"Time > Sunrise AND Time < Sunset" doesn't work
Feddan
Post by Feddan »
I have two saved events, where I want to turn Off an outside lamp on Sunrise, and turn it On on Sunset.
Sunrise:
Sunset:
But it doesn't work! What am I missing?
CaesarPL
Re: "Time > Sunrise AND Time < Sunset" doesn't work
Post by CaesarPL »
Why blockly :) ? You can do it directly on the switch.
Feddan
Post by Feddan »
CaesarPL wrote: Wednesday 18 October 2017 16:25 Why blockly :) ? You can do it directly on the switch.
Oh, I did not know that. I will try that instead, thanks!
jvdz
Domoticz version: 4.107
Post by jvdz »
For the record: The SunSet blockly is never true as that is pretty impossible when you think about it! Maybe an OR relation would be better for that one. ;)
Jos
CaesarPL
Post by CaesarPL »
Please check my example. When you press Timers, you can set time when you want to switch On or Off
Derik
Post by Derik »
you need to make a blockley more in this setup. because you use the extra if blockley...
Or you can use the base blockley.
olleman
Post by olleman »
I'm having a similliar problem but my blockly is a bit more advanced so I can't solve it directly on the switch.
My first condition (this one triggers as expected)
is "If PIR on AND Time: >Sunset AND Time: <22.00
Set whatever Switch on for 2 minutes
Second condition (this one doesn't trigger)
"If PIR on AND Time: >Sunset AND Time: <Sunrise
Any suggestions to what I'm doing wrong?
kuifje
Domoticz version: latest
Post by kuifje »
When its >sunset it is <sunrise, and the other way around. You dont need the <sunrise of the >sunrise. And you dont need the if/else blocky but the one without the blue thing.
Good luck.
Kuifje
Xztraz
Post by Xztraz »
Set trigger on time and this works. (you'r script would trigger every minute between times)
aDJa
Domoticz version: 4.9700
Post by aDJa »
Hi there,
I had the same challenge, but also wanted everything in de blockly with sunset sunrise.
unfortunately i still had to use a dummy switch but i got the rest in de blockly.
see attachement:
BlocklyActivatestairsDuringNight
p.s. the dummy has a sunrise and sunset timer but is also being turned off when the stairs are being turned off manually. (its not being turned on by the stairs)
OS: RPi4B, GH
ELECTRICITY: P1 Smart Meter USB
WATER: NPN inductive sensor
SOLAR: Omnik Inverter, PVOutput
LIGHTS: Philips HUE + GLEDOPTO + Yeelight
SENSORS: Xiaomi Temp + Humidity + Baro + Motion + HUE
