os.execute.aftersec
markjgabb
- Domoticz version: 3.8153
os.execute.aftersec
is there a way to get a delayed os.execute working in dzvents atm i have the following
os.execute('espeak welcome-home').afterSec(20)
but it seems to ifnore the aftersec and just runs it instantly.....
also not sure how to make longer that one word arguments os the os.execute as it will only take one word at the moment
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
RFlink 334 mhz
mysensors
broadlink
dannybloe
Re: os.execute.aftersec
os.execute is an os function that is not managed at all by dzVents. So no, that's not working unfortunately. Maybe you can create some bash function with an internal delay and execute that instead from your script.
markjgabb
that sounds like a likely way to do it...simple and it works
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
BakSeeDaa
Below is an example how it can be done. This specific example calls an url using curl on a linux platform. The important thing is to release the control back to Domoticz immediately.
local delay = 5
local url = 'http://somwebsite.com'
os.execute('(sleep '..delay..';curl -s "'..url..'" > /dev/null)&')-
markjgabb
have used this method and its works wonderfully thanks guys for the advice......now to laugh at wifes reaction when house welcomes her home later on
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
RFlink 334 mhz
mysensors
broadlink
poudenes
- Domoticz version: 3.8993
What is the reason you put this a the end: > /dev/null)&BakSeeDaa wrote: Tuesday 21 November 2017 8:28 Below is an example how it can be done. This specific example calls an url using curl on a linux platform. The important thing is to release the control back to Domoticz immediately.Code: Select all
local delay = 5 local url = 'http://somwebsite.com' os.execute('(sleep '..delay..';curl -s "'..url..'" > /dev/null)&')
I use os.execute as well but then just the URL :
os.execute('curl "http://127.0.0.1:8081/json.htm?type=command¶m=setcolbrightnessvalue&idx=3&hue=18&brightness=50&iswhite=false"')RPi3 B+, Debain Stretch, Domoticz, Homebridge, Dashticz, RFLink, Milight, Z-Wave, Fibaro, Nanoleaf, Nest, Harmony Hub, Now try to understand pass2php
BakSeeDaa
It's a redirection (discard) of the command output (not necessary) followed by the ampersand sign that will cause the command to run in the background. (prevents delays caused by waiting for the command to finish)poudenes wrote: Tuesday 21 November 2017 13:49
poudenes
Thanks for the "always" great help!!!. I will add them as well thenBakSeeDaa wrote: Tuesday 21 November 2017 14:59It's a redirection (discard) of the command output (not necessary) followed by the ampersand sign that will cause the command to run in the background. (prevents delays caused by waiting for the command to finish)poudenes wrote: Tuesday 21 November 2017 13:49
BakSeeDaa
Your'e welcome. Don't forget the inner parenthesis which is crucial for it to work.poudenes wrote: Tuesday 21 November 2017 15:01 Thanks for the "always" great help!!!. I will add them as well then![]()
poudenes
So it will look like this then
os.execute('(curl -s "http://127.0.0.1:8081/........iswhite=false" > /dev/null)&')RPi3 B+, Debain Stretch, Domoticz, Homebridge, Dashticz, RFLink, Milight, Z-Wave, Fibaro, Nanoleaf, Nest, Harmony Hub, Now try to understand pass2php
Nautilus
This should be enough when you don't need the separate sleep command:
os.execute('curl -s "http://127.0.0.1:8081/json.htm?type=command¶m=setcolbrightnessvalue&idx=3&hue=18&brightness=50&iswhite=false" &')-
ben53252642
Using this in a Lua script to run multiple commands using os.execute, thanks!
os.execute ('(/bin/sleep 4 && /usr/bin/curl -s "http://192.168.0.5:1880/hueapi?devicename=lightstripmainbathmirror&state=on&brightness=254&r=0&g=0&b=0&colortemp=351&transition=0.5")&')Unless otherwise stated, all my code is released under GPL 3 license: https://www.gnu.org/licenses/gpl-3.0.en.html
