be more on the settings page than I see in your screenshot. There should be dzVents settings at the bottom. I suggest to upgrade your Domoticz, preferably to the latest beta version.
DomoticaRob
Hello Danny,
No, this is all there is.
I did an ./updatebeta:
As you can see, it ends with an error and Domoticz doesn't work any more.
So after that I did an ./updaterelease:
As you can see, it ends fine and Domoticz works again, but still without dzVents in the settings. In the Domoticz lua-editor I can make dzVents scripts, but still without logging.
DewGew
Domoticz version: V4.10618
Post by DewGew »
Maybe you already fixed it but you have to clear cache after upgrade also.
DomoticaRob
For me, the logging is not yet fixed. In my case was clearing the cache not the solution. As you can see I can't install the Beta version. For now I have dzVents in the Release version without 'logging'. I use the 'print' statement to log. For now that is ok and I'll wait till the next Release version.
