os.execute.aftersec
markjgabb
Domoticz version: 3.8153
os.execute.aftersec
Post by markjgabb »
is there a way to get a delayed os.execute working in dzvents atm i have the following
os.execute('espeak welcome-home').afterSec(20)
but it seems to ifnore the aftersec and just runs it instantly.....
also not sure how to make longer that one word arguments os the os.execute as it will only take one word at the moment
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
dannybloe
Re: os.execute.aftersec
Post by dannybloe »
os.execute is an os function that is not managed at all by dzVents. So no, that's not working unfortunately. Maybe you can create some bash function with an internal delay and execute that instead from your script.
markjgabb
Post by markjgabb »
that sounds like a likely way to do it...simple and it works :D
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
BakSeeDaa
Post by BakSeeDaa »
Below is an example how it can be done. This specific example calls an url using curl on a linux platform. The important thing is to release the control back to Domoticz immediately.
local delay = 5
local url = 'http://somwebsite.com'
os.execute('(sleep '..delay..';curl -s "'..url..'" > /dev/null)&')
markjgabb
Post by markjgabb »
have used this method and its works wonderfully thanks guys for the advice......now to laugh at wifes reaction when house welcomes her home later on
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
BakSeeDaa
Post by BakSeeDaa »
markjgabb wrote: Tuesday 21 November 2017 8:49 have used this method and its works wonderfully thanks guys for the advice......now to laugh at wifes reaction when house welcomes her home later on
We should not underestimate the importance of WAF for the future of home automation. ;)
poudenes
Domoticz version: 3.8993
Post by poudenes »
BakSeeDaa wrote: Tuesday 21 November 2017 8:28 Below is an example how it can be done. This specific example calls an url using curl on a linux platform. The important thing is to release the control back to Domoticz immediately.
local delay = 5
What is the reason you put this a the end: > /dev/null)&
I use os.execute as well but then just the URL :
os.execute('curl "http://127.0.0.1:8081/json.htm?type=command&param=setcolbrightnessvalue&idx=3&hue=18&brightness=50&iswhite=false"')
BakSeeDaa
Post by BakSeeDaa »
poudenes wrote: Tuesday 21 November 2017 13:49
It's a redirection (discard) of the command output (not necessary) followed by the ampersand sign that will cause the command to run in the background. (prevents delays caused by waiting for the command to finish)
poudenes
Post by poudenes »
BakSeeDaa wrote: Tuesday 21 November 2017 14:59
Thanks for the "always" great help!!!. I will add them as well then :)
BakSeeDaa
Post by BakSeeDaa »
poudenes wrote: Tuesday 21 November 2017 15:01 Thanks for the "always" great help!!!. I will add them as well then :)
Your'e welcome. Don't forget the inner parenthesis which is crucial for it to work.
poudenes
Post by poudenes »
BakSeeDaa wrote: Tuesday 21 November 2017 15:44
So it will look like this then :)
os.execute('(curl -s  "http://127.0.0.1:8081/........iswhite=false" > /dev/null)&')
Nautilus
Post by Nautilus »
This should be enough when you don't need the separate sleep command:
os.execute('curl -s "http://127.0.0.1:8081/json.htm?type=command&param=setcolbrightnessvalue&idx=3&hue=18&brightness=50&iswhite=false" &')
ben53252642
Post by ben53252642 »
Using this in a Lua script to run multiple commands using os.execute, thanks!
os.execute ('(/bin/sleep 4 && /usr/bin/curl -s "http://192.168.0.5:1880/hueapi?devicename=lightstripmainbathmirror&state=on&brightness=254&r=0&g=0&b=0&colortemp=351&transition=0.5")&')
