[SOLVED] Integrating DeltaSol DL2 Topic is solved
furriephillips
Domoticz version: 4.10268
Post by furriephillips »
I'm trying to integrate the stats from my Solar Hot Water system's "Resol DataLogger DL2" (http://amzn.to/2k4y1mm) into Domoticz. Well, "integrate" may be overstating it - I'm just scraping the stats off the live data/stats webpage (https://resoldl2.furrie.net/dl2/live/data) & pushing the data into some dummy/virtual sensors.
My shell script wgets the page & then processes the text into a state where I have a list of CSVs, which I then PUT into Domoticz on my Raspberry Pi, using curl.
Here's the wget (expanded, to aid visual delight): -
wget --no-check-certificate --secure-protocol=TLSv1 -q -O - https://resoldl2.furrie.net/dl2/live/data \
  | grep "<td>" \
  | sed -e 's/^.*<td>//g' -e 's/&nbsp;//g' -e 's|</td>||g' \
  | dos2unix \
  | sed -e ':a;N;$!ba;s/:\n/,/g' \
  | grep -v 'relay 2' \
  | grep -v defective \
  | grep -v temperature \
  | grep -v operation \
  | sed -e 's/Temperature sensor 1/145,Solar Collector Temp (°C)/' \
    -e 's/Temperature sensor 2/146,Hot-Water Tank Bottom Temp (°C)/' \
    -e 's/Temperature sensor 3/147,Hot-Water Tank Top (°C)/' \
    -e 's/Temperature sensor 4/148,Pump Station Return Temp (°C)/' \
    -e 's/Pump speed relay 1/149,Pump Duty-Cycle (%)/' \
    -e 's/Operating hours relay 1/150,Pump Duration (h)/' \
    -e 's/Heat quantity/151,Heat Generation (kWh)/' \
  | sed -e 's/,\(.*\) .*$/,\1/g' \
  | grep -v DL2 \
  | grep -v Status \
  | grep -v Programme \
  | grep -v Version
Here's the curl output that is almost 100% successful: -
145,Solar Collector Temp (°C),22.1
/usr/bin/curl -S -X PUT http://domoticz.furrie.net/json.htm?type=command&param=udevice&idx=145&nvalue=0&svalue=22.1
   "status" : "OK",
   "title" : "Update Device"
146,Hot-Water Tank Bottom Temp (°C),23.8
/usr/bin/curl -S -X PUT http://domoticz.furrie.net/json.htm?type=command&param=udevice&idx=146&nvalue=0&svalue=23.8
   "status" : "OK",
147,Hot-Water Tank Top (°C),46.0
/usr/bin/curl -S -X PUT http://domoticz.furrie.net/json.htm?type=command&param=udevice&idx=147&nvalue=0&svalue=46.0
   "status" : "OK",
148,Pump Station Return Temp (°C),15.2
/usr/bin/curl -S -X PUT http://domoticz.furrie.net/json.htm?type=command&param=udevice&idx=148&nvalue=0&svalue=15.2
   "status" : "OK",
149,Pump Duty-Cycle (%),0
/usr/bin/curl -S -X PUT http://domoticz.furrie.net/json.htm?type=command&param=udevice&idx=149&nvalue=0&svalue=0
   "status" : "OK",
150,Pump Duration (h),9307
/usr/bin/curl -S -X PUT http://domoticz.furrie.net/json.htm?type=command&param=udevice&idx=150&nvalue=0&svalue=9307
   "status" : "OK",
151,Heat Generation (kWh),106677.31
/usr/bin/curl -S -X PUT http://domoticz.furrie.net/json.htm?type=command&param=udevice&idx=151&nvalue=0&svalue=106677.31
<html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>
This is infuriating, because the last command that fails in the script, actually does work if I issue it manually, a la: -
% /usr/bin/curl -S -X PUT http://domoticz.furrie.net/json.htm\?type\=command\&param\=udevice\&idx\=151\&nvalue\=0\&svalue\=106677.31
   "status" : "OK",
or with single quotes instead of the escapes: -
% /usr/bin/curl -S -X PUT 'http://domoticz.furrie.net/json.htm?type=command&param=udevice&idx=151&nvalue=0&svalue=106677.31'
   "status" : "OK",
I reverse-sorted the wget output, to test if it was the for loop that was borking on the last iteration, but the first one fails.
I have enabled -v and -S on curl and can see no real difference in the successful & unsuccessful requests. Is there something I can do on the Domoticz side, to figure out what's occurring? I wondered if the value I'm inserting is such a high number of kWh, but it DOES work manually, so probably not. Anyway, looking forward to any advice, cheers!
Here's some screenshots of the stats as shown in Domoticz
Last edited by furriephillips on Tuesday 05 December 2017 23:08, edited 1 time in total.
furriephillips
Re: Integrating DeltaSol DL2
Well, this was stupidly easy to resolve, although quite the swine to actually diagnose. Long story short, I highlighted the screen output & noticed some trailing whitespace on the errant element. The DL2's '/dl2/live/data' page places 2 spaces between the value and the unit - ONLY on this value! I fixed this by adding this sed operation, before the final (existing) sed operation; all it does is turn any double-spaces into a single space - which then gets handled by the previous script's final sed operation: -
-e 's/  / /g' \
This is my script, which I'm running from crontab, every 5 minutes (with ' 2>&1 >/dev/null', to prevent cron emails); I understand the sun doesn't shine at night, but the tank temperatures are still subject to change - it gets cold/rains/snows/etc and more importantly, I have a gas boiler that comes on to bring the top of the tank to the required temp & that's never been monitored - this costs me money, so I want to stay abreast of any issues.
#!/bin/zsh
## SolarHW-to-Domoticz
SolarHW='https://<DL2Hostname:Port>/dl2/live/data'
DomoticzHost='<DomoticzHostname:Port>'
wget=`which wget`
curl=`which curl`
## Tweak IFS so that we separate on newline, not spaces
## Record the old value
OLDIFS="$IFS"
## Tweak it
IFS=$'\n'
for stat in $(
    $wget --no-check-certificate --secure-protocol=TLSv1 -q -O - $SolarHW \
        | grep "<td>" \
        | sed -e 's/^.*<td>//g' \
            -e 's/&nbsp;//g' \
            -e 's|</td>||g' \
        | dos2unix \
        | grep -v 'relay 2' \
        | grep -v defective \
        | grep -v operation \
        | grep -v DL2 \
        | grep -v Status \
        | grep -v Programme \
        | grep -v Version \
        | sed -e 's/  / /g' \
do
    echo -e "\e[1;4;35m"
    printf '%s\n' "$stat"
    IDX=`echo $stat | cut -f1 -d,`
    STAT=`echo $stat | cut -f3 -d,`
    echo -e -n "\e[1;4;33m"
    echo $curl -s -X PUT "http://$DomoticzHost/json.htm?type=command&param=udevice&idx=$IDX&nvalue=0&svalue=$STAT"
    echo -e -n "\e[0m"
done
echo ''
## Return IFS to normal
IFS="$OLDIFS"
exit 0
#EOF
I've published the code-proper, on Github: https://github.com/furriephillips/ResolDL2-to-Domoticz
